- 14 Jun 2014
- Dublin
Very nice Tony. Undervolting is working wonders for my "stress testing". I'll be pulling the Ryzen machine apart tomorrow to install the Eisbaer so with luck will have some good results to post after that.
Edit:
One other interesting thing, using WHQL 17.9.3. On my 2 x 290x machine, CF enabled, I see 1 x control panel (AA, tessellation etc) and two Wattman panels, one for each card. On the 2 x V64 machine, I only see one of each, CF is enabled and working though.
It would be nice to be able to control each card's power/volts etc. independently as one may have worse RAM etc.
Anyone else seeing this or do those with 2 cards see two Wattman panels?
Additionally, the 2nd card (without a Wattman) is showing it's getting about 780mV when the other is getting the 950mV set in Wattman per GPU-z.
I suspect the CF/mGPU is still a bit immature. It looks like they may be trying to merge multiple cards to appear as one large one, which would be cool if it can be pulled off properly.
Edit:
