Multi Monitor with new + old GPU's
20 Aug 2008
I have a R9 290 that I use to run my 144hz monitor
I also have a very old ATI 3450 GPU that I would like to use to run my two old VGA monitors. I have installed the latest drivers for the 290 and the older drivers for the 3450, but this does not work.
Any body have any experience with this?
I think the problem you'll have is that newer AMD drivers don't support the old 3450, and older AMD drivers that do won't support the 290. If you can find a driver that supports both, it'll work but I don't think you will.
Weirdly, this will work fine if you mix an AMD card and an Nvidia one (or an AMD/Nvidia with an Intel on-board GPU) because AMD & Nvidia drivers can in theory co-exist since Vista was released, but you can't install two different AMD drivers because one will overwrite the other.
Exactly this - the newer drivers don't have support for cards older than Radeon 7xxx series, and trying to install 2 different sets of Radeon drivers will likely lead to problems even with your 290X.
If you have Intel onboard, then that should support 1 VGA display, and the 290X should support 1 via a DVI-VGA adapter.
I’m using my 1070 with 3 monitors in Nvidia surround and my intel onboard graphics driving a 4th old school vga monitor, couldn’t get the 1070 to drive a forth monitor for love nor money with surround enabled on the other three, hope this kind of helps?
