I don't think they are doing it right. For a start blobs or lines work fine if you apply one to GPU and one each to the HBM chips. I'm doing far better than their results in percentages with a 56 under a G10 bracket with a NZXT X41 140mm in push pull.http://www.tomshardware.co.uk/radeon-rx-vega-64-water-cooling,review-33986-2.html
Tomshardware used it when they were snubbed an acutal liquid Vega.
alphacool have had 10-11 days timer on the 120 for a couple of days and the 240 version no date.
What psu you using? Make and modelI seem to be having a few issues with my new V64. I got it today and fitted it and am having intermittent reboots. The monitor will go into standby and the system will reboot.
I've stuck my CPU to stock and it's made no difference, however my system has been rock solid for about a year. I managed to play Doom for about an hour with no crashes, then it rebooted several times browsing the web afterwards. I fired up Doom again and it crashed but now it's been on for 15mins on the desktop. There doesn't seem to be any recurring theme to it, it will crash if it's stressed or not.
buttery smooth gameplay, GPU not even sweating.
Stop it you're making me want to buy one but I refuse to pay £800 for a Vega 64 AIO.
Could you get close to liquid performance on air? With the vega 56, what voltage and clocks etc.Seeing as how you can get v64 liquid performance out of v56 without too much trouble i am not sure why anyone is spending 800 notes on it![]()
I did a clean install of the drivers, but didn't clear out the old ones. There is nothing in the Event Viewer, just logs when it starts back up and I'm using two separate cables already. It's annoying as it worked fine for an hour or so when I first installed it playing a game!
I'll have another play tonight, clear out the drivers etc and see what it does.
