- 25 Nov 2005
As the title says which is the best for gaming ? Not too fussed on size, I'm currently using a 24" which fits fine on my desk could probably fit another few inches
Can't go wrong with the Dell.
Indeed. I also have an Asus PG278QR which is a very good monitor as well but the Dell has that special factor.Dell S2417DG... such a gem of a monitor. love it and im not using any windows scaling.
Care to elaborate what makes it special ?
Seems like you're all pretty unanimous on the Dell though, thanks for the replies
http://wecravegamestoo.com/forums/monitor-reviews-discussion/15713-best-144hz-240hz-monitors.html
I found the above link earlier today while on reddit. Which should give you some more in sight into what you are looking for.
It's worth looking on this sub reddit for info here also. https://www.reddit.com/r/Monitors/
I used the same site for reference when i bought mine, the 24" is 165hz but I wanted something bigger. 27" seems to be sweat spot for 1440p.Thanks it seems the 27" is worse than the 24"
I wouldn't go near a TN panel monitor, that Dell would be straight out of the window.
