- 17 Jan 2006
I'm in the process of freshening up my kitchen a bit and need to remove the draw/door fronts from my integrated freezer but I'm not quite sure on how to do so.
With the integrated fridge it was simple as there were just screws and brackets that needed to be unscrewed however on the freezer I have what looks like 4 slotted brackets with bolts (2 either side)?
I think I probably need to get them undone using a flat pressed type spanner like you get with bikes etc though I don't know quite what size it would need to be?
Also I have the issue that I can't get to the two brackets on one side as it's close to the wall, would I be right in thinking I'll need to take the door of the freezer right off?
edit, forgot to put up a pic of the bracket I have:
