i dont have the hive system.
will the hive active lights pack be useless for me?
You get a free hive hub as well to go with them, mine turned up yesterday
Thanks
I've not had my boiler serviced for.......about 6 years lol
Maybe the free boiler service is more valuable to me than......automated light system
I currently have Philips Hue lights in my house, so planning just to pop this straight on Ebay, can put it towards some hue motion sensors/dimmer switch that i wanted to get the likes working as i prefer. Thanks OP for the heads up!
**EDIT**
Actually, the hub which is included with this kit, is this the same hub as for the heating? Might be useful if I decide to go down that route in the future...?
Can I set it to turn the heating down when my GPU temps go up?Yes it's the same hub. My kit arrived yesterday and I'm already planning what other devices I can add to it. Opps![]()
I've got mine installed now, but honestly I'm not sure that I see the point either.
The timer scheduling is a nice idea (I'm using one of the bulbs in my security light by the front door) but you cannot adjust the brightness on a schedule, it automatically comes on at 100% brightness, which is far too bright for outdoors. I have another set up in my lounge but turning it on / off via the Hive app is slow to load and onerous, I'm just using the light switch instead now (and same problem as above, it comes on at 100% brightness straight away).
It will be useful as a security / deterrent when I'm on holiday, but for everything else I can't really see the point.
