Hi guys,
My heating and hot water is currently operated independently using two 24hr time clocks respectively (APT IMM24) which is slightly surprising for a house built in 2000 - but I understand that the previous owner was reliant on a boiler multi fuel stove that he ran 24/7.
I'd like to convert the two 24 hr timers to a more modern setup, and the Hive (Heating plus hot water) is currently on offer from Amazon.
Would anyone please be able to help with the wiring?
This is the wiring diagram below the APT IMM24:
And this I believe are the diagrams for the Hive:
Assuming that the Permanent Live, Permanent Neutral and Earth are self explanatory. I'm assuming that the Live out ( Pin 1 in the top picture) from the IMM24's are essentially Normally Open switched lives, and would just go respectively to 3 and 4 on the 2b diagram?
If so, is anything required in pins 1 and 2 in picture 2b?
Thanks in advance.
Thanks in advance.
