Passat projector lens LED retrofit
Judging from these responses, is it safe to assume that most LED H7 retrofit bulbs are dodgy no matter the price?
Im guessing HID kits are more acceptable compared to LED in regards to retrofitting?
Legality of them for road use seems even more of a grey area than when HID retrofit kits first appeared, so the market consists pretty much entirely of non type approved Chinese knock off stuff.
If they were halfway legit then you'd have bulb companies like Philips, Osram etc. actually producing the bulbs themselves.
Are aftermarket hid legal? Seems a grey area. Another plus for led, is the fact is a bumper off and head lamp unit out to change bulbs so fit and forget would be great.
How about this https://www.powerbulbs.com/product/philips-x-treme-ultinon-led-headlamp-h7
Also appears from Philips AU website https://www.philips.com.au/c-p/12985BWX2/x-treme-ultinon-led-car-headlight-bulb
EDIT: Nevermind. Just saw the warning not suitable for public roads. But it seems Philips actually make headlights LED for H7 socket but not for public roads.
All of these crappy websites selling this sort of thing are full of total ******** information. For example on the powerbulbs website they list the wattage as 1-2W...yeah, per individual LED maybe, but for the replacement lamp itself it's going to be ~15-17W.
Also notice how the Philips specification is MUCH more believable than the tosh from that other company: 1760lm (with the same size heat sink as the other crowd of bull**** merchants claiming 4000lm) As you also saw Philips highlight that these are not road legal.
As I said before I wouldn't touch a LED retrofit lamp for this application with a barge pole.
It's a grey area for LED too though. With HID you know the lumens stated will be pretty accurate. I had them in my civic ep3 and my friend has them in his Fiesta, both with halogen projectors and neither of us had any issue passing an mot test.
35w hid bulbs are about 3000lm iirc, so almost 2000 brighter than the 1000/1350lm of those Phillips at powerbulbs and about £100 cheaper.
Well the NightEye LED from the bay @ £20 has arrived. Will fit tomorrow on the Passat and see how it goes.
If it is crap then I will switch back to halogen and rethink the HID bulbs.
Some pics of the NightEye
Box:
Contents:
LED 1:
LED 2:
LED 3: Tried to clearer shot but it could not get the tiny details within the yellow bit of the chip. It has fine lines within the center part of the yellow lines.
Cooling Fan:
Removable H7 Bracket:
Installation Manual for H7/H4:
Thanks. I predict you'll like them and everyone driving towards you at night will hate you.
The fine lines you can see under the yellow part (that's the phosphor coating which converts blue light to "white" light) is probably the edges of the LED die themselves.
Haha :D
Even with projector type head lights? Hopefully not after checking the pattern and alignment level check.
no grey area at all https://www.gov.uk/government/publications/aftermarket-hid-headlamps
In the Department for Transport's (DfT) view it is not legalto sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps
yes, you will pass MOT as they're not checked (assuming spread pattern is ok), but they're still illegal - which you should obviously know about when driving with such a mod.
I would guess similar statements will start to appear for aftermarket LED kits (if they don't already).
Whether the kits are "legal" or not, presumably a traffic officer could grip you for them not being e-marked anyway? That LED kit, linked by the OP, says "the design around E4 certificated (E-Mark) halogen bulbs" - so, to me, that says they're no actually e-marked themselves, just copied the design from one.
actually, as of 2012 MOT changes, it looks like they could/should fail MOT, as the light's washers and self-leveling mechanism are meant to be checked http://www.ukmot.com/manual/1.7/Headlamps. Even if you have washers on the lights and a self-leveling mechanism then they're still not e-marked ;) So, all depends how thorough the MOT tester is...
UKMOT.com said:
Vehicles equipped with High Intensity Discharge HID or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work
May be fitted, not MUST be fitted.
Reason thats there is that some early HID cars didnt have washers.
Only thing stopping me trying LED is i don't want to screw up the beam pattern. People that drive around blinding people need to crash into a concrete wall.
Not sure to be honest. So far Ive seen differences in the following:
LED chip: Cree, Bridgelux, Lumileds
Cooling: Passive and active with Fan ranging from 5000 - 12000 rpm
PnP: Some do not require resistors for dash light warning
Lifespan: 20k to 50k hours
Looks: Some looks like a normal halogen without the filament/glass while others are like LED flashlights.
I find very confusing to be honest. So many choices.
Just as a comparison - my LED (stock) are passive, and are 'lifetime' for the car (i.e. at least 3 years).
Mine has a lot of LEDs as standard i just hope any units are easy to get into should any LEDs pop, can replace them with something a bit brighter then.
