Let me set the background first. Im on the z87 platform powered by a 4770k for my main rig, i also got a z97 mobo and everything else except the CPU for that motherboard. Now i managed to get my hands on a 4790k and 16gigs of 1866mhz ram for around 110 pounds, dirt cheap if you ask me, and i did this due to the price as it allows me to upgrade my server with some proper hardware. Now ill be swapping the 4790k into my main rig instead of the 4770k and hopefully i can have my 4,4ghz without hitting 90c on AIO water, just a small bonus on the side.
Now my current server is doing better than i would expect from a pathetic AMD Athlon 5150 and it takes no power what so ever, we are talking less that 25 watts, but it is still weak and game servers on it is not a good experience when playing more than 2
. Now the 4770k is of course a huge upgrade but i don't need it to run full speed 3,9ghz as i'm not interested in 150+ watt of power draw. To the main topic then. Im of course going to underclock the 4770k, seems backwards no?
. I was thinking 2,0ghz for starters if i can even get it to go that low. Was wondering if anyone have experimented with a similar idea and what your results were? what volts was needed? did you measure power draw?
I know as you scale up an overclock power has to been increased exponentially. I was sort of hoping for the same thing but in backwards order for an underclock. That once i hit 2,5-2,0ghz that the power required is so low that its is next to none, at least compared to full tilt 3,9ghz. I would be very happy if i got get it to hit around the 60-75 watt mark. Am i being unrealistic?
TL;DR: Have you underclocked a 4770k(or similar) before and what where your power draw results from it? Was it for server use?
. I was thinking 2,0ghz for starters if i can even get it to go that low. Was wondering if anyone have experimented with a similar idea and what your results were? what volts was needed? did you measure power draw?I know as you scale up an overclock power has to been increased exponentially. I was sort of hoping for the same thing but in backwards order for an underclock. That once i hit 2,5-2,0ghz that the power required is so low that its is next to none, at least compared to full tilt 3,9ghz. I would be very happy if i got get it to hit around the 60-75 watt mark. Am i being unrealistic?
