Flashing Bios from a different motherboard? Asus p8h61-i
26 Nov 2015
Derby
any experts on bios here?
I bought Asus motherboard on ebay. It's OEM board from an RM machine.
motherboard is marked as ASUS P8H61-I/RM/SI ... it works fine with me i5 2400s but when i put an Ivy bridge CPU it doesn't work because it requires newer bios.
RM education doesn't provide any new bioses for this mobo. Asus does have a bios from 2013 but when I try to flash it in EZ Flash it says integrity check failed...
that RM motherboard looks exactly the same .. its just missing a HDMI and 2 usb ports...
is it possible to force flash a bios from P8H61-I and get support for newer CPUs? or it will kill the board
https://www.asus.com/us/Motherboards/P8H61I/
https://www.asus.com/media/global/products/nT9c3CJq6itMyvuE/ttSJKUHeJXg95OT0_500.jpg
** Do Not Hotlink Images **
i appreciate your help.. but could you explain to me what you did with that bios? I really don't want to brick this board
EZ Flash says "selected file is not an EFI bios"
Edit: it flashed from fat 32 formated drive but it's still showing same version...
Added ivybridge microcode support to your bios file which you ve uploaded.
Basically your bios only had support for sandybridge. See section 7.
Added Ivybridge Microcode
Sandybridge: Microcode 0206A7 - Which is Family 6, External Model 2A, Stepping 7
Ivybridge: Microcode 0306A9 - Which is Family 6, External Model 3A, Stepping 9
As always with any bios flashing, things can go wrong so use it at your own risk.
If you want to go ahead make sure usb disk is formatted as fat32 and bios file is the only file on it and use flash utility in bios itself. If it doesnt work alternatively you can use AMI utilities to flash your bios ( Afudos or Afuwin ) or by using third party bios chip programmers.
Alternatively if you want to read about bios editing or do it yourself see below link for bios modding forums and guides. Good luck.
http://www.win-raid.com/f16-BIOS-Modding-Guides-and-Problems.html
With I7 installed did your board power on at all and no display or was it not starting up at all, just making sure if it also required vbios support or not. If its not powering at all then i am guessing board is not compatible with Ivybridge due to voltage etc...
It may be possible, but there is higher risk using different motherboard bios then using original bios , although they might look a like but it might not be compatible at all. I ll try adding vbios to your file which is video bios for the processor to rule out if it was starting but no video post. Meanwhile if you can check whether your keyboard lights such as numlock or capslock is working when you press those keys after you turn on your pc with I7 installed.
I'll to that tomorrow.. I'll try booting with external gpu and check if keyboard lights are working.. I'll get back to you tomorrow it's to late today.. I need to get up early for work
P. S: I don't know if that has anything to do with the problem but motherboard doesn't post if I set ram to 1600Mhz... 1333 works fine.. As soon as I set the ram to 1600 it doesn't boot. Ram is 1866
Here is another attempt at adding microcode support to your bios file with another method incase previous attempt didnt stick. Its a rar file so uncompress it.
https://drive.google.com/file/d/0B24hTBQxw6SWVXBwZGRsUnRKbmM
Last thing you can check is inspect cpu pins in socket itself to make sure there are no bend pins considering this is removed from a RM machines. Alternatively you can force flash Asus bios unless you are ok with the risks by making a bootable usb freedos and using Afudos utility. Let me know how it goes...
If that doesn't work there is one other thing you could try. Asus still use removeable bios chips on their boards so although I can't see yours (it's behind the cmos battery) it should be the same as the board above. You could go on Ebay and pick up a bios chip for the P8H61-I which has been flashed to the latest bios and swap it over with your boards chip. That way if it bricks the board all you have to do is swap your own bios chip back. Cost would be less than a tenner.
