- 6 Jan 2013
- Rollergirl
Warning: this project probably won't be much to look at, it's more about the best way to set things up for optimal cooling etc.. (I know, yawn
Something I've wanted to do for a while is have a system that's full custom water cooled, but have the cooling separate from the room I'm using the PC in. Because over time I've realised that even with water cooling, the heat has to go somewhere. I really noticed this when I moved house as my system is in an office downstairs, and while the office is plenty big for a PC system I've really noticed the heat build up from the radiator fans and particular with VR the room gets really toasty (I don't think the foam headset helps).
Luckily, my office is adjacent to my garage so I have some interesting options.
I originally planned to use an external radiator by an open window, and while I was seeking some advice on the best way to do this (intake versus extract etc..) things just kind of... Well grew arms and legs I suppose.
I'll update the next post with where I've got to so far, and hopefully I can get some advice on the small details in terms of what components to use, how to set up the radiators etc..
)Something I've wanted to do for a while is have a system that's full custom water cooled, but have the cooling separate from the room I'm using the PC in. Because over time I've realised that even with water cooling, the heat has to go somewhere. I really noticed this when I moved house as my system is in an office downstairs, and while the office is plenty big for a PC system I've really noticed the heat build up from the radiator fans and particular with VR the room gets really toasty (I don't think the foam headset helps).
