 - 3 Oct 2009
 - Wales
How on earth do you find the threads you've created now? Used to be able to find it easily on your profile page..
			Go to you profile and under the "postings" tab right at the bottom gives you two links, one for all posts and other for all threads.How on earth do you find the threads you've created now? Used to be able to find it easily on your profile page..
Thanks, that was well hiddenGo to you profile and under the "postings" tab right at the bottom gives you two links, one for all posts and other for all threads.
Checking someone's trust doesn't seem to work. It won't accept my username and password on that page. Obviously works in general otherwise I wouldn't be posting this.
Double check please because I don't think it's me.
I don't like how it shows my account name when I'm posting.
If you've had a username change, try your old username. If not then never mind!
 But the trust section doesn't work for me.Nope. I changed my password around the time the forums switched to the new design. I did have a password issue for a bit but they said the databases just hadn't switched over yet. But my password works in general just not for trust.
Plus the old password doesn't work either.
I wouldn't be posting if I had password issue.But the trust section doesn't work for me.
Drop a post in FCD and we can grab an admin.
FCD?
Trust section of website broken for me. Doesn't like my password.![]()
