Xbox One X
It's theft either way, just my opinion.
If the carrier leaves it and it's stolen then fair play, you are entitled to a refund or a replacement.
If the carrier has left it and you receive it then it's not ideal but no harm done.
Making a false claim of not receiving something you have is stealing basically.
Anyway enough of that as it will simply derail the thread.
I wouldn't deal with you in the members market though!
not many USB ports :(
my ports are already filled
1 x Kinect
1x 4TB drive
1 x free but gets used for the Lego dimensions base and Guitar hero adapters , knackered if we want to use 2 guitar controllers
Just plug a usb hub into one of the rear ports, was doing the same on my old xbox one x, justed plugged it into the X and all is working fine.
I have got the Microsoft tv tuner thing plugged into the first rear usb port & the hub plugged into the second.
I keep the front port for the play & charge cable.
Cheers all
In video settings there is something called YCC 422, its unticked by default should I tick it?
It sounds like something needed for 4k sets, bit like YUV422 on the pro.
Thanks
Yes its works fine going from one external to another, I transferred over from a 1TB external directly to a 4TB external without any issues at all.
Cheers all
There is also an app you can use so you can make the drive seen in windows and copy drive to drive that way. I had to do this since I flogged my S and wanted to go from a 1TB to 5.
Cheers all
USB3 hub I assume?
I'm sure xbox will only support 2x external hard drive?
After messing about for 1 day, I'm pretty happy with everything.
I wish they do a sale on a few older games I've missed over the years.
I have both s and x next to each other and it's crazy how s is louder.
So the AC origins game with X enhancements is around 43gb and some games like Forza 7 are around 100gb with X enhancements. How come such a huge difference?
One game got 4k textures and other one not?
Talking about a car game with 700 detailed models and tracks, against a open world game.
I did as well, I cancelled in the end and went elsewhere, standard version instead, should be arriving in a short while.
Was messed about to much by there customer support telling me lies so felt I should take my cash elsewhere, lost out on the Scorpio edition mind you, but Im not that bothered.
Mine arrived today. I was tempted to cancel but I did want the scorpio edition :D
Do games automatically download the enhanced updates?
Yeah that's it, found out its because it does not have the extra textures, apparently the textures are same across all versions.
Nice one, enjoy.
Its a lovely console, love the compact design.
I think they do, Im installing AC origins, apparently that game is only around 43gb as it does not use extra 4k textures.
