Hi,
Case: Fractal Design Define R4
GPU: EVGA Nvidia GeForce GTX 770 Superclocked 2GB GDDR5 Graphics Card
CPU: i5-4670K
The pain: Currently i have a bulky air cooling for CPU and stock Evga cooling for the GTX, The case has
* 2 front facing fans
* 1 rear facing fan
* 1 top facing fan
* 1 side faxing fan on the case sliding panel
Its about 3 years old and there is creaking and noise from all the fans. Been considering replacing ... but under load it is still quite loud also the internals look like a nightmare from hell.
Is there something ready build that can cover both CPU and GPU cooling with one thing for both ? Is there anyway i can set it up in a way that everything is nice and cool with minimal fans.
I am relatively educated in terms of how to do general stuff. (always build my own pcs etc. and maintained them. ) However WC is way out of my comfort zone.
Also for custom work i simply do not have the vision/imagination. Tried looking for someone that will take the case clean it up. Install WC and make it nice and clean but couldn't find any such person/service around London
So off i go doing on my own. If someone can recommend something good that is a pre bundled package would be great.
Or if someone is willing and has the time to list me items i should buy and then guide me ... i am not going to say no to that as well.
I have read some of the guides and used google but .. it left me more confused than when i started so decided to just ask and see if some good soul will help.
Regards,
Atk
CPU: i5-4670K
* 1 rear facing fan
* 1 top facing fan
Regards,
Atk
