Caporegime
- 18 Sep 2009
- Dormanstown.
I'd be sending that back.
Definitely this.
8Pack should know better![]()
No way would I accept that.
O wow that is bad![]()
Some Isopropyl alcohol would clean that right off.
Sending back over a sticker? Lol.
Surely you clean it off and use it like normal?
If it doesn't work then send it back...
A sticker has probably ended up in the box by accident. If the chip looks new and the glue cleans off then there really isn't an issue.
Some people freak out over things that I would personally just deal with and not bother creating such drama.
FYI, you should raise this in the customer service section if you want staff to review it.
I’m not sure if I could move it there as there are restrictions on that forum but let me know if you want and I’ll try.
I didn't actually mean to create drama for this! I just asked a legitimate question i had! I've opened a support request just making sure i can send it back if i do clean it so will just wait for them to let me know it's safe for me to go ahead and try!
Thanks all for your input!
Thank you! I'll see how the webticket turns out first!
Because of a sticker ???
Because of a sticker ?????
Again Because of a sticker ????
Do you people get upset by everything so trivial ?
This man deserves a medal for (quite rightly) pointing out the sodding obvious !
