Is it even worth over locking a 1800X
Mine is stable at 4GHz/2933MHz RAM but I have to give it 1.4v.
There is a video somewhere where some official AMD guy says over 1.425 will shorten the lifespan of the chip.
@Rossi
i wanted an extremely quiet rig. Due to the HUGE wattage i9 require that's not possible.
I got the 8pack Kit on the way and settled for 3.8Ghz @ 1.248v for now, Quiet & Fast. Lower Voltages than "Stock"
I'm struggling to decide whether I should keep my Vengeance 3000MHz kit or swap it out for something better.
Is there really that much of a difference? I can run my RAM @ 2800MHz
what would you swap it to? if you cant get your ram to even run at its stated speed, what can another kit do for you? maybe a little lower timings?
Yes. Gaming alone there's a big difference, there's a bottleneck under 3200MHz. I recommend you get some 8Pack Team Group Dark Pro stuff, guaranteed to be B-Die.
@Rossi
dpd missed my pickup from ocuk today so ocuk was kind enough to sort it out & deliver tomorrow.
So should have it sometime tomorrow
So i go straight in with the XMP profile of 3600? to give it a try or start at 3466 and go down?
I had to order in a hurry this morning and ended up going for
G.SKILL F4-3200C14D-16GFX 16 GB (8 GB x 2) Flare X Series DDR4 3200 MHz PC4-25600 CL14 Dual Channel Memory Kit - Black
