Cheers, £250 sounds a lot better than £500 It's more of a preventative, and also I'm not sure if it's in my head but low end grunt for me doesn't feel as impressive as it did when I first had the car two years ago, and I'm sure I can feel a surge of power as I get past the 2.5-3k rpm mark.
The DISA Rebuild kit is still on my list of things to do, Suspension stuff can be removed with the MOT only coming back with a worn inner tie rod which has now been replaced with a Lemforder part.
Edit
At 102k Mileage reckon it'll be worth just replacing the DISA valve altogether? I have no history showing it's ever been changed during its life and some posts on forums seem to suggest it'll be worth replacing after 80/90k
I've never heard of a new replacement, but rebuilds are common. Involves replacing the O-ring, flap and pin. The issue is the OEM design pin can work itself loose, and get sucked into the engine. That, and the flap is a brittle plastic so can get damaged. The o ring wears out over time as all seals can do.
From what I see it's a pretty simple diy job to take the old unit out, strip out the old parts mentioned above and replace with uprated components.
