Ok after sorting out the overclocking (done a thread on that) have another problem!
My pre-binned i9 7900x apparently delidded (by overclockers.co.uk) however am getting extremely high temps these are worse then a i9 7900x NOT delidded from what I have seen online.
Basically at 1.11 volts (very low) with a 4.5Ghz overclock am hitting at full load using Aida64 above 90c on some cores
(please see screenshots below.) I am using a AIO cooler the NZXT Kraken x62 280mm Radiator yes, yes I know a 360 is recommend but at 1.11v I should not be hitting over 90c even a non delidded with the same cooler won't hit those temps at that voltage I reckon it would have hit 100c after a while.
Am pretty sure this was delidded but did someone maybe forget to apply the TIM between the die and IHS
