https://broadspeed.com/new_cars/Skoda/Octavia/Choose_Number_Of_Doors/Estate/
I didn't realise they do a 230 and a 245. What is the point in that?
I think I'll just stick with the Leon, it's got an extra 45bhp, 4wd, DCC as standard, not bad for an extra £30 or so a month.
The only thing I'd like it to have is the newer 7 speed DSG that the Octavia gets, but I'm sure I can live with 6 gears.
How long is the wait?
Bentley is part of VAG so will be shared with Audi/Porsche etc.
As others have mentioned it isn't just the power upgrade. It's essentially the performance pack to the Golf GTI but on an Octavia VRS. Additional standard kit, bigger rear brakes, VAQ diff, and the option of the 7 speed wet clutch DSG. 230 only gets the older 6 speed.
Unfortunately Skoda have ruined the appeal by limiting you to boring colours if you take the 245...
they also bump the spec to electric alcantara front seats and i think you get front and rear parking sensors as standardAs others have mentioned it isn't just the power upgrade. It's essentially the performance pack to the Golf GTI but on an Octavia VRS. Additional standard kit, bigger rear brakes, VAQ diff, and the option of the 7 speed wet clutch DSG. 230 only gets the older 6 speed.
A good summary, I think the interior is also nicer as well.
My mrs doesn't really care what she drives as long as it's an auto (we are both DSG converts and wouldn't go back to a manual) but her only other requirement is that the car isn't red. She came around to red on the VRS 245 as it works quite nicely with the black trim, but I'm tempted to surprise her by changing my order to meteor grey for an extra £16 per month.
Part of me thinks no, it's not worth it and makes the deal worse. But on the other hand I think she would really like it. Tough choice![]()
I went for the 245 deal
£199 Fee
£226 down and 23 x £226
Keeping the C63 the Skoda is our second car...
Factory order though and seems like there is a longgggg waiting time on them.
As Fox said, I was pretty happy with how the car was standard so kept it that way as adding options seems to take away the 'value' aspect of it..
Where did you order that from?
