Damn forgot I wrote that.. Its been a long couple of days.
I decided against the Gigabyte AIO GFX in the end.
But to add the "Cockups" I could have got away with 140mm fans but clicked 120mm. Luckily I can use them in my server. I just need 3 more 140mm so I can push pull the AIO
As from my pic , just run push pull for an over the top effect .
Also the silent loop is simi modular- it can be taken apart (need fingers of a god) and parts added changed - although full warranty is removed - believe it's alphacools unit that warranty carries over to adding in parts .
Replace the rad with 420 version, either Alphacool or other -brand.
Then add Phanteks halo fan covers for some RGB goodness
