- 20 Apr 2004
- Rugby
For me top end cards should be all about the most performance for 350watts. I would love to see cards rated by power use. What do you put first performance per watt or watts to performance? Performance should come first in the gaming market.
And it does for me too but its all has to be within reason but would I switched from a 980ti SLI hybrid setup to if the 1080ti was a 600w card rather than a 6=300w no not unless it was very cheap.
Would I want 600w of heat to be dumped into my WC loop or case, no as i would have ramp up fans or get more fans and rad space, extra cost or noise
Would I of liked to upgrade my PSU as well and or overstress my current one, no, extra cost and noise
Some peoples might card that fit a ITX case but not sound like a banshee which you could'nt do with a 600w card with in a dual slot cooler or even a 4 slot cooler in a normal size case
a lot of people (or maybe just me) would prefer a 300w with 90% performance of its 600w competitor.
Yes performance is important but its not the be all and end all not matter if your buying high end or low end
