- 1 Apr 2010
When you put it that way then yes go for the Ryzen build. You should get ar least £200 for your old CPU, Mobo and RAM.
He should get more than that for the cpu on its own.
Man, I wish I had the kind of money to throw around to upgrade my 980.But it's not faulty and not giving me issues so far, so it shall stay on for now.
Going for it, and will look into GPU later on in the year if I ever feel like it. 980 is more than enough for gaming so far, so I'm okay.
No overclocking planned. With that board it looks like I can get £150 of 3200 RAM with the 1600x CPU with a touch of change. Still gutted that DDR4 has got so pricey!
Don't fret, my RAM was £120 3 years ago.
Looks like if I grab a £190 AMD CPU and ~£120 on DDR4 RAM then that leaves me with £190 to play with on an AMD board. That's doable!
No idea how good the 1600 CPU is though. And still no clue on what to look for on a system board other than the basics.
It's a hex core that definitely pulls ahead of your current CPU in heavily multithreaded workloads, and is better for multitasking (playing overwatch while streaming it and watching netflix on your second screen while you do some other junk in the background for example).
There are two downsides to Ryzen. The obvious upshot is the value for your money. Downsides are that most things are still Intel optimized, also that they don't overclock well. 4Ghz is roughly the limit with Ryzen. Sometimes not even that. Meanwhile Kaby Lake can hit darn near 5Ghz. IPC is very similar.
Yeh, and RAM for my first PC in 1990 was £30 per MB, so 16GB would cost you £26000 in today's money![]()
Shouldn't it be £30*16*1024=£491520 without inflation rates, and even more with inflation rates? £491,520.00 in 1990 is equivalent to £914,855.54 in 2017.
Go with Intel, they have a far more reliable platform than AMD IMO.
Never seen so many issues with RAM compatibility before. Every internet forum regarding PC hardware have hundreds of posts about RAM issues for Ryzen.
Makes me wonder where all this false hype regarding AMD & Ryzen is coming from.
This.The Asus B350 Strix is an excellent board for Ryzen
