Need to run PC mark and VR mark and the. Try and get a few more games done , also hoping 1070 Ti will be here next week
Then onto coffee 8400
cool it will be good to see results on the 1070ti to see how it performs. which one u getting?
Got Gigabyte G1 for £410 , but that's if the order will be processed , couldn't resist the order but it's 50/50 to be honest with that site . And RMA is useless with them or non existent so least can be mailed to Gigabyte directly haha
which site
One that compares to big general e-sellers and tries to beat the price . Can't list on here, but if item goes out of stock by someone whom buys directly, you get told after the estimated delivery date is missed then takes ages for a refund :/
Couldn't resist the price , so thought I'd give it a shot, did it once with Asus Strix 1070 and had to RMA the unit, Asus is a pain so can't deal with them directly so took months of fighting to get it sent off :/
Got my eye on this though as a back up
My basket at Overclockers UK:
that's shocking. I just got asus strix 1080ti gonna take cooler off for a water block which will void it' warranty hope it doesn't die
Use pliers ! Use them to remove the screws with stickers on , as for the paint on the screws. If a lot flakes off, just repaint and screw in when semi dry
never thought of that, cheers will have to see if I can get pliers in coz of the back plate
Good set, thin nose type and take your time ! Found laying masking tape around the screw and overhanging the backplate helps, avoids visible scratches
cool i will be like a dentist haha. I carnt wait to get this beast installed.
wud u change the asus back plate for ekwb 1 or not?
You've paid a lot of money for a strix card with RGB, I got Phanteks so I could keep it and plug in RGB. I think now it's easier to mount their block with stock backplate. Keep it !
my 1070 was with a ekwb will look at phantom shud be same temps I guess
Cheers 1070 never went above 40c benchingTemp wise, yeah , but that's all down to your rads and fans technically
Did you test the results at a higher resolution?
Good to see the Vega coming out on top slightly. Will be very interesting to see how the 8400 changes things.
I am very happy with the 1600 I got and in recent reviews it seems overclocked it does hold its own against the 8400 as most other benchmarks have the 1600 at stock.
