How do you know they had faulty memory chips? Did you get a report from the repair/RMA centre, or are you just assuming?
Did the cards only become faulty after you removed the stock thermal solution and fitted waterblocks?
are you guys setting state 6 as the minimum state in Wattman when gaming or benching?
Disable Relive?Does anyone have a problem with the load sitting at 100% even when it isn't under load?
Interesting that - I just wonder is it happening all the time or not? Or if this affects Vega 64 in the same manner? Mine certainly behaved as if it was applying the overclocks: I saw noticeable and proportionate gains in scores up to 1907 and 1075 and experienced crashes and artefacts when I went any higher than that. I guess we'll find out when they address it with the next driver release. I'm going to run some benchmarks at stock to compare...
Looking at the graphics score it's a near 8% increase at 1907/1075 compared to stock vs a 9% increase on the core clock. Anything higher on either the core or memory clocks caused Time Spy to either artefact or crash for me. Based on these scores, I don't think I have encountered the bug and believe my overclock is genuine.
Ok so here are my Time Spy scores, starting from the default Balanced and Turbo profiles and then my overclocks. Each one clearly shows a proportionate performance increase:
Core:1668/1750 (balanced) - HBM: 945 - Total Score: 7130 - Graphics Score: 7490
Core:1750 (turbo) - HBM: 945 - Total Score: 7231 - Graphics Score: 7610
Core:1837 (custom) - HBM: 1050 - Total Score: 7339 - Graphics Score: 7844
Core:1882 (custom) - HBM: 1075 - Total Score: 7479 - Graphics Score: 7872
Core:1907 (custom) - HBM: 1075 - Total Score: 7599 - Graphics Score: 8062
I did see one incident of that happening; with 10% frequency on the core clock (1917 I think it was), I managed to run Time Spy but you could clearly see there were artefacts and things missing although the overall score dropped to circa 5500. I've watched Time Spy each time I ran it and the scores are definitely legitimate although whilst I've been able to replicate the same scores for the balanced and turbo profiles I'm falling just short of 8000 on the graphics score for my top clock in retesting this morning...Yeah but according to haircut 2000 (<--- Credit to Gerard for the nickname lol) if you are seeing higher scores it is because the benchmark is corrupting and not rendering everything... I can't give any personal feedback of course, but I wouldn't be surprised if this not entirely true and I do believe that the 64 LCs are doing 1900+ mhz and rendering correctly, the LC users will have to give some feedback on that. It's just that you have to watch out that the clocks are really being applied, his snarky delivery and clickbaity thumbnail/title is somewhat misleading I think, but time will tell.
