hi there..
i have this problem and i tried to fix it for 2 days.
i tried to install windows 10 and it freeze while installing.. tried different version, different flash memory, different usb port.
tried to install it on M.2 960 pro also tried on samsung 930 pro sata.. same problem
updated the bios to 702 also tried one slot memory and test the memory with memok and memetest
no problem found.
my computer parts:
asus rog vi apex (bought it from here)
7900x (bought it from here)
4x8 gskill 3600c16
m.2 512 960 pro + 930 pro ssd
amd 290x also tried nvdia 1050
ax 850 corsair power supply
custom wc 560 rad temp inside bios is reporting low around 35 idle.. amb 23c.
any suggestion or help are welcome .. its maybe there is some setting in the bios that i donno
no problem found.
my computer parts:
4x8 gskill 3600c16
