What rock is this ? Any Geologists here
Caporegime
24 Dec 2005
Autonomy
I want to be able to identify it as I want to use it in my waterfall or pond if possible.
Quartzite or Limestone?
Difficult to tell with those images.
Can you scratch it with a pen knife. If you can it's probably predominantly calcite and possibly a Limestone of some kind. If not then its possibly made of quartz and may be a Quarzite.
If you can take an unblurry close up it may help.
sandstone
quartzite
limestone
something with a lot of calcy/quartz cement
spray it with acid and smack the crap out of it with a hammer*
*won't look good in fishtank then
