Hello All,
I am looking for any hints or tips regarding my graphics card, which I think I may be broken. This is the card:
https://www.overclockers.co.uk/b-gr...graphics-card-retail-all-white-bg-028-kf.html
I purchased the card from overclockers just over four years ago, warranty long gone.
Initial problem:
During gaming the screen started to behave strange, odd shapes appearing etc then eventually it would crash. I initially put this down to the game so I started the game again same thing only this time blue vertical lines started to appear on the screen and then a major crash. When the system was restored a pop up from windows appeared stating some kernel driver had failed but was restored and there was a number something 387.??. Annoyed I didn't record this.
Eventually this stopped for a while then whilst doing nothing blue squares started to appear on the screen so I knew something was wrong.
What I have done so far:
Last night updated to the very latest drivers.
Today I gave the whole PC a tidy out it was a bit dusty but nothing severe. This included removing the card and making sure there was no dust in the PCI slot etc.
After this I managed to get a picture on the monitor but it also had blue vertical lines and it was almost like safe mode for example the resolution was 800 x 600 and I couldn't change that.
I am going to borrow another cable tomorrow to try that out but I doubt that will be the problem.
Other than that it only leaves two possibilities either the card is knackered or my slot on the motherboard is broken.
I am going to try again tomorrow but would anyone have any other suggestions that might be worth trying? I cant really think of anything at the moment.
As always any help at all would really be appreciated.
Initial problem:
. I haven't really had a chance to test my existing 780GTX card although I am fairly certain its done. My budget hasn't changed much, could maybe push to £200. As before I wont be buying second hand. What's the best card for £200. Gaming wise it hasn't changed total war games mostly, although I would like to play GTA5. Does anyone have any thoughts?
