- 18 May 2010
Hi all,
Bit of an issue on the way to work this morning and it got me thinking who was in the wrong, never usually have problems on the road as its such a short commute and full of traffic so its rattled me a bit and also got me thinking who was in the wrong.
There is a roundabout with no left turn, you can either go straight on or right, straight on just takes you back on the motorway you just exited. Its a bit of a strange one because the left hand lane you can either use to go straight on or right without the need to change lanes, I am in this lane.
The right hand lane obviously you can use to turn right but you have to merge with the left hand lane, there is a bus in this lane.
The bus and I set off at the same time and as we both pass the straight on exit the bus assumes I have gone straight on and moves into the left hand lane, no indication, didn't check the lane just literally went to squash me into the kerb, there was no accident I was aware of the bus and managed to stop in time. The bus then continues to move into the left lane and carries on with me behind and I must admit for the first time in a long time I provided some gestures I haven't used in a while, maybe in vein because was it my fault for going right in the left lane or the buses for changing lanes without checking?
Your opinions OCUK motors?
