- 2 Aug 2016
- Third Earth
Aside from the dual AIO's you haven't been supplied with the Gigabyte AIO GFX, assuming that's what you ordered.
You already mentioned the two coolers so otherwise without knowing your final order nothing else stands out.
Damn forgot I wrote that.. Its been a long couple of days.
I decided against the Gigabyte AIO GFX in the end.
But to add the "Cockups" I could have got away with 140mm fans but clicked 120mm. Luckily I can use them in my server. I just need 3 more 140mm so I can push pull the AIO
The BeQuiet AIO in your pic uses 120mm fans though as it is a 360mm (3 x120mm)
It does but the case is just screaming out for 3x140 in the top. Unless thats going to cause some sort of turbulence issues.
To be honest its sat at 27deg idle at the moment max 43deg and the M.2@ 33deg max 35 during windows install so its running cool so far.
Although not done any stress testing yet.
