Two monitors on an AMD ASUS A68HM PLUS Socket FM+ motherboard
27 Feb 2004
Kent
hello,
This m/board has built in DVI And HDMI outputs on the on board graphics processor. I have only ever used 1 monitor.
I have given this to my daughter and she says she needs 2 monitors when she works at home - for viewing spreadsheets, documents at the same time. Can I just plug 2 monitors into these sockets or do I need to buy a pci express graphics card with provision for connecting (say) 2 x DVI monitors at the same time.
Thanks, Mel
The processor is AMD A6 6400K A6 APU Black Edition
Clock Speed 3.90GHz
Graphics Chipset Integrated AMD RADEON HD 8470D
1 x DVI
1 x D sub
1 x HDMI
Can I just connect one monitor to the DVI (as now) and an additional one to the HDMI port?
I think dual graphics as in crossfire support which is a no. I believe dvi + D sub or hdmi + d sub might work,from past experience hdmi and dvi are both digital using same connector or resource in graphic processor so we could only use one port between those two.
Can I buy a graphics card with output for 2 monitors and put this in the PCI-Express slot and run 2 monitors that way - bypassing the on-board graphics capability?
Or buy a graphics board with one DVI output and plug one monitor into the on-board DVI outlet and the other into the graphics board outlet? Or does installing a graphics board disable the on board graphics?
Thanks.
That APU + motherboard can run two monitors fine. No need to spend the extra on a discrete GPU.
Thanks - is that from personal experience? Or some other info I / others have failed to find? Anyway I will take my small TV which has HDMI and VGA input to try with the existing DVI monitor next time I go to my Daughter's.
From experience. All APUs/IGPs I've seen so far can run a minimum of two monitors. I had an older A6 APU that could do dual monitors with no issues.
