- 7 Mar 2013
- Caistor
Looks alright?
CPU: 1700 @3.8
GPU: 1080Ti @2050/3000
Cheers dude, that is actually helpful. Its always nice to have a comparisonas a comparison my score is 3760 also with a 2600k at 4.3ghz and asus strix oc at stock gaming mode so you seem to be where you should be. hope that helps![]()
Looks alright?
CPU: 1700 @3.8
Scoreboard updated.![]()
Please don't think i've turned up months later to be a **** on purpose. But is this result running x8 AA?
I was just looking up the leaderboards to compare ryzen scores and this seems to be somewhat of an outlier for the clock speeds.
JR
JR
Aorus 1080ti Extreme (OC mode out of the box)
Gpu 2062/1431/5724
Ryzen 1700x @ 3.4
Mem: G Skill Flare X C14 3200
Driver: 384.94
For the scoreboard you need to use 8xMSAA.
CPU : i5 6600K @ 3500
GPU : HD 7850 @ 900/1200
Divers : 17.1.1
Seems an odd result?ryzen 1800x @ 4GHz / Vega RX 64 XTX AIO @ 1980MHz/1100MHz / Driver 17.8.1.beta6
score - 2387 @ 1080P -
https://preview.~ibb.co~/erqYsF/00004.jpg
1980mhz is far higher than the maximum overclocks I have seen from reviewers and it's only a few pegs above a 780ti on the score board.
17** MHz in reviews used 600w so just seemed an abnormally high result?He is using an overclocked AIO cooled card hence the clockspeeds.
As far as AMD cards go it is a very good result as this bench is like NVidia's home ground.![]()
