Caporegime
- 18 Oct 2002
It's the Cryorig C7.
Great, thanks Chug.
We are already discussing the next step, Kevin has some awesome ideas. Without putting pressure on him I would think possibly late Q4/early Q1...
A compact M-ATX case sounds good, I'm very keen on the HTPC aspect/low profile case, but if possible I want to avoid PCIe risers.
Wouldn't it get toastie for the components in that case
The system is practically silent during idle
Me too, I'm considering getting this right now. I'm just worried about being limited to 7 inch cards in the future.I also value this. Don't mind as much during gaming (as long as it's not nuts), as a headset can be worn
Coffee Lake is due out later this year, definitely hope that OcUK @ChugNorris update the system platform once it is as it'll be an absolute cracker!! And a system for years to come when paired with a Ti
I'll certainly be waiting for it, half made up my mind to buy a pre-built for the first time ever!!![]()
Would love to hear what you think once you receive itJust bought this system with the 1080 Ti
Looking forward to getting it. It will be my first SFF PC.
Just waiting nowWould love to hear what you think once you receive it
Yes the Kube case is about 30mm longer, 2mm higher and 15mm wider making it just under 9 litres.Just waiting now
Is the KUBE bigger than the LZ7? I've read that the 1080 Ti Mini doesn't fit in the LZ7.
Gigabytes gtx 1080 starts production next week (week 35) from media releases , should be able to allow bit more power from the LZ7![]()
