Delidded chip difference between the cores
14 Oct 2007
newcastle
I have an 8pack 5ghz chip, what should be the difference between the cores on a realbench stress test? At the minute I’m seeing an 8-9c difference between the hottest and coldest core is that about right?
Anything between 6-10c is normal I believe. Last two cpus for me have also typically been 8-9c. Longer more intensive stress tests typically widen the gap a little I found.
My 7700k (delidded by myself) tends to have a 5-8c variation in core temps.
I think it's fairly normal. I've certainly never worried about it.
I wonder if the chips that are running hotter are being effected by the local cache and that difference is just extra residual heat coming from the on board memory?
Sounds sensible; this quickly-googled die diagram shows that each pair of cores has a different neighbour, so some of them will be affected by GPU activity, some by 'system agent' (?) and some only by the other cores.
I've been very happy with this 7700k with temp variance across the cores at idle and load. This is non delided with all cores synced at 4.5ghz cooled by a Noctua D14. So far up and running for 48hrs and a few hours gaming in Destiny 2.
Seems they did a very good pasting job on this one.
