Caporegime
- 18 Oct 2002
Nvidia wiping the with floor with AMD....
An overstatement, and probably easily rectified with optimised drivers.
wasn't being in slightest bit serious, just something someone said that makes me chuckleAn overstatement, and probably easily rectified with optimised drivers.
wasn't being in slightest bit serious, just something someone said that makes me chuckle![]()
Actually this is how AMD cards pretty much performed in the previous AC, they were much slower than NVIDIA as well:
http://gamegpu.com/action-/-fps-/-tps/assassin-s-creed-syndicate-test-gpu-2015.html
http://www.pcgameshardware.de/Gefor...afikkarte-265855/Tests/Test-Review-1222421/2/
https://www.computerbase.de/2016-08...#diagramm-assassins-creed-syndicate-1920-1080
Amd have always performed quite bad vs nvidia in these games. They use heavy amount of NVidia gameworks tech that massively favour nvidia.
AMD console game, running terrible on AMD gfx cards on the PC, who'd have thought![]()
I am very surprised how well amd is doing in this newer game.
Ermmm?> The Console has never had the PC gaming Feature!! lol Hell even still the Console versions in the past have had issues with Frame rate! Its just a poor engine and only does well on PC because of Brute force...
You can't have it both ways man, it's either AMD will go great guns on PC now because of porting or it's a **** engine
Tbf, AMD are at their strongest when the game is programmed to the better open standards![]()
When you have a PC version ridden with Nvidia code amd is going to struggle..
So you're basically refuting your earlier comments of 'AMD in consoles is good for their PC graphics'? That's a bit of a blanket statement, and AssCreed has proven it wrong.
DirectX 12 and Vulkan is what matters for AMD and developers.
Remember guys, NVidia can do no rightAMD = Angels sent from heaven
