- 10 Oct 2006
I'm pretty sure that the Mk5 GTi uses the same 2.0TFSI engine that's in my Leon, and it's a cambelt and pulley system rather than chain.
At 109k miles though, it will be due a new belt, tensioner and waterpump soon.
The engine has both a chain and belt, the timing belt is on the left and a chain links the two cams on the right. It is a fairly common fault for the chain tensioner to fail causing a rattle once the engine is at running temperature.
If you are going for preventative maintenance you should change the blow off valve, cam follower and PVC valve all cheap and straight forward to replace.
