Giving up for now (for ever!)
So sad to see this. I'm almost tempted to try to replicate this faultGiving up for now (for ever!)
Have you tried running the game in compatibility mode for Win 8.1?
Google how to do this plz so I don't have to type I just woke up. It might work.
Before you do can you check you have the very latest W10 build.
Run CMD from the search icon and enter winver. This should pop up a box saying Windows 10 version 1703 build 15063.540.
Andi.
PS You could also try this -
- If you’re using Windows 10 or Windows 7
- Click Start, type Command Prompt or cmd in the Search box, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
- At the command prompt, type the following command, and then press ENTER:
- sfc /scannow
- The sfc /scannow command will scan all protected system files, and replace corrupted files with a cached copy that’s located in a compressed folder at %WinDir%\System32\dllcache.
- The %WinDir% placeholder represents the Windows operating system folder. For example, C:\Windows.
- Note Do not close this Command Prompt window until the verification is 100% complete. The scan results will be shown after this process is finished.
I have a similar issue with the Creators, and my answer was rather dramatic ~ I just uninstalled the Creators and then blocked it from installing again. In time the issue will probably be resolved in time so I will keep trying now and then. But honestly, unless there is something you specifically want in the update, there is no rush to install it.
The train drivers became unionized in creators update, he needs to roll back to anniversary update or negotiate with ASLEF.However, I have just updated my win 10 with the creators update AND now Train Simulator will not run past the startup banner screen - the trains just freeze!"
For future ref, you can link familiy steam libraries and install/play each others games (only one person can play each at once).Well some sort of solution. Bought my own version of TS as it was reduced to £12.
I have to ask but have you done a malware check?
Andi.
If you want to run it on your older PC just turn down some of the grafix settings or set it to run at a lower res eg 720 not 1080
