18 core plenty of oc headroom on good quality water. It's kicking batty!!!
Can you show any clocks / results yet?
When you say "good quality water", do you mean an all in one cooler is good enough or full custom water loop required?18 core plenty of oc headroom on good quality water. It's kicking batty!!!
7960x outperforms 1950x by 3% for 60% extra cost, what a bargain!
If theyr're using thermal paste it doesn't really matter what cooling you throw at it the limitation is the transfer of heat between the die and the heatspreader.
They are paste.i delided them!!
The better the cooling the better the oc you can achieve. Even better water cool vrm too if your able. All improves the clocks.
What is the non overclocked performance like compared to threadripper non overclocked?And..... We delid no problem!!!
Overclocking, Imc etc is strong.
Nda man. I can't discuss that at all.
Who would buy an X chip and not oc. Not many at all. If they want that they buy Xeon.
I bet it comes in a #### box too![]()
