Cheers mate. After all the best the GTX1080Ti can do is around 110s at 2560x1440, 100hz monitor 3440x1440 will serve me well for as long as I keep the 1080Ti.
@tyler_jrb  any feedback mate?
Well I'm currently using an X34A now myself. Pixel died on me on my z35p so managed to get a refund from Amazon and the X34A was on sale at £800 over Black Friday so couldn't help myself really.
Kind of to tide me over to the Asus 200hz one if it's any good that is and not like £2000.
Both are great monitors and the Z35p is excellent if you get a good one.
Although it's not without its issues. It overclocks fine and does feel marginally smoother for obvious reasons (100hz vs 120hz) but it's not massive.
The extra inch is pretty nice though just makes it feel a bit taller. Something I do miss on the X34 although it's only an inch
The tight curve was a bit of a problem for me though. Not sure if it's just how it was made but  I have tried 3 and 2 out of the 3 had noticeable screen uniformity issues and the third wasn't perfect although acceptable. Basically parts of the screen darker/lighter than others especially noticeable while scrolling.
My X34A does not have this issue.
Not to mention it had a bizarre split screen issue with a certain shade of grey/brown. Steam library menu the entire window basically has a line split down the centre and of anything with the exact same colour it does the same thing. Not sure why but once I saw it on BF1 it did put me off. Will likely be able to find the mentioned issue online.
The ghosting due to VA was pretty bad for me personally. games were fine but dark backgrounds or say scrolling down the OCUK forums would result in noticeable melt effect.
I did get a decent panel in the end which then crapped out on me. So rather than risk another I did miss IPS to be fair and went with the X34A and while it has a tiny bit of bleed and slightly lesser refresh rate.
Really enjoying it so far and none of the above issues.
