I'll check for you and update later.
A further update on the system -
-> 1920x with a 4.0Ghz overclock, cooled via Kraken X52
-> 3333Mhz memory @ Cas 16
-> 1080 FE in SLI
A buttery smooth but with a couple of questions / issues -
1. SLI, when using a non SLI game i.e. world of warcraft the FPS will suddenly half every few seconds even when I've set the game to a single GPU in the Nvidia CP, disabling SLI in CP and the game is fine. SLI games work well in SLI i.e. Doom. I suspect this is a BIOS issue but I'll pop up a separate post asking other X399 users.
2. In terms of memory would 3333 @ CAS16 be as good as 3200 @ CAS14? I suspect there is no perceivable difference
Point 2 didn't turn out to be SLI at all but memory / overclock issues - cinebench also crashed. So starting from the ground up -
-> Tested memory with no o/clock - all the way up to 3466 just using the auto settings, pretty sure 3600 should be achievable.
-> Started the CPU overclocking and things started going wrong, so by process a loooong process of testing the following combinations seem to be available (no real tweaking just auto setting and memory voltage increases) -
1. 3.50Ghz CPU / 3466Mhz memory
2. 3.70Ghz CPU / 3333Mhz memory
2. 3.80Ghz CPU / 3200Mhz memory
I've settled on a conservative 3.70Ghz CPU / 3200Mhz memory for now to test things for a few weeks, I'd consider this a benchmark from which things can improve from.
Aida64 @ 3200Mhz cas16 / 3.70Ghz CPU
Memory read 79144MB/s
Memory write 91549MB/s
Memory latency 97.9ns
Cinebench 2374
