Gigabyte 980ti Xtreme Waterforce voltage issues?
22 Jan 2014
Evening all,
Recently purchased a 980ti Waterforce from the MM here, and having a play around with it. All seems to be running fine, nothing odd that I've noticed, but GPU-Z is showing:
PerfCap Reason VRel - so performance is being capped by voltage reliability. This is running straight just plugged in, no playing with overclocking by me. Any clues?
There are two 8-pin power connectors that I've plugged in, but there's also a 6-pin one for LN2...would plugging the 6-pin in when there's no LN2 provide more stable power or just bork the card?
PSU is a SuperFlower Golden Green HX 650W non-modular, so should be plenty powerful enough for this card.
Hugh
99% sure this means nothing and will be shown on most gpus @ load.
If you are worried about performance all you need to do run a few benchmark and see if you have similar scores systems like yours.
Edit*
I just checked and loaded up a game on my 1080 and it says Vrel for me as well.
Vrel means the clock is boosting to the highest it can for that voltage. I assume by reliable they mean that any higher clock might be unreliable/unstable.
Totally normal behaviour.
Its normal.
One other thing to add is not all 980ti like added voltage. My 980ti G1 overclocked amazingly well on stock voltage. If I added more it didnt respond well at all.
Its normal.
Mines like this. Does 1470 at stock volts, not interested in 1500mhz no matter what voltage, crashes within a second of testing it.
Edit*
Its normal.
Excellent news, thank you.
I'll benchmark and compare just now to make sure, but it certainly feels dandy.
