Just post back if you get into problems - but it sounds like your Dad is clued up.I have no idea what anything you just said means...
I'm sure my dad can help me anyway...
thanks for the info!The fact you have a 1gb graphics card that's not the strongest anymore as such is your weak link along with the power supply, you might need more than 8gb ram.
Your i5 would still suffice for today's gaming, not exactly that old if you think about it, but whether it's fact it's Radeon or the games better with nvidia, your 1gb vram is killer and this is coming from someone who doesn't care about having big vram, but has experienced it many times, thay PUGB might be more demanding that GTA V?.
Anyways i noticed people have listed builds, so if you want new then go with whoever has the best, 6 core ryzen, 16gb ram, gtx 1060 6gb should do the job
Are you sure that this case will fit all of these components in it? Not that i doubt your build, just that i want to be sure before i order it. Also would i need to buy anything extra such as wiring etc?Just post back if you get into problems - but it sounds like your Dad is clued up.
Yep, case supports max gfx card 320mm and the Gigabyte is 285mm.Are you sure that this case will fit all of these components in it? Not that i doubt your build, just that i want to be sure before i order it. Also would i need to buy anything extra such as wiring etc?
thanks so much for all your help. My dad said we're gonna start ordering parts tomorrow in hopes it will all arrive for my birthday. I'll report back to you if I run into any trouble, thanks again chiefYep, case supports max gfx card 320mm and the Gigabyte is 285mm.
Everything else is standard. But be aware you can only attach an external optical drive (DVD-R drive) if you plan on using one. But all games can be bought digitally - and all new ones are.
No worries - i'll stay subscribed to thread.thanks so much for all your help. My dad said we're gonna start ordering parts tomorrow in hopes it will all arrive for my birthday. I'll report back to you if I run into any trouble, thanks again chief![]()
Hey @Journey@Plec Just wondering if you think the Gigabyte GTX 1070 is worth it against the Palit card? They are pretty much specification in terms of cooling set up, the Palit is only £389, so £30 less and is in stock, the Gigabyte is out of stock until at least 22nd Sept. If he changes this then it would allow him to get the AMAZING 8 Pack Ryzen bundle, with the R5 1600, 16GB of the same RAM, but will have the Taichi board, yes I know he'll then need a full size case. It works out approximately the same cost.
My basket at Overclockers UK:
- 1 x 8Pack Approved - Elite Tier Ryzen 5 Asrock Bundle: AMD 1600 @ 3.90GHz = £423.97
- CPU Cooler:Unwanted
- Memory:Team Group Dark T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TDGED416G300
- 1 x Palit GeForce GTX 1070 Dual 8192MB GDDR5 PCI-Express Graphics Card= £389.99
. But as you noted in your previous post he has a Zalman Z3 so your amendment could be applied if Luke wants to consider it...That's what i was afraid of - was good while it lasted...I think they were not making enough margin on it, when dropping the cooler, so stopped you from removing it.
Yes, my dad has build a PC before with similar budget. And again yes, I have an Ethernet cable running to my PC.Just wondering, have either one of you build a PC before, since you mentioned earlier you were not sure about adding parts to your current build, since you "might not get past all the wires" The Zalman case you currently have is reasonably spacious, and if you are worried about adding parts, how can you be confident building a new system? I am not tryig to put you off, but depending on where you live you may find a friendly OCUK'er willing to help you who has much more experience.
Also, one question about your gaming setup, are you running Ethernet cable from the router or running WI-FI?
Thanks a lot!Awesome, I hope you have fun building it, and then using it.![]()
About what you said here ; what exactly do you mean by "flash the bios". Because the only place I recognize "Bios" from is from pressing one of the function buttons during startup on my PC, but even then i was just folllowing a tutorial to fix a problem I had. If you could explain what you mean by "flash the bios" and what BIOS are in general that would be really helpful!No worries - hope the build goes smoothly.
I always add the following with Ryzen builds:
Ideally with Ryzen builds you would flash the BIOS almost immediately. Once you've established post with a minimal setup - CPU, 1 stick, GFX, keyboard and have established temps/stability seems OK, flash the BIOS.
Install the latest BIOS file to a freshly formatted FAT 32 USB stick and update via the dedicated Q Flash utility as it's a Gigabyte board (hit <end> at post) to flash the BIOS (prep the stick before hand). This will ensure you have maximum memory compatibility - and should ensure you hit 3000MHz (2933MHz) using the XMP.
So im going to order the parts tonight for sure, but i was wondering if there was any last minute discounts or discount codes even if I could just save a few pounds right before I buy it because its the first time ive ever spent this amount of money on something and its a real step up. Any last second discounts or codes you know of I could use??No worries - i'll stay subscribed to thread.
Best if luck and Happy Birthday.
