If you really are wanting to go full retard I'd go with a volt modded Titan a ask 8 pack for a 5.4Ghz 6700/7700k all wrapped up in the best water loop. That's the only way to cut above anyone else and garrenteed 144Hz+ gaming for a while. Just don't try and stream at the same time.
Actually switched from 6700K @ 4.9Ghz to 6800K @ 4Ghz because I want to play games, while streaming radio and using TS
The fps is better, everything smoother and doesn't "semi crash" the system every time using alt+tab.....
