Do you mean the Pro4 or ASRock in general?
That one in particular (see above video from buildzoid) and a number of others.
What was that link meant to show?2 year warrantysays it all.
http://www.vip-computers.com/eu/shop/product.aspx?product=6166
And NO they are not a competitor but a UK distributor for shops like OcUK.
Fair enough, I'd say just go for whichever is cheaper then. Both work fine at stock. For RMA the Gigabyte is better, due to a UK RMA centre.Interesting, although I'm not that worried about overclocking at the moment.
My old computer was bought in May 2010, running from an Intel I7 930 2.8GHZ Bloomfied. So, even stock it will run amazing in comparison to my old computer.
Thanks Stulid, as I mentioned before, I am going to keep using my old monitor and get a new one in a few months. I want to get the system right and go on from there.
It would work, but you might struggle to hit 100fps at that res with high settings in some games. 60fps no problems though. Is very game dependent.Question - would a GTX1070 work ok with a 1440P 100Hz+ 27" monitor?
When you're in the basket screen, click 'BBCODE' then copy and paste all the text from the black box into a post. Shows your basket.I have made a few changes to the build. I'm still trying to figure out how to share it.
However, I'm looking for recommendations on a different case, roughly about £100. Any ideas?
Windowed with a colour scheme.
