- 15 Sep 2009
- Birmingham
I have at home a Samsung UE40UK6020 TV connected to a Denon AVRX2300W amp that has connected to it a gaming PC, nvidia Shield, blu ray player and new VM TV box
All are connected up with brand new Amazon HDMI cables
Initially I had problems with my PC where I'd be playing a game and the audio would drop out (image would still show on the TV) Tested a spare Amazon HDMI cable and it solved the problem so bought a batch load and since then, no issues with the audio
Next issue was the TV screen turning itself off whilst gaming, I'd turn back on manually and several minutes later. Turn itself off again... this turned out to be a memory setting in the BIOS so since made that change all OK
However, TV turning itself off problem has now moved to the Virgin Media box. TV V6 box arrived yesterday and connected up, no problems and works fine. After a while and again this morning, the TV would keep turning itself off. You can still hear the audio and if I use the remote to 'try' and navigate the VM box, you can hear the Tivo beeps
Any ideas what could be causing this? All eco settings on the TV are off and no signs of any standby options. TV is also running the latest software / firmware
