Team Viewer & PC Locking
1 May 2012
Scotland
Bit of an odd one started happening since yesterday wondering if anyone might know the cause.
Have logged into my main PC from GF's and work for the last 2 years with TM without issue.
Yesterday it came up connection lost I thought OK does this every so often it will come back soon - After 5 hours it never came back I went home after work PC looked like it was still on so I powered on the monitor but it just kept coming up saying no signal had to pwer of completley and power back on.
Then went to GF's that night loged back in made sure my power settings were all set to never sleep etc never turn of hard disks ran some virus checks and installed the monitor driver from TM on both PC's.
Had a look in event viewer and only thing I could see I cant currently remember but will update tonight but it was something along the lines jrscpt service or something similiar failed.
After about 2 hours of being in the system the same thing happened again - Given the PC is remaining powered on and the monitor dosent seem to want to output anything after turning back on im stuck as to what it might be - I will be home tonight and putting it through its paces to see if it does it when not in TM.
Edit - I should point out the PC is not showing as online after it drops connection its not like it is dropping signal and still viewable as on online pc.
The WarpJITSvc seems to be a frequent error and the report from who crashed below - Can anyone help at all?
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Fri 08/12/2017 13:42:56 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\120817-6734-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1640E0)
Bugcheck code: 0x109 (0xA3A00A5EF735D61E, 0xB3B716E549B78C45, 0xFFFFF806DEAD0000, 0x19)
Error: CRITICAL_STRUCTURE_CORRUPTION
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that the kernel has detected critical kernel code or data corruption.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Fri 08/12/2017 00:08:31 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\120817-6515-01.dmp
Bugcheck code: 0x109 (0xA39FCFE80C40F5AF, 0xB3B6DC6E5EC3A686, 0xFFFFF80267370000, 0x19)
On Thu 07/12/2017 19:48:42 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\120717-5515-01.dmp
Bugcheck code: 0x109 (0xA39FD45E0D48B946, 0xB3B6E0E45FCA6F5D, 0xFFFFF80462BF0000, 0x19)
On Thu 07/12/2017 18:48:50 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\120717-5718-01.dmp
Bugcheck code: 0x109 (0xA3A01DD89860F669, 0xB3B72A5EEAE2AC90, 0xFFFFF806355C0000, 0x19)
dont' understand - thought you said event viewer had nothing, but the complete machine had crashed ?
so do crashes relate/correlate with team viewer use ?
the one hour spacing on last couple of crashes makes it look like some scheduled service is responsible.
No problem here is 1 and other to follow not sure if you need the info thats below the first part or not
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 8 Kernel Version 16299 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 16299.15.amd64fre.rs3_release.170928-1534
Machine Name:
Kernel base = 0xfffff801`e2699000 PsLoadedModuleList = 0xfffff801`e29fafb0
Debug session time: Thu Dec 7 14:48:42.538 2017 (UTC - 5:00)
System Uptime: 0 days 0:38:33.250
* Bugcheck Analysis *
CRITICAL_STRUCTURE_CORRUPTION (109)
This bugcheck is generated when the kernel detects that critical kernel code or
data have been corrupted. There are generally three causes for a corruption:
1) A driver has inadvertently or deliberately modified critical kernel code
or data. See http://www.microsoft.com/whdc/driver/kernel/64bitPatching.mspx
2) A developer attempted to set a normal kernel breakpoint using a kernel
debugger that was not attached when the system was booted. Normal breakpoints,
"bp", can only be set if the debugger is attached at boot time. Hardware
breakpoints, "ba", can be set at any time.
3) A hardware corruption occurred, e.g. failing RAM holding kernel code or data.
Arguments:
Arg1: a39fd45e0d48b946, Reserved
Arg2: b3b6e0e45fca6f5d, Reserved
Arg3: fffff80462bf0000, Failure type dependent information
Arg4: 0000000000000019, Type of corrupted region, can be
0 : A generic data region
1 : Modification of a function or .pdata
2 : A processor IDT
3 : A processor GDT
4 : Type 1 process list corruption
5 : Type 2 process list corruption
6 : Debug routine modification
7 : Critical MSR modification
Debugging Details:
BUGCHECK_STR: 0x109
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff801e27fd0e0
STACK_TEXT:
ffffa502`02e768f8 00000000`00000000 : 00000000`00000109 a39fd45e`0d48b946 b3b6e0e4`5fca6f5d fffff804`62bf0000 : nt!KeBugCheckEx
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: BAD_STACK
Followup: MachineOwner
This free analysis is provided by OSR Open Systems Resources, Inc.
Machine Name:
Kernel base = 0xfffff803`fee00000 PsLoadedModuleList = 0xfffff803`ff161fb0
Debug session time: Thu Dec 7 19:08:31.425 2017 (UTC - 5:00)
System Uptime: 0 days 2:36:00.137
Arguments:
Arg1: a39fcfe80c40f5af, Reserved
Arg2: b3b6dc6e5ec3a686, Reserved
Arg3: fffff80267370000, Failure type dependent information
2 : A processor IDT
3 : A processor GDT
Debugging Details:
BUGCHECK_STR: 0x109
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff803fef640e0
STACK_TEXT:
fffff280`b29168f8 00000000`00000000 : 00000000`00000109 a39fcfe8`0c40f5af b3b6dc6e`5ec3a686 fffff802`67370000 : nt!KeBugCheckEx
STACK_COMMAND: kb
At first I thought it was down to TM but I think its a little deeper than that.
I have updated all my drivers just in case as well now.
I would check out the system log just prior to the crashes too, for common traites.
run a memory check too, per initial transcript.
You have 2 factor enabled for team viewer too ? (given recent thread about PC take-over)
Am home tonight so will do dude - Thanks,
Yes I do have that already activated - Always been a worry when using TM is there any better free alternatives to it though?
Hmm those dumps usually list the driver name and stack trace to help figure out what it is.
Any chance you could upload them somewhere (DropBox etc?) and I'll try and take a deeper look?
There's Google Remote Desktop but honestly your issue doesn't seem to point at TV being the cause.
Make a bootable disk/USB using this and run that for a while.
I will do this tonight when I get home as it has yet again crashed and no one is home so cant annoy anyone to press the power button for me :) - Thanks for your help
Hi Mate - sorry didn't get anything up yesterday night - here is a more recent one with more info if that helps any?
Instant Online Crash Analysis, brought to you by OSR Open Systems Resources, Inc.
Primary Analysis
Machine Name:
Arguments:
2 : A processor IDT
3 : A processor GDT
Debugging Details:
BUGCHECK_STR: 0x109
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
Want a deeper understanding of crash dump analysis? Check out our Windows Kernel Debugging and Crash Dump Analysis Seminar (opens in new tab/window)
Crash Code Links
View the MSDN page for CRITICAL_STRUCTURE_CORRUPTION
Search Google for CRITICAL_STRUCTURE_CORRUPTION
Loaded Module List
start end module name
ffff85d9`ae400000 ffff85d9`ae794000 win32kfull win32kfull.sys
ffff85d9`ae7a0000 ffff85d9`ae9b2000 win32kbase win32kbase.sys
ffff85d9`ae9d0000 ffff85d9`ae9da000 TSDDD TSDDD.dll
ffff85d9`ae9e0000 ffff85d9`aea21000 cdd cdd.dll
ffff85d9`aec10000 ffff85d9`aec87000 win32k win32k.sys
fffff802`64800000 fffff802`64811000 werkernel werkernel.sys
fffff802`64820000 fffff802`64882000 CLFS CLFS.SYS
fffff802`64890000 fffff802`648b4000 tm tm.sys
fffff802`648c0000 fffff802`648d7000 PSHED PSHED.dll
fffff802`648e0000 fffff802`648eb000 BOOTVID BOOTVID.dll
fffff802`648f0000 fffff802`64958000 FLTMGR FLTMGR.SYS
fffff802`64960000 fffff802`64a61000 clipsp clipsp.sys
fffff802`64a70000 fffff802`64a7e000 cmimcext cmimcext.sys
fffff802`64a80000 fffff802`64a8c000 ntosext ntosext.sys
fffff802`64a90000 fffff802`64b42000 CI CI.dll
fffff802`64b50000 fffff802`64bfa000 cng cng.sys
fffff802`64c00000 fffff802`64ce3000 Wdf01000 Wdf01000.sys
fffff802`64cf0000 fffff802`64d03000 WDFLDR WDFLDR.SYS
fffff802`64d10000 fffff802`64d1e000 WppRecorder WppRecorder.sys
fffff802`64d20000 fffff802`64d2f000 SleepStudyHelper SleepStudyHelper.sys
fffff802`64d30000 fffff802`64d53000 acpiex acpiex.sys
fffff802`64d60000 fffff802`64dab000 mssecflt mssecflt.sys
fffff802`64db0000 fffff802`64e69000 ACPI ACPI.sys
fffff802`64e70000 fffff802`64e7c000 WMILIB WMILIB.SYS
fffff802`64e90000 fffff802`64eb5000 intelpep intelpep.sys
fffff802`64ec0000 fffff802`64ed6000 WindowsTrustedRT WindowsTrustedRT.sys
fffff802`64ee0000 fffff802`64eeb000 WindowsTrustedRTProxy WindowsTrustedRTProxy.sys
fffff802`64ef0000 fffff802`64f04000 pcw pcw.sys
fffff802`64f10000 fffff802`64f1b000 msisadrv msisadrv.sys
fffff802`64f20000 fffff802`64f7d000 pci pci.sys
fffff802`64f80000 fffff802`64f92000 vdrvroot vdrvroot.sys
fffff802`64fa0000 fffff802`64fc5000 pdc pdc.sys
fffff802`64fd0000 fffff802`64fe9000 CEA CEA.sys
fffff802`64ff0000 fffff802`6501d000 partmgr partmgr.sys
fffff802`65020000 fffff802`650b0000 spaceport spaceport.sys
fffff802`650b0000 fffff802`650c9000 volmgr volmgr.sys
fffff802`650d0000 fffff802`6512e000 volmgrx volmgrx.sys
fffff802`65130000 fffff802`6514e000 mountmgr mountmgr.sys
fffff802`65150000 fffff802`65179000 storahci storahci.sys
fffff802`65180000 fffff802`6520e000 storport storport.sys
fffff802`65230000 fffff802`6524a000 fileinfo fileinfo.sys
fffff802`65250000 fffff802`65347000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll
fffff802`65350000 fffff802`653b1000 msrpc msrpc.sys
fffff802`653c0000 fffff802`653e9000 ksecdd ksecdd.sys
fffff802`65400000 fffff802`65656000 NTFS NTFS.sys
fffff802`65660000 fffff802`6566d000 Fs_Rec Fs_Rec.sys
fffff802`65670000 fffff802`657af000 ndis ndis.sys
fffff802`657b0000 fffff802`65838000 NETIO NETIO.SYS
fffff802`65840000 fffff802`65870000 ksecpkg ksecpkg.sys
fffff802`65870000 fffff802`65b22000 tcpip tcpip.sys
fffff802`65b30000 fffff802`65ba1000 fwpkclnt fwpkclnt.sys
fffff802`65bb0000 fffff802`65bdc000 wfplwfs wfplwfs.sys
fffff802`65be0000 fffff802`65c98000 fvevol fvevol.sys
fffff802`65ca0000 fffff802`65cab000 volume volume.sys
fffff802`65cb0000 fffff802`65d16000 volsnap volsnap.sys
fffff802`65d20000 fffff802`65d28000 SmartDefragDriver SmartDefragDriver.sys
fffff802`65d30000 fffff802`65d7c000 rdyboost rdyboost.sys
fffff802`65d80000 fffff802`65da4000 mup mup.sys
fffff802`65db0000 fffff802`65dc1000 iorate iorate.sys
fffff802`65de0000 fffff802`65dfc000 disk disk.sys
fffff802`65e00000 fffff802`65e68000 CLASSPNP CLASSPNP.SYS
fffff802`65e90000 fffff802`65eab000 crashdmp crashdmp.sys
fffff802`65eb0000 fffff802`65f69000 srv2 srv2.sys
fffff802`65f70000 fffff802`65f9e000 cdrom cdrom.sys
fffff802`65fa0000 fffff802`65fb4000 filecrypt filecrypt.sys
fffff802`65fc0000 fffff802`65fcd000 tbs tbs.sys
fffff802`65fd0000 fffff802`66051000 mrxsmb mrxsmb.sys
fffff802`66060000 fffff802`660af000 atksgt atksgt.sys
fffff802`660b0000 fffff802`660d5000 Ndu Ndu.sys
fffff802`660e0000 fffff802`6611b000 Wof Wof.sys
fffff802`66170000 fffff802`661a3000 idmwfp idmwfp.sys
fffff802`661b0000 fffff802`661f7000 srvnet srvnet.sys
fffff802`66a00000 fffff802`66c79000 dxgkrnl dxgkrnl.sys
fffff802`66c80000 fffff802`66c9a000 vmbkmclr vmbkmclr.sys
fffff802`66ca0000 fffff802`66cb0000 BasicRender BasicRender.sys
fffff802`66cb0000 fffff802`66ccb000 Npfs Npfs.SYS
fffff802`66cd0000 fffff802`66ce0000 Msfs Msfs.SYS
fffff802`66ce0000 fffff802`66d03000 tdx tdx.sys
fffff802`66d10000 fffff802`66d20000 TDI TDI.SYS
fffff802`66d20000 fffff802`66d76000 netbt netbt.sys
fffff802`66d80000 fffff802`66d90000 mrxsmb22 mrxsmb22.sys
fffff802`66d90000 fffff802`66e2b000 afd afd.sys
fffff802`66e30000 fffff802`66e64000 VBoxNetLwf VBoxNetLwf.sys
fffff802`66e70000 fffff802`66e8a000 vwififlt vwififlt.sys
fffff802`66e90000 fffff802`66eb9000 pacer pacer.sys
fffff802`66ec0000 fffff802`66ed2000 netbios netbios.sys
fffff802`66ee0000 fffff802`66f54000 rdbss rdbss.sys
fffff802`66f60000 fffff802`66fef000 csc csc.sys
fffff802`66ff0000 fffff802`67019000 VBoxUSBMon VBoxUSBMon.sys
fffff802`67020000 fffff802`67111000 VBoxDrv VBoxDrv.sys
fffff802`67120000 fffff802`67132000 nsiproxy nsiproxy.sys
fffff802`67140000 fffff802`6714d000 npsvctrig npsvctrig.sys
fffff802`67150000 fffff802`6715f000 mssmbios mssmbios.sys
fffff802`67160000 fffff802`6716f000 MpKslc066f949 MpKslc066f949.sys
fffff802`67170000 fffff802`6717f000 MpKslb5db646b MpKslb5db646b.sys
fffff802`67180000 fffff802`6718a000 gpuenergydrv gpuenergydrv.sys
fffff802`67190000 fffff802`671ba000 dfsc dfsc.sys
fffff802`671c0000 fffff802`671d3000 mmcss mmcss.sys
fffff802`671e0000 fffff802`671f4000 bam bam.sys
fffff802`67200000 fffff802`67207000 AsUpIO AsUpIO.sys
fffff802`67210000 fffff802`67216000 AsIO AsIO.sys
fffff802`67220000 fffff802`67262000 ahcache ahcache.sys
fffff802`67270000 fffff802`67281000 CompositeBus CompositeBus.sys
fffff802`67290000 fffff802`6729d000 kdnic kdnic.sys
fffff802`672a0000 fffff802`672b5000 umbus umbus.sys
fffff802`672c0000 fffff802`67345000 atikmpag atikmpag.sys
fffff802`67950000 fffff802`6795a000 Null Null.SYS
fffff802`67960000 fffff802`6796a000 Beep Beep.SYS
fffff802`67970000 fffff802`67985000 BasicDisplay BasicDisplay.sys
fffff802`67990000 fffff802`679a4000 watchdog watchdog.sys
fffff802`679b0000 fffff802`679ed000 mrxsmb20 mrxsmb20.sys
fffff802`679f0000 fffff802`679fd000 lirsgt lirsgt.sys
fffff802`67a00000 fffff802`67a10000 kbdhid kbdhid.sys
fffff802`67a10000 fffff802`67a23000 kbdclass kbdclass.sys
fffff802`67a30000 fffff802`67a37300 I1KBFLTR I1KBFLTR.sys
fffff802`68000000 fffff802`680bc000 dxgmms2 dxgmms2.sys
fffff802`680c0000 fffff802`68115000 udfs udfs.sys
fffff802`68120000 fffff802`68128000 TVMonitor TVMonitor.sys
fffff802`68140000 fffff802`6814f000 dump_diskdump dump_diskdump.sys
fffff802`68150000 fffff802`68667000 RTKVHD64 RTKVHD64.sys
fffff802`68670000 fffff802`68688000 uaspstor uaspstor.sys
fffff802`68690000 fffff802`686b6000 asmthub3 asmthub3.sys
fffff802`686c0000 fffff802`686e4000 USBSTOR USBSTOR.SYS
fffff802`686f0000 fffff802`6871f000 usbccgp usbccgp.sys
fffff802`68740000 fffff802`68744c00 AndroidAFDx64 AndroidAFDx64.sys
fffff802`68750000 fffff802`68762000 hidusb hidusb.sys
fffff802`68770000 fffff802`687a5000 HIDCLASS HIDCLASS.SYS
fffff802`687b0000 fffff802`687c3000 HIDPARSE HIDPARSE.SYS
fffff802`687d0000 fffff802`687df000 mouhid mouhid.sys
fffff802`687e0000 fffff802`687f2000 mouclass mouclass.sys
fffff802`69800000 fffff802`698c1000 peauth peauth.sys
fffff802`698d0000 fffff802`698dc000 npf npf.sys
fffff802`698e0000 fffff802`69970000 srv srv.sys
fffff802`69970000 fffff802`69983000 tcpipreg tcpipreg.sys
fffff802`69990000 fffff802`69999000 UltraMonUtility UltraMonUtility.sys
fffff802`69a20000 fffff802`69a29000 IOMap64 IOMap64.sys
fffff802`69a40000 fffff802`69a5b000 rassstp rassstp.sys
fffff802`69a60000 fffff802`69a76000 NDProxy NDProxy.sys
fffff802`69a80000 fffff802`69aa7000 AgileVpn AgileVpn.sys
fffff802`69ab0000 fffff802`69ad0000 rasl2tp rasl2tp.sys
fffff802`69ad0000 fffff802`69aef000 raspptp raspptp.sys
fffff802`69af0000 fffff802`69b0b000 raspppoe raspppoe.sys
fffff802`69b10000 fffff802`69b2b000 wanarp wanarp.sys
fffff802`69b30000 fffff802`69b3f000 ndistapi ndistapi.sys
fffff802`69b40000 fffff802`69b77000 ndiswan ndiswan.sys
fffff802`69b80000 fffff802`69bd7000 aswVmm aswVmm.sys
fffff802`69be0000 fffff802`69c51000 aswSP aswSP.sys
fffff802`69c60000 fffff802`69cb0000 aswbidsdrivera aswbidsdrivera.sys
fffff802`69cb0000 fffff802`69cdf000 aswbidsha aswbidsha.sys
fffff802`69ce0000 fffff802`69d30000 aswbloga aswbloga.sys
fffff802`69d30000 fffff802`69d3e000 aswbuniva aswbuniva.sys
fffff802`69d70000 fffff802`69dbe000 mrxsmb10 mrxsmb10.sys
fffff802`6a000000 fffff802`6a001f80 AiChargerPlus AiChargerPlus.sys
fffff802`6a010000 fffff802`6a080000 USBXHCI USBXHCI.SYS
fffff802`6a080000 fffff802`6a0bc000 ucx01000 ucx01000.sys
fffff802`6a0c0000 fffff802`6a0f0000 TeeDriverW8x64 TeeDriverW8x64.sys
fffff802`6a0f0000 fffff802`6a15c000 asmtxhci asmtxhci.sys
fffff802`6a160000 fffff802`6a17c000 serial serial.sys
fffff802`6a180000 fffff802`6a18f000 serenum serenum.sys
fffff802`6a190000 fffff802`6a215000 e1d65x64 e1d65x64.sys
fffff802`6a220000 fffff802`6a22c000 wmiacpi wmiacpi.sys
fffff802`6a230000 fffff802`6a26c000 intelppm intelppm.sys
fffff802`6a270000 fffff802`6a27b000 acpipagr acpipagr.sys
fffff802`6a280000 fffff802`6a28d000 NdisVirtualBus NdisVirtualBus.sys
fffff802`6a290000 fffff802`6a29c000 swenum swenum.sys
fffff802`6a2a0000 fffff802`6a2ae000 ScpVBus ScpVBus.sys
fffff802`6a2b0000 fffff802`6a2be000 rdpbus rdpbus.sys
fffff802`6a2c0000 fffff802`6a2ca000 xspltspk xspltspk.sys
fffff802`6a2d0000 fffff802`6a2df000 ksthunk ksthunk.sys
fffff802`6a2e0000 fffff802`6a2fe000 AtihdWT6 AtihdWT6.sys
fffff802`6a300000 fffff802`6a38c000 UsbHub3 UsbHub3.sys
fffff802`6a390000 fffff802`6a39e000 USBD USBD.SYS
fffff802`6a3d0000 fffff802`6a3f9000 dump_storahci dump_storahci.sys
fffff802`6a400000 fffff802`6a41d000 dump_dumpfve dump_dumpfve.sys
fffff802`6a420000 fffff802`6a446000 luafv luafv.sys
fffff802`6a450000 fffff802`6a477000 wcifs wcifs.sys
fffff802`6a480000 fffff802`6a4c6000 WUDFRd WUDFRd.sys
fffff802`6a4d0000 fffff802`6a4dd000 WpdUpFltr WpdUpFltr.sys
fffff802`6a4e0000 fffff802`6a546000 cldflt cldflt.sys
fffff802`6a550000 fffff802`6a569000 storqosflt storqosflt.sys
fffff802`6a570000 fffff802`6a582000 condrv condrv.sys
fffff802`6a590000 fffff802`6a5aa000 mslldp mslldp.sys
fffff802`6a5b0000 fffff802`6a5c6000 lltdio lltdio.sys
fffff802`6a5d0000 fffff802`6a5ea000 rspndr rspndr.sys
fffff802`6a5f0000 fffff802`6a703000 HTTP HTTP.sys
fffff802`6a710000 fffff802`6a731000 bowser bowser.sys
fffff802`6a740000 fffff802`6a759000 mpsdrv mpsdrv.sys
fffff802`6a760000 fffff802`6ccb3000 atikmdag atikmdag.sys
fffff802`6ccc0000 fffff802`6ccc9000 mi2c mi2c.sys
fffff802`6ccd0000 fffff802`6cced000 HDAudBus HDAudBus.sys
fffff802`6ccf0000 fffff802`6cd53000 portcls portcls.sys
fffff802`6cd60000 fffff802`6cd81000 drmk drmk.sys
fffff802`6cd90000 fffff802`6cdf8000 ks ks.sys
fffff802`6e170000 fffff802`6e268000 aswSnx aswSnx.sys
fffff802`6e270000 fffff802`6e28a000 aswRdr2 aswRdr2.sys
fffff802`6e290000 fffff802`6e2df000 aswArPot aswArPot.sys
fffff802`6e2e0000 fffff802`6e308000 aswMonFlt aswMonFlt.sys
fffff802`6e310000 fffff802`6e342000 aswStm aswStm.sys
fffff803`fee00000 fffff803`ff6d2000 nt ntkrnlmp.exe
fffff803`ff6d2000 fffff803`ff751000 hal hal.dll
fffff803`ff800000 fffff803`ff80b000 kd kd.dll
Unloaded modules:
fffff802`6e350000 fffff802`6e36c000 aswHdsKe.sys
fffff802`699a0000 fffff802`699eb000 WdFilter.sys
fffff802`699f0000 fffff802`69a12000 WdNisDrv.sys
fffff802`69a30000 fffff802`69a37000 OpenHardware
fffff802`66120000 fffff802`6616b000 WdFilter.sys
fffff802`65ec0000 fffff802`65ecf000 dump_storpor
fffff802`65f00000 fffff802`65f29000 dump_storahc
fffff802`65f50000 fffff802`65f6d000 dump_dumpfve
fffff802`68720000 fffff802`6873c000 EhStorClass.
fffff802`65210000 fffff802`6522c000 EhStorClass.
fffff802`6ccc0000 fffff802`6ccca000 amdkmafd.sys
fffff802`671c0000 fffff802`671d9000 dam.sys
fffff802`64e80000 fffff802`64e8f000 WdBoot.sys
fffff802`65dd0000 fffff802`65ddf000 hwpolicy.sys
Raw Stack Contents
fffff280`b2911000 00000000`00000000
fffff280`b2911008 40280000`00000000
fffff280`b2911010 00000000`00000004
fffff280`b2911018 00000000`00000000
fffff280`b2911020 00000000`93000202
fffff280`b2911028 00000000`00000000
fffff280`b2911030 00000000`00000001
fffff280`b2911038 00000000`00000000
fffff280`b2911040 00000000`00000000
fffff280`b2911048 40280000`00000000
fffff280`b2911050 00000000`00000004
fffff280`b2911058 00000000`00000000
fffff280`b2911060 00000000`93000202
fffff280`b2911068 00000000`00000000
fffff280`b2911070 00000000`00000001
fffff280`b2911078 00000000`00000000
fffff280`b2911080 00000000`00000000
fffff280`b2911088 40280000`00000000
fffff280`b2911090 00000000`00000004
fffff280`b2911098 00000000`00000000
fffff280`b29110a0 00000000`92000202
fffff280`b29110a8 00000000`00000000
fffff280`b29110b0 00000000`00000001
fffff280`b29110b8 00000000`00000000
fffff280`b29110c0 00000000`00000000
fffff280`b29110c8 40280000`00000000
fffff280`b29110d0 00000000`00000004
fffff280`b29110d8 00000000`00000000
fffff280`b29110e0 00000000`93000202
fffff280`b29110e8 00000000`00000000
fffff280`b29110f0 00000000`00000001
fffff280`b29110f8 00000000`00000000
fffff280`b2911100 ????????`????????
fffff280`b2911108 ????????`????????
fffff280`b2911110 ????????`????????
fffff280`b2911118 ????????`????????
fffff280`b2911120 ????????`????????
fffff280`b2911128 ????????`????????
fffff280`b2911130 ????????`????????
fffff280`b2911138 ????????`????????
fffff280`b2911140 ????????`????????
fffff280`b2911148 ????????`????????
fffff280`b2911150 ????????`????????
fffff280`b2911158 ????????`????????
fffff280`b2911160 ????????`????????
fffff280`b2911168 ????????`????????
fffff280`b2911170 ????????`????????
fffff280`b2911178 ????????`????????
fffff280`b2911180 ????????`????????
fffff280`b2911188 ????????`????????
fffff280`b2911190 ????????`????????
fffff280`b2911198 ????????`????????
fffff280`b29111a0 ????????`????????
fffff280`b29111a8 ????????`????????
fffff280`b29111b0 ????????`????????
fffff280`b29111b8 ????????`????????
fffff280`b29111c0 ????????`????????
fffff280`b29111c8 ????????`????????
fffff280`b29111d0 ????????`????????
fffff280`b29111d8 ????????`????????
fffff280`b29111e0 ????????`????????
fffff280`b29111e8 ????????`????????
fffff280`b29111f0 ????????`????????
fffff280`b29111f8 ????????`????????
fffff280`b2911200 ????????`????????
fffff280`b2911208 ????????`????????
fffff280`b2911210 ????????`????????
fffff280`b2911218 ????????`????????
fffff280`b2911220 ????????`????????
fffff280`b2911228 ????????`????????
fffff280`b2911230 ????????`????????
fffff280`b2911238 ????????`????????
fffff280`b2911240 ????????`????????
fffff280`b2911248 ????????`????????
fffff280`b2911250 ????????`????????
fffff280`b2911258 ????????`????????
fffff280`b2911260 ????????`????????
fffff280`b2911268 ????????`????????
fffff280`b2911270 ????????`????????
fffff280`b2911278 ????????`????????
fffff280`b2911280 ????????`????????
fffff280`b2911288 ????????`????????
fffff280`b2911290 ????????`????????
fffff280`b2911298 ????????`????????
fffff280`b29112a0 ????????`????????
fffff280`b29112a8 ????????`????????
fffff280`b29112b0 ????????`????????
fffff280`b29112b8 ????????`????????
fffff280`b29112c0 ????????`????????
fffff280`b29112c8 ????????`????????
fffff280`b29112d0 ????????`????????
fffff280`b29112d8 ????????`????????
fffff280`b29112e0 ????????`????????
fffff280`b29112e8 ????????`????????
fffff280`b29112f0 ????????`????????
fffff280`b29112f8 ????????`????????
fffff280`b2911300 ????????`????????
fffff280`b2911308 ????????`????????
fffff280`b2911310 ????????`????????
fffff280`b2911318 ????????`????????
fffff280`b2911320 ????????`????????
fffff280`b2911328 ????????`????????
fffff280`b2911330 ????????`????????
fffff280`b2911338 ????????`????????
fffff280`b2911340 ????????`????????
fffff280`b2911348 ????????`????????
fffff280`b2911350 ????????`????????
fffff280`b2911358 ????????`????????
fffff280`b2911360 ????????`????????
fffff280`b2911368 ????????`????????
fffff280`b2911370 ????????`????????
fffff280`b2911378 ????????`????????
fffff280`b2911380 ????????`????????
fffff280`b2911388 ????????`????????
fffff280`b2911390 ????????`????????
fffff280`b2911398 ????????`????????
fffff280`b29113a0 ????????`????????
fffff280`b29113a8 ????????`????????
fffff280`b29113b0 ????????`????????
fffff280`b29113b8 ????????`????????
fffff280`b29113c0 ????????`????????
fffff280`b29113c8 ????????`????????
fffff280`b29113d0 ????????`????????
fffff280`b29113d8 ????????`????????
fffff280`b29113e0 ????????`????????
fffff280`b29113e8 ????????`????????
fffff280`b29113f0 ????????`????????
fffff280`b29113f8 ????????`????????
fffff280`b2911400 ????????`????????
fffff280`b2911408 ????????`????????
fffff280`b2911410 ????????`????????
fffff280`b2911418 ????????`????????
fffff280`b2911420 ????????`????????
fffff280`b2911428 ????????`????????
fffff280`b2911430 ????????`????????
fffff280`b2911438 ????????`????????
fffff280`b2911440 ????????`????????
fffff280`b2911448 ????????`????????
fffff280`b2911450 ????????`????????
fffff280`b2911458 ????????`????????
fffff280`b2911460 ????????`????????
fffff280`b2911468 ????????`????????
fffff280`b2911470 ????????`????????
fffff280`b2911478 ????????`????????
fffff280`b2911480 ????????`????????
fffff280`b2911488 ????????`????????
fffff280`b2911490 ????????`????????
fffff280`b2911498 ????????`????????
fffff280`b29114a0 ????????`????????
fffff280`b29114a8 ????????`????????
fffff280`b29114b0 ????????`????????
fffff280`b29114b8 ????????`????????
fffff280`b29114c0 ????????`????????
fffff280`b29114c8 ????????`????????
fffff280`b29114d0 ????????`????????
fffff280`b29114d8 ????????`????????
fffff280`b29114e0 ????????`????????
fffff280`b29114e8 ????????`????????
fffff280`b29114f0 ????????`????????
fffff280`b29114f8 ????????`????????
fffff280`b2911500 ????????`????????
fffff280`b2911508 ????????`????????
fffff280`b2911510 ????????`????????
fffff280`b2911518 ????????`????????
fffff280`b2911520 ????????`????????
fffff280`b2911528 ????????`????????
fffff280`b2911530 ????????`????????
fffff280`b2911538 ????????`????????
fffff280`b2911540 ????????`????????
fffff280`b2911548 ????????`????????
fffff280`b2911550 ????????`????????
fffff280`b2911558 ????????`????????
fffff280`b2911560 ????????`????????
fffff280`b2911568 ????????`????????
fffff280`b2911570 ????????`????????
fffff280`b2911578 ????????`????????
fffff280`b2911580 ????????`????????
fffff280`b2911588 ????????`????????
fffff280`b2911590 ????????`????????
fffff280`b2911598 ????????`????????
fffff280`b29115a0 ????????`????????
fffff280`b29115a8 ????????`????????
fffff280`b29115b0 ????????`????????
fffff280`b29115b8 ????????`????????
fffff280`b29115c0 ????????`????????
fffff280`b29115c8 ????????`????????
fffff280`b29115d0 ????????`????????
fffff280`b29115d8 ????????`????????
fffff280`b29115e0 ????????`????????
fffff280`b29115e8 ????????`????????
fffff280`b29115f0 ????????`????????
fffff280`b29115f8 ????????`????????
fffff280`b2911600 ????????`????????
fffff280`b2911608 ????????`????????
fffff280`b2911610 ????????`????????
fffff280`b2911618 ????????`????????
fffff280`b2911620 ????????`????????
fffff280`b2911628 ????????`????????
fffff280`b2911630 ????????`????????
fffff280`b2911638 ????????`????????
fffff280`b2911640 ????????`????????
fffff280`b2911648 ????????`????????
fffff280`b2911650 ????????`????????
fffff280`b2911658 ????????`????????
fffff280`b2911660 ????????`????????
fffff280`b2911668 ????????`????????
fffff280`b2911670 ????????`????????
fffff280`b2911678 ????????`????????
fffff280`b2911680 ????????`????????
fffff280`b2911688 ????????`????????
fffff280`b2911690 ????????`????????
fffff280`b2911698 ????????`????????
fffff280`b29116a0 ????????`????????
fffff280`b29116a8 ????????`????????
fffff280`b29116b0 ????????`????????
fffff280`b29116b8 ????????`????????
fffff280`b29116c0 ????????`????????
fffff280`b29116c8 ????????`????????
fffff280`b29116d0 ????????`????????
fffff280`b29116d8 ????????`????????
fffff280`b29116e0 ????????`????????
fffff280`b29116e8 ????????`????????
fffff280`b29116f0 ????????`????????
fffff280`b29116f8 ????????`????????
fffff280`b2911700 ????????`????????
fffff280`b2911708 ????????`????????
fffff280`b2911710 ????????`????????
fffff280`b2911718 ????????`????????
fffff280`b2911720 ????????`????????
fffff280`b2911728 ????????`????????
fffff280`b2911730 ????????`????????
fffff280`b2911738 ????????`????????
fffff280`b2911740 ????????`????????
fffff280`b2911748 ????????`????????
fffff280`b2911750 ????????`????????
fffff280`b2911758 ????????`????????
fffff280`b2911760 ????????`????????
fffff280`b2911768 ????????`????????
fffff280`b2911770 ????????`????????
fffff280`b2911778 ????????`????????
fffff280`b2911780 ????????`????????
fffff280`b2911788 ????????`????????
fffff280`b2911790 ????????`????????
fffff280`b2911798 ????????`????????
fffff280`b29117a0 ????????`????????
fffff280`b29117a8 ????????`????????
fffff280`b29117b0 ????????`????????
fffff280`b29117b8 ????????`????????
fffff280`b29117c0 ????????`????????
fffff280`b29117c8 ????????`????????
fffff280`b29117d0 ????????`????????
fffff280`b29117d8 ????????`????????
fffff280`b29117e0 ????????`????????
fffff280`b29117e8 ????????`????????
fffff280`b29117f0 ????????`????????
fffff280`b29117f8 ????????`????????
fffff280`b2911800 ????????`????????
fffff280`b2911808 ????????`????????
fffff280`b2911810 ????????`????????
fffff280`b2911818 ????????`????????
fffff280`b2911820 ????????`????????
fffff280`b2911828 ????????`????????
fffff280`b2911830 ????????`????????
fffff280`b2911838 ????????`????????
fffff280`b2911840 ????????`????????
fffff280`b2911848 ????????`????????
fffff280`b2911850 ????????`????????
fffff280`b2911858 ????????`????????
fffff280`b2911860 ????????`????????
fffff280`b2911868 ????????`????????
fffff280`b2911870 ????????`????????
fffff280`b2911878 ????????`????????
fffff280`b2911880 ????????`????????
fffff280`b2911888 ????????`????????
fffff280`b2911890 ????????`????????
fffff280`b2911898 ????????`????????
fffff280`b29118a0 ????????`????????
fffff280`b29118a8 ????????`????????
fffff280`b29118b0 ????????`????????
fffff280`b29118b8 ????????`????????
fffff280`b29118c0 ????????`????????
fffff280`b29118c8 ????????`????????
fffff280`b29118d0 ????????`????????
fffff280`b29118d8 ????????`????????
fffff280`b29118e0 ????????`????????
fffff280`b29118e8 ????????`????????
fffff280`b29118f0 ????????`????????
fffff280`b29118f8 ????????`????????
fffff280`b2911900 ????????`????????
fffff280`b2911908 ????????`????????
fffff280`b2911910 ????????`????????
fffff280`b2911918 ????????`????????
fffff280`b2911920 ????????`????????
fffff280`b2911928 ????????`????????
fffff280`b2911930 ????????`????????
fffff280`b2911938 ????????`????????
fffff280`b2911940 ????????`????????
fffff280`b2911948 ????????`????????
fffff280`b2911950 ????????`????????
fffff280`b2911958 ????????`????????
fffff280`b2911960 ????????`????????
fffff280`b2911968 ????????`????????
fffff280`b2911970 ????????`????????
fffff280`b2911978 ????????`????????
fffff280`b2911980 ????????`????????
fffff280`b2911988 ????????`????????
fffff280`b2911990 ????????`????????
fffff280`b2911998 ????????`????????
fffff280`b29119a0 ????????`????????
fffff280`b29119a8 ????????`????????
fffff280`b29119b0 ????????`????????
fffff280`b29119b8 ????????`????????
fffff280`b29119c0 ????????`????????
fffff280`b29119c8 ????????`????????
fffff280`b29119d0 ????????`????????
fffff280`b29119d8 ????????`????????
fffff280`b29119e0 ????????`????????
fffff280`b29119e8 ????????`????????
fffff280`b29119f0 ????????`????????
fffff280`b29119f8 ????????`????????
fffff280`b2911a00 ????????`????????
fffff280`b2911a08 ????????`????????
fffff280`b2911a10 ????????`????????
fffff280`b2911a18 ????????`????????
fffff280`b2911a20 ????????`????????
fffff280`b2911a28 ????????`????????
fffff280`b2911a30 ????????`????????
fffff280`b2911a38 ????????`????????
fffff280`b2911a40 ????????`????????
fffff280`b2911a48 ????????`????????
fffff280`b2911a50 ????????`????????
fffff280`b2911a58 ????????`????????
fffff280`b2911a60 ????????`????????
fffff280`b2911a68 ????????`????????
fffff280`b2911a70 ????????`????????
fffff280`b2911a78 ????????`????????
fffff280`b2911a80 ????????`????????
fffff280`b2911a88 ????????`????????
fffff280`b2911a90 ????????`????????
fffff280`b2911a98 ????????`????????
fffff280`b2911aa0 ????????`????????
fffff280`b2911aa8 ????????`????????
fffff280`b2911ab0 ????????`????????
fffff280`b2911ab8 ????????`????????
fffff280`b2911ac0 ????????`????????
fffff280`b2911ac8 ????????`????????
fffff280`b2911ad0 ????????`????????
fffff280`b2911ad8 ????????`????????
fffff280`b2911ae0 ????????`????????
fffff280`b2911ae8 ????????`????????
fffff280`b2911af0 ????????`????????
fffff280`b2911af8 ????????`????????
fffff280`b2911b00 ????????`????????
fffff280`b2911b08 ????????`????????
fffff280`b2911b10 ????????`????????
fffff280`b2911b18 ????????`????????
fffff280`b2911b20 ????????`????????
fffff280`b2911b28 ????????`????????
fffff280`b2911b30 ????????`????????
fffff280`b2911b38 ????????`????????
fffff280`b2911b40 ????????`????????
fffff280`b2911b48 ????????`????????
fffff280`b2911b50 ????????`????????
fffff280`b2911b58 ????????`????????
fffff280`b2911b60 ????????`????????
fffff280`b2911b68 ????????`????????
fffff280`b2911b70 ????????`????????
fffff280`b2911b78 ????????`????????
fffff280`b2911b80 ????????`????????
fffff280`b2911b88 ????????`????????
fffff280`b2911b90 ????????`????????
fffff280`b2911b98 ????????`????????
fffff280`b2911ba0 ????????`????????
fffff280`b2911ba8 ????????`????????
fffff280`b2911bb0 ????????`????????
fffff280`b2911bb8 ????????`????????
fffff280`b2911bc0 ????????`????????
fffff280`b2911bc8 ????????`????????
fffff280`b2911bd0 ????????`????????
fffff280`b2911bd8 ????????`????????
fffff280`b2911be0 ????????`????????
fffff280`b2911be8 ????????`????????
fffff280`b2911bf0 ????????`????????
fffff280`b2911bf8 ????????`????????
fffff280`b2911c00 ????????`????????
fffff280`b2911c08 ????????`????????
fffff280`b2911c10 ????????`????????
fffff280`b2911c18 ????????`????????
fffff280`b2911c20 ????????`????????
fffff280`b2911c28 ????????`????????
fffff280`b2911c30 ????????`????????
fffff280`b2911c38 ????????`????????
fffff280`b2911c40 ????????`????????
fffff280`b2911c48 ????????`????????
fffff280`b2911c50 ????????`????????
fffff280`b2911c58 ????????`????????
fffff280`b2911c60 ????????`????????
fffff280`b2911c68 ????????`????????
fffff280`b2911c70 ????????`????????
fffff280`b2911c78 ????????`????????
fffff280`b2911c80 ????????`????????
fffff280`b2911c88 ????????`????????
fffff280`b2911c90 ????????`????????
fffff280`b2911c98 ????????`????????
fffff280`b2911ca0 ????????`????????
fffff280`b2911ca8 ????????`????????
fffff280`b2911cb0 ????????`????????
fffff280`b2911cb8 ????????`????????
fffff280`b2911cc0 ????????`????????
fffff280`b2911cc8 ????????`????????
fffff280`b2911cd0 ????????`????????
fffff280`b2911cd8 ????????`????????
fffff280`b2911ce0 ????????`????????
fffff280`b2911ce8 ????????`????????
fffff280`b2911cf0 ????????`????????
fffff280`b2911cf8 ????????`????????
fffff280`b2911d00 ????????`????????
fffff280`b2911d08 ????????`????????
fffff280`b2911d10 ????????`????????
fffff280`b2911d18 ????????`????????
fffff280`b2911d20 ????????`????????
fffff280`b2911d28 ????????`????????
fffff280`b2911d30 ????????`????????
fffff280`b2911d38 ????????`????????
fffff280`b2911d40 ????????`????????
fffff280`b2911d48 ????????`????????
fffff280`b2911d50 ????????`????????
fffff280`b2911d58 ????????`????????
fffff280`b2911d60 ????????`????????
fffff280`b2911d68 ????????`????????
fffff280`b2911d70 ????????`????????
fffff280`b2911d78 ????????`????????
fffff280`b2911d80 ????????`????????
fffff280`b2911d88 ????????`????????
fffff280`b2911d90 ????????`????????
fffff280`b2911d98 ????????`????????
fffff280`b2911da0 ????????`????????
fffff280`b2911da8 ????????`????????
fffff280`b2911db0 ????????`????????
fffff280`b2911db8 ????????`????????
fffff280`b2911dc0 ????????`????????
fffff280`b2911dc8 ????????`????????
fffff280`b2911dd0 ????????`????????
fffff280`b2911dd8 ????????`????????
fffff280`b2911de0 ????????`????????
fffff280`b2911de8 ????????`????????
fffff280`b2911df0 ????????`????????
fffff280`b2911df8 ????????`????????
fffff280`b2911e00 ????????`????????
fffff280`b2911e08 ????????`????????
fffff280`b2911e10 ????????`????????
fffff280`b2911e18 ????????`????????
fffff280`b2911e20 ????????`????????
fffff280`b2911e28 ????????`????????
fffff280`b2911e30 ????????`????????
fffff280`b2911e38 ????????`????????
fffff280`b2911e40 ????????`????????
fffff280`b2911e48 ????????`????????
fffff280`b2911e50 ????????`????????
fffff280`b2911e58 ????????`????????
fffff280`b2911e60 ????????`????????
fffff280`b2911e68 ????????`????????
fffff280`b2911e70 ????????`????????
fffff280`b2911e78 ????????`????????
fffff280`b2911e80 ????????`????????
fffff280`b2911e88 ????????`????????
fffff280`b2911e90 ????????`????????
fffff280`b2911e98 ????????`????????
fffff280`b2911ea0 ????????`????????
fffff280`b2911ea8 ????????`????????
fffff280`b2911eb0 ????????`????????
fffff280`b2911eb8 ????????`????????
fffff280`b2911ec0 ????????`????????
fffff280`b2911ec8 ????????`????????
fffff280`b2911ed0 ????????`????????
fffff280`b2911ed8 ????????`????????
fffff280`b2911ee0 ????????`????????
fffff280`b2911ee8 ????????`????????
fffff280`b2911ef0 ????????`????????
fffff280`b2911ef8 ????????`????????
fffff280`b2911f00 ????????`????????
fffff280`b2911f08 ????????`????????
fffff280`b2911f10 ????????`????????
fffff280`b2911f18 ????????`????????
fffff280`b2911f20 ????????`????????
fffff280`b2911f28 ????????`????????
fffff280`b2911f30 ????????`????????
fffff280`b2911f38 ????????`????????
fffff280`b2911f40 ????????`????????
fffff280`b2911f48 ????????`????????
fffff280`b2911f50 ????????`????????
fffff280`b2911f58 ????????`????????
fffff280`b2911f60 ????????`????????
fffff280`b2911f68 ????????`????????
fffff280`b2911f70 ????????`????????
fffff280`b2911f78 ????????`????????
fffff280`b2911f80 ????????`????????
fffff280`b2911f88 ????????`????????
fffff280`b2911f90 ????????`????????
fffff280`b2911f98 ????????`????????
fffff280`b2911fa0 ????????`????????
fffff280`b2911fa8 ????????`????????
fffff280`b2911fb0 ????????`????????
fffff280`b2911fb8 ????????`????????
fffff280`b2911fc0 ????????`????????
fffff280`b2911fc8 ????????`????????
fffff280`b2911fd0 ????????`????????
fffff280`b2911fd8 ????????`????????
fffff280`b2911fe0 ????????`????????
fffff280`b2911fe8 ????????`????????
fffff280`b2911ff0 ????????`????????
fffff280`b2911ff8 ????????`????????
fffff280`b2912000 ????????`????????
fffff280`b2912008 ????????`????????
fffff280`b2912010 ????????`????????
fffff280`b2912018 ????????`????????
fffff280`b2912020 ????????`????????
fffff280`b2912028 ????????`????????
fffff280`b2912030 ????????`????????
fffff280`b2912038 ????????`????????
fffff280`b2912040 ????????`????????
fffff280`b2912048 ????????`????????
fffff280`b2912050 ????????`????????
fffff280`b2912058 ????????`????????
fffff280`b2912060 ????????`????????
fffff280`b2912068 ????????`????????
fffff280`b2912070 ????????`????????
fffff280`b2912078 ????????`????????
fffff280`b2912080 ????????`????????
fffff280`b2912088 ????????`????????
fffff280`b2912090 ????????`????????
fffff280`b2912098 ????????`????????
fffff280`b29120a0 ????????`????????
fffff280`b29120a8 ????????`????????
fffff280`b29120b0 ????????`????????
fffff280`b29120b8 ????????`????????
fffff280`b29120c0 ????????`????????
fffff280`b29120c8 ????????`????????
fffff280`b29120d0 ????????`????????
fffff280`b29120d8 ????????`????????
fffff280`b29120e0 ????????`????????
fffff280`b29120e8 ????????`????????
fffff280`b29120f0 ????????`????????
fffff280`b29120f8 ????????`????????
fffff280`b2912100 ????????`????????
fffff280`b2912108 ????????`????????
fffff280`b2912110 ????????`????????
fffff280`b2912118 ????????`????????
fffff280`b2912120 ????????`????????
fffff280`b2912128 ????????`????????
fffff280`b2912130 ????????`????????
fffff280`b2912138 ????????`????????
fffff280`b2912140 ????????`????????
fffff280`b2912148 ????????`????????
fffff280`b2912150 ????????`????????
fffff280`b2912158 ????????`????????
fffff280`b2912160 ????????`????????
fffff280`b2912168 ????????`????????
fffff280`b2912170 ????????`????????
fffff280`b2912178 ????????`????????
fffff280`b2912180 ????????`????????
fffff280`b2912188 ????????`????????
fffff280`b2912190 ????????`????????
fffff280`b2912198 ????????`????????
fffff280`b29121a0 ????????`????????
fffff280`b29121a8 ????????`????????
fffff280`b29121b0 ????????`????????
fffff280`b29121b8 ????????`????????
fffff280`b29121c0 ????????`????????
fffff280`b29121c8 ????????`????????
fffff280`b29121d0 ????????`????????
fffff280`b29121d8 ????????`????????
fffff280`b29121e0 ????????`????????
fffff280`b29121e8 ????????`????????
fffff280`b29121f0 ????????`????????
fffff280`b29121f8 ????????`????????
fffff280`b2912200 ????????`????????
fffff280`b2912208 ????????`????????
fffff280`b2912210 ????????`????????
fffff280`b2912218 ????????`????????
fffff280`b2912220 ????????`????????
fffff280`b2912228 ????????`????????
fffff280`b2912230 ????????`????????
fffff280`b2912238 ????????`????????
fffff280`b2912240 ????????`????????
fffff280`b2912248 ????????`????????
fffff280`b2912250 ????????`????????
fffff280`b2912258 ????????`????????
fffff280`b2912260 ????????`????????
fffff280`b2912268 ????????`????????
fffff280`b2912270 ????????`????????
fffff280`b2912278 ????????`????????
fffff280`b2912280 ????????`????????
fffff280`b2912288 ????????`????????
fffff280`b2912290 ????????`????????
fffff280`b2912298 ????????`????????
fffff280`b29122a0 ????????`????????
fffff280`b29122a8 ????????`????????
fffff280`b29122b0 ????????`????????
fffff280`b29122b8 ????????`????????
fffff280`b29122c0 ????????`????????
fffff280`b29122c8 ????????`????????
fffff280`b29122d0 ????????`????????
fffff280`b29122d8 ????????`????????
fffff280`b29122e0 ????????`????????
fffff280`b29122e8 ????????`????????
fffff280`b29122f0 ????????`????????
fffff280`b29122f8 ????????`????????
fffff280`b2912300 ????????`????????
fffff280`b2912308 ????????`????????
fffff280`b2912310 ????????`????????
fffff280`b2912318 ????????`????????
fffff280`b2912320 ????????`????????
fffff280`b2912328 ????????`????????
fffff280`b2912330 ????????`????????
fffff280`b2912338 ????????`????????
fffff280`b2912340 ????????`????????
fffff280`b2912348 ????????`????????
fffff280`b2912350 ????????`????????
fffff280`b2912358 ????????`????????
fffff280`b2912360 ????????`????????
fffff280`b2912368 ????????`????????
fffff280`b2912370 ????????`????????
fffff280`b2912378 ????????`????????
fffff280`b2912380 ????????`????????
fffff280`b2912388 ????????`????????
fffff280`b2912390 ????????`????????
fffff280`b2912398 ????????`????????
fffff280`b29123a0 ????????`????????
fffff280`b29123a8 ????????`????????
fffff280`b29123b0 ????????`????????
fffff280`b29123b8 ????????`????????
fffff280`b29123c0 ????????`????????
fffff280`b29123c8 ????????`????????
fffff280`b29123d0 ????????`????????
fffff280`b29123d8 ????????`????????
fffff280`b29123e0 ????????`????????
fffff280`b29123e8 ????????`????????
fffff280`b29123f0 ????????`????????
fffff280`b29123f8 ????????`????????
fffff280`b2912400 ????????`????????
fffff280`b2912408 ????????`????????
fffff280`b2912410 ????????`????????
fffff280`b2912418 ????????`????????
fffff280`b2912420 ????????`????????
fffff280`b2912428 ????????`????????
fffff280`b2912430 ????????`????????
fffff280`b2912438 ????????`????????
fffff280`b2912440 ????????`????????
fffff280`b2912448 ????????`????????
fffff280`b2912450 ????????`????????
fffff280`b2912458 ????????`????????
fffff280`b2912460 ????????`????????
fffff280`b2912468 ????????`????????
fffff280`b2912470 ????????`????????
fffff280`b2912478 ????????`????????
fffff280`b2912480 ????????`????????
fffff280`b2912488 ????????`????????
fffff280`b2912490 ????????`????????
fffff280`b2912498 ????????`????????
fffff280`b29124a0 ????????`????????
fffff280`b29124a8 ????????`????????
fffff280`b29124b0 ????????`????????
fffff280`b29124b8 ????????`????????
fffff280`b29124c0 ????????`????????
fffff280`b29124c8 ????????`????????
fffff280`b29124d0 ????????`????????
fffff280`b29124d8 ????????`????????
fffff280`b29124e0 ????????`????????
fffff280`b29124e8 ????????`????????
fffff280`b29124f0 ????????`????????
fffff280`b29124f8 ????????`????????
fffff280`b2912500 ????????`????????
fffff280`b2912508 ????????`????????
fffff280`b2912510 ????????`????????
fffff280`b2912518 ????????`????????
fffff280`b2912520 ????????`????????
fffff280`b2912528 ????????`????????
fffff280`b2912530 ????????`????????
fffff280`b2912538 ????????`????????
fffff280`b2912540 ????????`????????
fffff280`b2912548 ????????`????????
fffff280`b2912550 ????????`????????
fffff280`b2912558 ????????`????????
fffff280`b2912560 ????????`????????
fffff280`b2912568 ????????`????????
fffff280`b2912570 ????????`????????
fffff280`b2912578 ????????`????????
fffff280`b2912580 ????????`????????
fffff280`b2912588 ????????`????????
fffff280`b2912590 ????????`????????
fffff280`b2912598 ????????`????????
fffff280`b29125a0 ????????`????????
fffff280`b29125a8 ????????`????????
fffff280`b29125b0 ????????`????????
fffff280`b29125b8 ????????`????????
fffff280`b29125c0 ????????`????????
fffff280`b29125c8 ????????`????????
fffff280`b29125d0 ????????`????????
fffff280`b29125d8 ????????`????????
fffff280`b29125e0 ????????`????????
fffff280`b29125e8 ????????`????????
fffff280`b29125f0 ????????`????????
fffff280`b29125f8 ????????`????????
fffff280`b2912600 ????????`????????
fffff280`b2912608 ????????`????????
fffff280`b2912610 ????????`????????
fffff280`b2912618 ????????`????????
fffff280`b2912620 ????????`????????
fffff280`b2912628 ????????`????????
fffff280`b2912630 ????????`????????
fffff280`b2912638 ????????`????????
fffff280`b2912640 ????????`????????
fffff280`b2912648 ????????`????????
fffff280`b2912650 ????????`????????
fffff280`b2912658 ????????`????????
fffff280`b2912660 ????????`????????
fffff280`b2912668 ????????`????????
fffff280`b2912670 ????????`????????
fffff280`b2912678 ????????`????????
fffff280`b2912680 ????????`????????
fffff280`b2912688 ????????`????????
fffff280`b2912690 ????????`????????
fffff280`b2912698 ????????`????????
fffff280`b29126a0 ????????`????????
fffff280`b29126a8 ????????`????????
fffff280`b29126b0 ????????`????????
fffff280`b29126b8 ????????`????????
fffff280`b29126c0 ????????`????????
fffff280`b29126c8 ????????`????????
fffff280`b29126d0 ????????`????????
fffff280`b29126d8 ????????`????????
fffff280`b29126e0 ????????`????????
fffff280`b29126e8 ????????`????????
fffff280`b29126f0 ????????`????????
fffff280`b29126f8 ????????`????????
fffff280`b2912700 ????????`????????
fffff280`b2912708 ????????`????????
fffff280`b2912710 ????????`????????
fffff280`b2912718 ????????`????????
fffff280`b2912720 ????????`????????
fffff280`b2912728 ????????`????????
fffff280`b2912730 ????????`????????
fffff280`b2912738 ????????`????????
fffff280`b2912740 ????????`????????
fffff280`b2912748 ????????`????????
fffff280`b2912750 ????????`????????
fffff280`b2912758 ????????`????????
fffff280`b2912760 ????????`????????
fffff280`b2912768 ????????`????????
fffff280`b2912770 ????????`????????
fffff280`b2912778 ????????`????????
fffff280`b2912780 ????????`????????
fffff280`b2912788 ????????`????????
fffff280`b2912790 ????????`????????
fffff280`b2912798 ????????`????????
fffff280`b29127a0 ????????`????????
fffff280`b29127a8 ????????`????????
fffff280`b29127b0 ????????`????????
fffff280`b29127b8 ????????`????????
fffff280`b29127c0 ????????`????????
fffff280`b29127c8 ????????`????????
fffff280`b29127d0 ????????`????????
fffff280`b29127d8 ????????`????????
fffff280`b29127e0 ????????`????????
fffff280`b29127e8 ????????`????????
fffff280`b29127f0 ????????`????????
fffff280`b29127f8 ????????`????????
fffff280`b2912800 ????????`????????
fffff280`b2912808 ????????`????????
fffff280`b2912810 ????????`????????
fffff280`b2912818 ????????`????????
fffff280`b2912820 ????????`????????
fffff280`b2912828 ????????`????????
fffff280`b2912830 ????????`????????
fffff280`b2912838 ????????`????????
fffff280`b2912840 ????????`????????
fffff280`b2912848 ????????`????????
fffff280`b2912850 ????????`????????
fffff280`b2912858 ????????`????????
fffff280`b2912860 ????????`????????
fffff280`b2912868 ????????`????????
fffff280`b2912870 ????????`????????
fffff280`b2912878 ????????`????????
fffff280`b2912880 ????????`????????
fffff280`b2912888 ????????`????????
fffff280`b2912890 ????????`????????
fffff280`b2912898 ????????`????????
fffff280`b29128a0 ????????`????????
fffff280`b29128a8 ????????`????????
fffff280`b29128b0 ????????`????????
fffff280`b29128b8 ????????`????????
fffff280`b29128c0 ????????`????????
fffff280`b29128c8 ????????`????????
fffff280`b29128d0 ????????`????????
fffff280`b29128d8 ????????`????????
fffff280`b29128e0 ????????`????????
fffff280`b29128e8 ????????`????????
fffff280`b29128f0 ????????`????????
fffff280`b29128f8 ????????`????????
fffff280`b2912900 ????????`????????
fffff280`b2912908 ????????`????????
fffff280`b2912910 ????????`????????
fffff280`b2912918 ????????`????????
fffff280`b2912920 ????????`????????
fffff280`b2912928 ????????`????????
fffff280`b2912930 ????????`????????
fffff280`b2912938 ????????`????????
fffff280`b2912940 ????????`????????
fffff280`b2912948 ????????`????????
fffff280`b2912950 ????????`????????
fffff280`b2912958 ????????`????????
fffff280`b2912960 ????????`????????
fffff280`b2912968 ????????`????????
fffff280`b2912970 ????????`????????
fffff280`b2912978 ????????`????????
fffff280`b2912980 ????????`????????
fffff280`b2912988 ????????`????????
fffff280`b2912990 ????????`????????
fffff280`b2912998 ????????`????????
fffff280`b29129a0 ????????`????????
fffff280`b29129a8 ????????`????????
fffff280`b29129b0 ????????`????????
fffff280`b29129b8 ????????`????????
fffff280`b29129c0 ????????`????????
fffff280`b29129c8 ????????`????????
fffff280`b29129d0 ????????`????????
fffff280`b29129d8 ????????`????????
fffff280`b29129e0 ????????`????????
fffff280`b29129e8 ????????`????????
fffff280`b29129f0 ????????`????????
fffff280`b29129f8 ????????`????????
fffff280`b2912a00 ????????`????????
fffff280`b2912a08 ????????`????????
fffff280`b2912a10 ????????`????????
fffff280`b2912a18 ????????`????????
fffff280`b2912a20 ????????`????????
fffff280`b2912a28 ????????`????????
fffff280`b2912a30 ????????`????????
fffff280`b2912a38 ????????`????????
fffff280`b2912a40 ????????`????????
fffff280`b2912a48 ????????`????????
fffff280`b2912a50 ????????`????????
fffff280`b2912a58 ????????`????????
fffff280`b2912a60 ????????`????????
fffff280`b2912a68 ????????`????????
fffff280`b2912a70 ????????`????????
fffff280`b2912a78 ????????`????????
fffff280`b2912a80 ????????`????????
fffff280`b2912a88 ????????`????????
fffff280`b2912a90 ????????`????????
fffff280`b2912a98 ????????`????????
fffff280`b2912aa0 ????????`????????
fffff280`b2912aa8 ????????`????????
fffff280`b2912ab0 ????????`????????
fffff280`b2912ab8 ????????`????????
fffff280`b2912ac0 ????????`????????
fffff280`b2912ac8 ????????`????????
fffff280`b2912ad0 ????????`????????
fffff280`b2912ad8 ????????`????????
fffff280`b2912ae0 ????????`????????
fffff280`b2912ae8 ????????`????????
fffff280`b2912af0 ????????`????????
fffff280`b2912af8 ????????`????????
fffff280`b2912b00 ????????`????????
fffff280`b2912b08 ????????`????????
fffff280`b2912b10 ????????`????????
fffff280`b2912b18 ????????`????????
fffff280`b2912b20 ????????`????????
fffff280`b2912b28 ????????`????????
fffff280`b2912b30 ????????`????????
fffff280`b2912b38 ????????`????????
fffff280`b2912b40 ????????`????????
fffff280`b2912b48 ????????`????????
fffff280`b2912b50 ????????`????????
fffff280`b2912b58 ????????`????????
fffff280`b2912b60 ????????`????????
fffff280`b2912b68 ????????`????????
fffff280`b2912b70 ????????`????????
fffff280`b2912b78 ????????`????????
fffff280`b2912b80 ????????`????????
fffff280`b2912b88 ????????`????????
fffff280`b2912b90 ????????`????????
fffff280`b2912b98 ????????`????????
fffff280`b2912ba0 ????????`????????
fffff280`b2912ba8 ????????`????????
fffff280`b2912bb0 ????????`????????
fffff280`b2912bb8 ????????`????????
fffff280`b2912bc0 ????????`????????
fffff280`b2912bc8 ????????`????????
fffff280`b2912bd0 ????????`????????
fffff280`b2912bd8 ????????`????????
fffff280`b2912be0 ????????`????????
fffff280`b2912be8 ????????`????????
fffff280`b2912bf0 ????????`????????
fffff280`b2912bf8 ????????`????????
fffff280`b2912c00 ????????`????????
fffff280`b2912c08 ????????`????????
fffff280`b2912c10 ????????`????????
fffff280`b2912c18 ????????`????????
fffff280`b2912c20 ????????`????????
fffff280`b2912c28 ????????`????????
fffff280`b2912c30 ????????`????????
fffff280`b2912c38 ????????`????????
fffff280`b2912c40 ????????`????????
fffff280`b2912c48 ????????`????????
fffff280`b2912c50 ????????`????????
fffff280`b2912c58 ????????`????????
fffff280`b2912c60 ????????`????????
fffff280`b2912c68 ????????`????????
fffff280`b2912c70 ????????`????????
fffff280`b2912c78 ????????`????????
fffff280`b2912c80 ????????`????????
fffff280`b2912c88 ????????`????????
fffff280`b2912c90 ????????`????????
fffff280`b2912c98 ????????`????????
fffff280`b2912ca0 ????????`????????
fffff280`b2912ca8 ????????`????????
fffff280`b2912cb0 ????????`????????
fffff280`b2912cb8 ????????`????????
fffff280`b2912cc0 ????????`????????
fffff280`b2912cc8 ????????`????????
fffff280`b2912cd0 ????????`????????
fffff280`b2912cd8 ????????`????????
fffff280`b2912ce0 ????????`????????
fffff280`b2912ce8 ????????`????????
fffff280`b2912cf0 ????????`????????
fffff280`b2912cf8 ????????`????????
fffff280`b2912d00 ????????`????????
fffff280`b2912d08 ????????`????????
fffff280`b2912d10 ????????`????????
fffff280`b2912d18 ????????`????????
fffff280`b2912d20 ????????`????????
fffff280`b2912d28 ????????`????????
fffff280`b2912d30 ????????`????????
fffff280`b2912d38 ????????`????????
fffff280`b2912d40 ????????`????????
fffff280`b2912d48 ????????`????????
fffff280`b2912d50 ????????`????????
fffff280`b2912d58 ????????`????????
fffff280`b2912d60 ????????`????????
fffff280`b2912d68 ????????`????????
fffff280`b2912d70 ????????`????????
fffff280`b2912d78 ????????`????????
fffff280`b2912d80 ????????`????????
fffff280`b2912d88 ????????`????????
fffff280`b2912d90 ????????`????????
fffff280`b2912d98 ????????`????????
fffff280`b2912da0 ????????`????????
fffff280`b2912da8 ????????`????????
fffff280`b2912db0 ????????`????????
fffff280`b2912db8 ????????`????????
fffff280`b2912dc0 ????????`????????
fffff280`b2912dc8 ????????`????????
fffff280`b2912dd0 ????????`????????
fffff280`b2912dd8 ????????`????????
fffff280`b2912de0 ????????`????????
fffff280`b2912de8 ????????`????????
fffff280`b2912df0 ????????`????????
fffff280`b2912df8 ????????`????????
fffff280`b2912e00 ????????`????????
fffff280`b2912e08 ????????`????????
fffff280`b2912e10 ????????`????????
fffff280`b2912e18 ????????`????????
fffff280`b2912e20 ????????`????????
fffff280`b2912e28 ????????`????????
fffff280`b2912e30 ????????`????????
fffff280`b2912e38 ????????`????????
fffff280`b2912e40 ????????`????????
fffff280`b2912e48 ????????`????????
fffff280`b2912e50 ????????`????????
fffff280`b2912e58 ????????`????????
fffff280`b2912e60 ????????`????????
fffff280`b2912e68 ????????`????????
fffff280`b2912e70 ????????`????????
fffff280`b2912e78 ????????`????????
fffff280`b2912e80 ????????`????????
fffff280`b2912e88 ????????`????????
fffff280`b2912e90 ????????`????????
fffff280`b2912e98 ????????`????????
fffff280`b2912ea0 ????????`????????
fffff280`b2912ea8 ????????`????????
fffff280`b2912eb0 ????????`????????
fffff280`b2912eb8 ????????`????????
fffff280`b2912ec0 ????????`????????
fffff280`b2912ec8 ????????`????????
fffff280`b2912ed0 ????????`????????
fffff280`b2912ed8 ????????`????????
fffff280`b2912ee0 ????????`????????
fffff280`b2912ee8 ????????`????????
fffff280`b2912ef0 ????????`????????
fffff280`b2912ef8 ????????`????????
fffff280`b2912f00 ????????`????????
fffff280`b2912f08 ????????`????????
fffff280`b2912f10 ????????`????????
fffff280`b2912f18 ????????`????????
fffff280`b2912f20 ????????`????????
fffff280`b2912f28 ????????`????????
fffff280`b2912f30 ????????`????????
fffff280`b2912f38 ????????`????????
fffff280`b2912f40 ????????`????????
fffff280`b2912f48 ????????`????????
fffff280`b2912f50 ????????`????????
fffff280`b2912f58 ????????`????????
fffff280`b2912f60 ????????`????????
fffff280`b2912f68 ????????`????????
fffff280`b2912f70 ????????`????????
fffff280`b2912f78 ????????`????????
fffff280`b2912f80 ????????`????????
fffff280`b2912f88 ????????`????????
fffff280`b2912f90 ????????`????????
fffff280`b2912f98 ????????`????????
fffff280`b2912fa0 ????????`????????
fffff280`b2912fa8 ????????`????????
fffff280`b2912fb0 ????????`????????
fffff280`b2912fb8 ????????`????????
fffff280`b2912fc0 ????????`????????
fffff280`b2912fc8 ????????`????????
fffff280`b2912fd0 ????????`????????
fffff280`b2912fd8 ????????`????????
fffff280`b2912fe0 ????????`????????
fffff280`b2912fe8 ????????`????????
fffff280`b2912ff0 ????????`????????
fffff280`b2912ff8 ????????`????????
fffff280`b2913000 ????????`????????
fffff280`b2913008 ????????`????????
fffff280`b2913010 ????????`????????
fffff280`b2913018 ????????`????????
fffff280`b2913020 ????????`????????
fffff280`b2913028 ????????`????????
fffff280`b2913030 ????????`????????
fffff280`b2913038 ????????`????????
fffff280`b2913040 ????????`????????
fffff280`b2913048 ????????`????????
fffff280`b2913050 ????????`????????
fffff280`b2913058 ????????`????????
fffff280`b2913060 ????????`????????
fffff280`b2913068 ????????`????????
fffff280`b2913070 ????????`????????
fffff280`b2913078 ????????`????????
fffff280`b2913080 ????????`????????
fffff280`b2913088 ????????`????????
fffff280`b2913090 ????????`????????
fffff280`b2913098 ????????`????????
fffff280`b29130a0 ????????`????????
fffff280`b29130a8 ????????`????????
fffff280`b29130b0 ????????`????????
fffff280`b29130b8 ????????`????????
fffff280`b29130c0 ????????`????????
fffff280`b29130c8 ????????`????????
fffff280`b29130d0 ????????`????????
fffff280`b29130d8 ????????`????????
fffff280`b29130e0 ????????`????????
fffff280`b29130e8 ????????`????????
fffff280`b29130f0 ????????`????????
fffff280`b29130f8 ????????`????????
fffff280`b2913100 ????????`????????
fffff280`b2913108 ????????`????????
fffff280`b2913110 ????????`????????
fffff280`b2913118 ????????`????????
fffff280`b2913120 ????????`????????
fffff280`b2913128 ????????`????????
fffff280`b2913130 ????????`????????
fffff280`b2913138 ????????`????????
fffff280`b2913140 ????????`????????
fffff280`b2913148 ????????`????????
fffff280`b2913150 ????????`????????
fffff280`b2913158 ????????`????????
fffff280`b2913160 ????????`????????
fffff280`b2913168 ????????`????????
fffff280`b2913170 ????????`????????
fffff280`b2913178 ????????`????????
fffff280`b2913180 ????????`????????
fffff280`b2913188 ????????`????????
fffff280`b2913190 ????????`????????
fffff280`b2913198 ????????`????????
fffff280`b29131a0 ????????`????????
fffff280`b29131a8 ????????`????????
fffff280`b29131b0 ????????`????????
fffff280`b29131b8 ????????`????????
fffff280`b29131c0 ????????`????????
fffff280`b29131c8 ????????`????????
fffff280`b29131d0 ????????`????????
fffff280`b29131d8 ????????`????????
fffff280`b29131e0 ????????`????????
fffff280`b29131e8 ????????`????????
fffff280`b29131f0 ????????`????????
fffff280`b29131f8 ????????`????????
fffff280`b2913200 ????????`????????
fffff280`b2913208 ????????`????????
fffff280`b2913210 ????????`????????
fffff280`b2913218 ????????`????????
fffff280`b2913220 ????????`????????
fffff280`b2913228 ????????`????????
fffff280`b2913230 ????????`????????
fffff280`b2913238 ????????`????????
fffff280`b2913240 ????????`????????
fffff280`b2913248 ????????`????????
fffff280`b2913250 ????????`????????
fffff280`b2913258 ????????`????????
fffff280`b2913260 ????????`????????
fffff280`b2913268 ????????`????????
fffff280`b2913270 ????????`????????
fffff280`b2913278 ????????`????????
fffff280`b2913280 ????????`????????
fffff280`b2913288 ????????`????????
fffff280`b2913290 ????????`????????
fffff280`b2913298 ????????`????????
fffff280`b29132a0 ????????`????????
fffff280`b29132a8 ????????`????????
fffff280`b29132b0 ????????`????????
fffff280`b29132b8 ????????`????????
fffff280`b29132c0 ????????`????????
fffff280`b29132c8 ????????`????????
fffff280`b29132d0 ????????`????????
fffff280`b29132d8 ????????`????????
fffff280`b29132e0 ????????`????????
fffff280`b29132e8 ????????`????????
fffff280`b29132f0 ????????`????????
fffff280`b29132f8 ????????`????????
fffff280`b2913300 ????????`????????
fffff280`b2913308 ????????`????????
fffff280`b2913310 ????????`????????
fffff280`b2913318 ????????`????????
fffff280`b2913320 ????????`????????
fffff280`b2913328 ????????`????????
fffff280`b2913330 ????????`????????
fffff280`b2913338 ????????`????????
fffff280`b2913340 ????????`????????
fffff280`b2913348 ????????`????????
fffff280`b2913350 ????????`????????
fffff280`b2913358 ????????`????????
fffff280`b2913360 ????????`????????
fffff280`b2913368 ????????`????????
fffff280`b2913370 ????????`????????
fffff280`b2913378 ????????`????????
fffff280`b2913380 ????????`????????
fffff280`b2913388 ????????`????????
fffff280`b2913390 ????????`????????
fffff280`b2913398 ????????`????????
fffff280`b29133a0 ????????`????????
fffff280`b29133a8 ????????`????????
fffff280`b29133b0 ????????`????????
fffff280`b29133b8 ????????`????????
fffff280`b29133c0 ????????`????????
fffff280`b29133c8 ????????`????????
fffff280`b29133d0 ????????`????????
fffff280`b29133d8 ????????`????????
fffff280`b29133e0 ????????`????????
fffff280`b29133e8 ????????`????????
fffff280`b29133f0 ????????`????????
fffff280`b29133f8 ????????`????????
fffff280`b2913400 ????????`????????
fffff280`b2913408 ????????`????????
fffff280`b2913410 ????????`????????
fffff280`b2913418 ????????`????????
fffff280`b2913420 ????????`????????
fffff280`b2913428 ????????`????????
fffff280`b2913430 ????????`????????
fffff280`b2913438 ????????`????????
fffff280`b2913440 ????????`????????
fffff280`b2913448 ????????`????????
fffff280`b2913450 ????????`????????
fffff280`b2913458 ????????`????????
fffff280`b2913460 ????????`????????
fffff280`b2913468 ????????`????????
fffff280`b2913470 ????????`????????
fffff280`b2913478 ????????`????????
fffff280`b2913480 ????????`????????
fffff280`b2913488 ????????`????????
fffff280`b2913490 ????????`????????
fffff280`b2913498 ????????`????????
fffff280`b29134a0 ????????`????????
fffff280`b29134a8 ????????`????????
fffff280`b29134b0 ????????`????????
fffff280`b29134b8 ????????`????????
fffff280`b29134c0 ????????`????????
fffff280`b29134c8 ????????`????????
fffff280`b29134d0 ????????`????????
fffff280`b29134d8 ????????`????????
fffff280`b29134e0 ????????`????????
fffff280`b29134e8 ????????`????????
fffff280`b29134f0 ????????`????????
fffff280`b29134f8 ????????`????????
fffff280`b2913500 ????????`????????
fffff280`b2913508 ????????`????????
fffff280`b2913510 ????????`????????
fffff280`b2913518 ????????`????????
fffff280`b2913520 ????????`????????
fffff280`b2913528 ????????`????????
fffff280`b2913530 ????????`????????
fffff280`b2913538 ????????`????????
fffff280`b2913540 ????????`????????
fffff280`b2913548 ????????`????????
fffff280`b2913550 ????????`????????
fffff280`b2913558 ????????`????????
fffff280`b2913560 ????????`????????
fffff280`b2913568 ????????`????????
fffff280`b2913570 ????????`????????
fffff280`b2913578 ????????`????????
fffff280`b2913580 ????????`????????
fffff280`b2913588 ????????`????????
fffff280`b2913590 ????????`????????
fffff280`b2913598 ????????`????????
fffff280`b29135a0 ????????`????????
fffff280`b29135a8 ????????`????????
fffff280`b29135b0 ????????`????????
fffff280`b29135b8 ????????`????????
fffff280`b29135c0 ????????`????????
fffff280`b29135c8 ????????`????????
fffff280`b29135d0 ????????`????????
fffff280`b29135d8 ????????`????????
fffff280`b29135e0 ????????`????????
fffff280`b29135e8 ????????`????????
fffff280`b29135f0 ????????`????????
fffff280`b29135f8 ????????`????????
fffff280`b2913600 ????????`????????
fffff280`b2913608 ????????`????????
fffff280`b2913610 ????????`????????
fffff280`b2913618 ????????`????????
fffff280`b2913620 ????????`????????
fffff280`b2913628 ????????`????????
fffff280`b2913630 ????????`????????
fffff280`b2913638 ????????`????????
fffff280`b2913640 ????????`????????
fffff280`b2913648 ????????`????????
fffff280`b2913650 ????????`????????
fffff280`b2913658 ????????`????????
fffff280`b2913660 ????????`????????
fffff280`b2913668 ????????`????????
fffff280`b2913670 ????????`????????
fffff280`b2913678 ????????`????????
fffff280`b2913680 ????????`????????
fffff280`b2913688 ????????`????????
fffff280`b2913690 ????????`????????
fffff280`b2913698 ????????`????????
fffff280`b29136a0 ????????`????????
fffff280`b29136a8 ????????`????????
fffff280`b29136b0 ????????`????????
fffff280`b29136b8 ????????`????????
fffff280`b29136c0 ????????`????????
fffff280`b29136c8 ????????`????????
fffff280`b29136d0 ????????`????????
fffff280`b29136d8 ????????`????????
fffff280`b29136e0 ????????`????????
fffff280`b29136e8 ????????`????????
fffff280`b29136f0 ????????`????????
fffff280`b29136f8 ????????`????????
fffff280`b2913700 ????????`????????
fffff280`b2913708 ????????`????????
fffff280`b2913710 ????????`????????
fffff280`b2913718 ????????`????????
fffff280`b2913720 ????????`????????
fffff280`b2913728 ????????`????????
fffff280`b2913730 ????????`????????
fffff280`b2913738 ????????`????????
fffff280`b2913740 ????????`????????
fffff280`b2913748 ????????`????????
fffff280`b2913750 ????????`????????
fffff280`b2913758 ????????`????????
fffff280`b2913760 ????????`????????
fffff280`b2913768 ????????`????????
fffff280`b2913770 ????????`????????
fffff280`b2913778 ????????`????????
fffff280`b2913780 ????????`????????
fffff280`b2913788 ????????`????????
fffff280`b2913790 ????????`????????
fffff280`b2913798 ????????`????????
fffff280`b29137a0 ????????`????????
fffff280`b29137a8 ????????`????????
fffff280`b29137b0 ????????`????????
fffff280`b29137b8 ????????`????????
fffff280`b29137c0 ????????`????????
fffff280`b29137c8 ????????`????????
fffff280`b29137d0 ????????`????????
fffff280`b29137d8 ????????`????????
fffff280`b29137e0 ????????`????????
fffff280`b29137e8 ????????`????????
fffff280`b29137f0 ????????`????????
fffff280`b29137f8 ????????`????????
fffff280`b2913800 ????????`????????
fffff280`b2913808 ????????`????????
fffff280`b2913810 ????????`????????
fffff280`b2913818 ????????`????????
fffff280`b2913820 ????????`????????
fffff280`b2913828 ????????`????????
fffff280`b2913830 ????????`????????
fffff280`b2913838 ????????`????????
fffff280`b2913840 ????????`????????
fffff280`b2913848 ????????`????????
fffff280`b2913850 ????????`????????
fffff280`b2913858 ????????`????????
fffff280`b2913860 ????????`????????
fffff280`b2913868 ????????`????????
fffff280`b2913870 ????????`????????
fffff280`b2913878 ????????`????????
fffff280`b2913880 ????????`????????
fffff280`b2913888 ????????`????????
fffff280`b2913890 ????????`????????
fffff280`b2913898 ????????`????????
fffff280`b29138a0 ????????`????????
fffff280`b29138a8 ????????`????????
fffff280`b29138b0 ????????`????????
fffff280`b29138b8 ????????`????????
fffff280`b29138c0 ????????`????????
fffff280`b29138c8 ????????`????????
fffff280`b29138d0 ????????`????????
fffff280`b29138d8 ????????`????????
fffff280`b29138e0 ????????`????????
fffff280`b29138e8 ????????`????????
fffff280`b29138f0 ????????`????????
fffff280`b29138f8 ????????`????????
fffff280`b2913900 ????????`????????
fffff280`b2913908 ????????`????????
fffff280`b2913910 ????????`????????
fffff280`b2913918 ????????`????????
fffff280`b2913920 ????????`????????
fffff280`b2913928 ????????`????????
fffff280`b2913930 ????????`????????
fffff280`b2913938 ????????`????????
fffff280`b2913940 ????????`????????
fffff280`b2913948 ????????`????????
fffff280`b2913950 ????????`????????
fffff280`b2913958 ????????`????????
fffff280`b2913960 ????????`????????
fffff280`b2913968 ????????`????????
fffff280`b2913970 ????????`????????
fffff280`b2913978 ????????`????????
fffff280`b2913980 ????????`????????
fffff280`b2913988 ????????`????????
fffff280`b2913990 ????????`????????
fffff280`b2913998 ????????`????????
fffff280`b29139a0 ????????`????????
fffff280`b29139a8 ????????`????????
fffff280`b29139b0 ????????`????????
fffff280`b29139b8 ????????`????????
fffff280`b29139c0 ????????`????????
fffff280`b29139c8 ????????`????????
fffff280`b29139d0 ????????`????????
fffff280`b29139d8 ????????`????????
fffff280`b29139e0 ????????`????????
fffff280`b29139e8 ????????`????????
fffff280`b29139f0 ????????`????????
fffff280`b29139f8 ????????`????????
fffff280`b2913a00 ????????`????????
fffff280`b2913a08 ????????`????????
fffff280`b2913a10 ????????`????????
fffff280`b2913a18 ????????`????????
fffff280`b2913a20 ????????`????????
fffff280`b2913a28 ????????`????????
fffff280`b2913a30 ????????`????????
fffff280`b2913a38 ????????`????????
fffff280`b2913a40 ????????`????????
fffff280`b2913a48 ????????`????????
fffff280`b2913a50 ????????`????????
fffff280`b2913a58 ????????`????????
fffff280`b2913a60 ????????`????????
fffff280`b2913a68 ????????`????????
fffff280`b2913a70 ????????`????????
fffff280`b2913a78 ????????`????????
fffff280`b2913a80 ????????`????????
fffff280`b2913a88 ????????`????????
fffff280`b2913a90 ????????`????????
fffff280`b2913a98 ????????`????????
fffff280`b2913aa0 ????????`????????
fffff280`b2913aa8 ????????`????????
fffff280`b2913ab0 ????????`????????
fffff280`b2913ab8 ????????`????????
fffff280`b2913ac0 ????????`????????
fffff280`b2913ac8 ????????`????????
fffff280`b2913ad0 ????????`????????
fffff280`b2913ad8 ????????`????????
fffff280`b2913ae0 ????????`????????
fffff280`b2913ae8 ????????`????????
fffff280`b2913af0 ????????`????????
fffff280`b2913af8 ????????`????????
fffff280`b2913b00 ????????`????????
fffff280`b2913b08 ????????`????????
fffff280`b2913b10 ????????`????????
fffff280`b2913b18 ????????`????????
fffff280`b2913b20 ????????`????????
fffff280`b2913b28 ????????`????????
fffff280`b2913b30 ????????`????????
fffff280`b2913b38 ????????`????????
fffff280`b2913b40 ????????`????????
fffff280`b2913b48 ????????`????????
fffff280`b2913b50 ????????`????????
fffff280`b2913b58 ????????`????????
fffff280`b2913b60 ????????`????????
fffff280`b2913b68 ????????`????????
fffff280`b2913b70 ????????`????????
fffff280`b2913b78 ????????`????????
fffff280`b2913b80 ????????`????????
fffff280`b2913b88 ????????`????????
fffff280`b2913b90 ????????`????????
fffff280`b2913b98 ????????`????????
fffff280`b2913ba0 ????????`????????
fffff280`b2913ba8 ????????`????????
fffff280`b2913bb0 ????????`????????
fffff280`b2913bb8 ????????`????????
fffff280`b2913bc0 ????????`????????
fffff280`b2913bc8 ????????`????????
fffff280`b2913bd0 ????????`????????
fffff280`b2913bd8 ????????`????????
fffff280`b2913be0 ????????`????????
fffff280`b2913be8 ????????`????????
fffff280`b2913bf0 ????????`????????
fffff280`b2913bf8 ????????`????????
fffff280`b2913c00 ????????`????????
fffff280`b2913c08 ????????`????????
fffff280`b2913c10 ????????`????????
fffff280`b2913c18 ????????`????????
fffff280`b2913c20 ????????`????????
fffff280`b2913c28 ????????`????????
fffff280`b2913c30 ????????`????????
fffff280`b2913c38 ????????`????????
fffff280`b2913c40 ????????`????????
fffff280`b2913c48 ????????`????????
fffff280`b2913c50 ????????`????????
fffff280`b2913c58 ????????`????????
fffff280`b2913c60 ????????`????????
fffff280`b2913c68 ????????`????????
fffff280`b2913c70 ????????`????????
fffff280`b2913c78 ????????`????????
fffff280`b2913c80 ????????`????????
fffff280`b2913c88 ????????`????????
fffff280`b2913c90 ????????`????????
fffff280`b2913c98 ????????`????????
fffff280`b2913ca0 ????????`????????
fffff280`b2913ca8 ????????`????????
fffff280`b2913cb0 ????????`????????
fffff280`b2913cb8 ????????`????????
fffff280`b2913cc0 ????????`????????
fffff280`b2913cc8 ????????`????????
fffff280`b2913cd0 ????????`????????
fffff280`b2913cd8 ????????`????????
fffff280`b2913ce0 ????????`????????
fffff280`b2913ce8 ????????`????????
fffff280`b2913cf0 ????????`????????
fffff280`b2913cf8 ????????`????????
fffff280`b2913d00 ????????`????????
fffff280`b2913d08 ????????`????????
fffff280`b2913d10 ????????`????????
fffff280`b2913d18 ????????`????????
fffff280`b2913d20 ????????`????????
fffff280`b2913d28 ????????`????????
fffff280`b2913d30 ????????`????????
fffff280`b2913d38 ????????`????????
fffff280`b2913d40 ????????`????????
fffff280`b2913d48 ????????`????????
fffff280`b2913d50 ????????`????????
fffff280`b2913d58 ????????`????????
fffff280`b2913d60 ????????`????????
fffff280`b2913d68 ????????`????????
fffff280`b2913d70 ????????`????????
fffff280`b2913d78 ????????`????????
fffff280`b2913d80 ????????`????????
fffff280`b2913d88 ????????`????????
fffff280`b2913d90 ????????`????????
fffff280`b2913d98 ????????`????????
fffff280`b2913da0 ????????`????????
fffff280`b2913da8 ????????`????????
fffff280`b2913db0 ????????`????????
fffff280`b2913db8 ????????`????????
fffff280`b2913dc0 ????????`????????
fffff280`b2913dc8 ????????`????????
fffff280`b2913dd0 ????????`????????
fffff280`b2913dd8 ????????`????????
fffff280`b2913de0 ????????`????????
fffff280`b2913de8 ????????`????????
fffff280`b2913df0 ????????`????????
fffff280`b2913df8 ????????`????????
fffff280`b2913e00 ????????`????????
fffff280`b2913e08 ????????`????????
fffff280`b2913e10 ????????`????????
fffff280`b2913e18 ????????`????????
fffff280`b2913e20 ????????`????????
fffff280`b2913e28 ????????`????????
fffff280`b2913e30 ????????`????????
fffff280`b2913e38 ????????`????????
fffff280`b2913e40 ????????`????????
fffff280`b2913e48 ????????`????????
fffff280`b2913e50 ????????`????????
fffff280`b2913e58 ????????`????????
fffff280`b2913e60 ????????`????????
fffff280`b2913e68 ????????`????????
fffff280`b2913e70 ????????`????????
fffff280`b2913e78 ????????`????????
fffff280`b2913e80 ????????`????????
fffff280`b2913e88 ????????`????????
fffff280`b2913e90 ????????`????????
fffff280`b2913e98 ????????`????????
fffff280`b2913ea0 ????????`????????
fffff280`b2913ea8 ????????`????????
fffff280`b2913eb0 ????????`????????
fffff280`b2913eb8 ????????`????????
fffff280`b2913ec0 ????????`????????
fffff280`b2913ec8 ????????`????????
fffff280`b2913ed0 ????????`????????
fffff280`b2913ed8 ????????`????????
fffff280`b2913ee0 ????????`????????
fffff280`b2913ee8 ????????`????????
fffff280`b2913ef0 ????????`????????
fffff280`b2913ef8 ????????`????????
fffff280`b2913f00 ????????`????????
fffff280`b2913f08 ????????`????????
fffff280`b2913f10 ????????`????????
fffff280`b2913f18 ????????`????????
fffff280`b2913f20 ????????`????????
fffff280`b2913f28 ????????`????????
fffff280`b2913f30 ????????`????????
fffff280`b2913f38 ????????`????????
fffff280`b2913f40 ????????`????????
fffff280`b2913f48 ????????`????????
fffff280`b2913f50 ????????`????????
fffff280`b2913f58 ????????`????????
fffff280`b2913f60 ????????`????????
fffff280`b2913f68 ????????`????????
fffff280`b2913f70 ????????`????????
fffff280`b2913f78 ????????`????????
fffff280`b2913f80 ????????`????????
fffff280`b2913f88 ????????`????????
fffff280`b2913f90 ????????`????????
fffff280`b2913f98 ????????`????????
fffff280`b2913fa0 ????????`????????
fffff280`b2913fa8 ????????`????????
fffff280`b2913fb0 ????????`????????
fffff280`b2913fb8 ????????`????????
fffff280`b2913fc0 ????????`????????
fffff280`b2913fc8 ????????`????????
fffff280`b2913fd0 ????????`????????
fffff280`b2913fd8 ????????`????????
fffff280`b2913fe0 ????????`????????
fffff280`b2913fe8 ????????`????????
fffff280`b2913ff0 ????????`????????
fffff280`b2913ff8 ????????`????????
fffff280`b2914000 ????????`????????
fffff280`b2914008 ????????`????????
fffff280`b2914010 ????????`????????
fffff280`b2914018 ????????`????????
fffff280`b2914020 ????????`????????
fffff280`b2914028 ????????`????????
fffff280`b2914030 ????????`????????
fffff280`b2914038 ????????`????????
fffff280`b2914040 ????????`????????
fffff280`b2914048 ????????`????????
fffff280`b2914050 ????????`????????
fffff280`b2914058 ????????`????????
fffff280`b2914060 ????????`????????
fffff280`b2914068 ????????`????????
fffff280`b2914070 ????????`????????
fffff280`b2914078 ????????`????????
fffff280`b2914080 ????????`????????
fffff280`b2914088 ????????`????????
fffff280`b2914090 ????????`????????
fffff280`b2914098 ????????`????????
fffff280`b29140a0 ????????`????????
fffff280`b29140a8 ????????`????????
fffff280`b29140b0 ????????`????????
fffff280`b29140b8 ????????`????????
fffff280`b29140c0 ????????`????????
fffff280`b29140c8 ????????`????????
fffff280`b29140d0 ????????`????????
fffff280`b29140d8 ????????`????????
fffff280`b29140e0 ????????`????????
fffff280`b29140e8 ????????`????????
fffff280`b29140f0 ????????`????????
fffff280`b29140f8 ????????`????????
fffff280`b2914100 ????????`????????
fffff280`b2914108 ????????`????????
fffff280`b2914110 ????????`????????
fffff280`b2914118 ????????`????????
fffff280`b2914120 ????????`????????
fffff280`b2914128 ????????`????????
fffff280`b2914130 ????????`????????
fffff280`b2914138 ????????`????????
fffff280`b2914140 ????????`????????
fffff280`b2914148 ????????`????????
fffff280`b2914150 ????????`????????
fffff280`b2914158 ????????`????????
fffff280`b2914160 ????????`????????
fffff280`b2914168 ????????`????????
fffff280`b2914170 ????????`????????
fffff280`b2914178 ????????`????????
fffff280`b2914180 ????????`????????
fffff280`b2914188 ????????`????????
fffff280`b2914190 ????????`????????
fffff280`b2914198 ????????`????????
fffff280`b29141a0 ????????`????????
fffff280`b29141a8 ????????`????????
fffff280`b29141b0 ????????`????????
fffff280`b29141b8 ????????`????????
fffff280`b29141c0 ????????`????????
fffff280`b29141c8 ????????`????????
fffff280`b29141d0 ????????`????????
fffff280`b29141d8 ????????`????????
fffff280`b29141e0 ????????`????????
fffff280`b29141e8 ????????`????????
fffff280`b29141f0 ????????`????????
fffff280`b29141f8 ????????`????????
fffff280`b2914200 ????????`????????
fffff280`b2914208 ????????`????????
fffff280`b2914210 ????????`????????
fffff280`b2914218 ????????`????????
fffff280`b2914220 ????????`????????
fffff280`b2914228 ????????`????????
fffff280`b2914230 ????????`????????
fffff280`b2914238 ????????`????????
fffff280`b2914240 ????????`????????
fffff280`b2914248 ????????`????????
fffff280`b2914250 ????????`????????
fffff280`b2914258 ????????`????????
fffff280`b2914260 ????????`????????
fffff280`b2914268 ????????`????????
fffff280`b2914270 ????????`????????
fffff280`b2914278 ????????`????????
fffff280`b2914280 ????????`????????
fffff280`b2914288 ????????`????????
fffff280`b2914290 ????????`????????
fffff280`b2914298 ????????`????????
fffff280`b29142a0 ????????`????????
fffff280`b29142a8 ????????`????????
fffff280`b29142b0 ????????`????????
fffff280`b29142b8 ????????`????????
fffff280`b29142c0 ????????`????????
fffff280`b29142c8 ????????`????????
fffff280`b29142d0 ????????`????????
fffff280`b29142d8 ????????`????????
fffff280`b29142e0 ????????`????????
fffff280`b29142e8 ????????`????????
fffff280`b29142f0 ????????`????????
fffff280`b29142f8 ????????`????????
fffff280`b2914300 ????????`????????
fffff280`b2914308 ????????`????????
fffff280`b2914310 ????????`????????
fffff280`b2914318 ????????`????????
fffff280`b2914320 ????????`????????
fffff280`b2914328 ????????`????????
fffff280`b2914330 ????????`????????
fffff280`b2914338 ????????`????????
fffff280`b2914340 ????????`????????
fffff280`b2914348 ????????`????????
fffff280`b2914350 ????????`????????
fffff280`b2914358 ????????`????????
fffff280`b2914360 ????????`????????
fffff280`b2914368 ????????`????????
fffff280`b2914370 ????????`????????
fffff280`b2914378 ????????`????????
fffff280`b2914380 ????????`????????
fffff280`b2914388 ????????`????????
fffff280`b2914390 ????????`????????
fffff280`b2914398 ????????`????????
fffff280`b29143a0 ????????`????????
fffff280`b29143a8 ????????`????????
fffff280`b29143b0 ????????`????????
fffff280`b29143b8 ????????`????????
fffff280`b29143c0 ????????`????????
fffff280`b29143c8 ????????`????????
fffff280`b29143d0 ????????`????????
fffff280`b29143d8 ????????`????????
fffff280`b29143e0 ????????`????????
fffff280`b29143e8 ????????`????????
fffff280`b29143f0 ????????`????????
fffff280`b29143f8 ????????`????????
fffff280`b2914400 ????????`????????
fffff280`b2914408 ????????`????????
fffff280`b2914410 ????????`????????
fffff280`b2914418 ????????`????????
fffff280`b2914420 ????????`????????
fffff280`b2914428 ????????`????????
fffff280`b2914430 ????????`????????
fffff280`b2914438 ????????`????????
fffff280`b2914440 ????????`????????
fffff280`b2914448 ????????`????????
fffff280`b2914450 ????????`????????
fffff280`b2914458 ????????`????????
fffff280`b2914460 ????????`????????
fffff280`b2914468 ????????`????????
fffff280`b2914470 ????????`????????
fffff280`b2914478 ????????`????????
fffff280`b2914480 ????????`????????
fffff280`b2914488 ????????`????????
fffff280`b2914490 ????????`????????
fffff280`b2914498 ????????`????????
fffff280`b29144a0 ????????`????????
fffff280`b29144a8 ????????`????????
fffff280`b29144b0 ????????`????????
fffff280`b29144b8 ????????`????????
fffff280`b29144c0 ????????`????????
fffff280`b29144c8 ????????`????????
fffff280`b29144d0 ????????`????????
fffff280`b29144d8 ????????`????????
fffff280`b29144e0 ????????`????????
fffff280`b29144e8 ????????`????????
fffff280`b29144f0 ????????`????????
fffff280`b29144f8 ????????`????????
fffff280`b2914500 ????????`????????
fffff280`b2914508 ????????`????????
fffff280`b2914510 ????????`????????
fffff280`b2914518 ????????`????????
fffff280`b2914520 ????????`????????
fffff280`b2914528 ????????`????????
fffff280`b2914530 ????????`????????
fffff280`b2914538 ????????`????????
fffff280`b2914540 ????????`????????
fffff280`b2914548 ????????`????????
fffff280`b2914550 ????????`????????
fffff280`b2914558 ????????`????????
fffff280`b2914560 ????????`????????
fffff280`b2914568 ????????`????????
fffff280`b2914570 ????????`????????
fffff280`b2914578 ????????`????????
fffff280`b2914580 ????????`????????
fffff280`b2914588 ????????`????????
fffff280`b2914590 ????????`????????
fffff280`b2914598 ????????`????????
fffff280`b29145a0 ????????`????????
fffff280`b29145a8 ????????`????????
fffff280`b29145b0 ????????`????????
fffff280`b29145b8 ????????`????????
fffff280`b29145c0 ????????`????????
fffff280`b29145c8 ????????`????????
fffff280`b29145d0 ????????`????????
fffff280`b29145d8 ????????`????????
fffff280`b29145e0 ????????`????????
fffff280`b29145e8 ????????`????????
fffff280`b29145f0 ????????`????????
fffff280`b29145f8 ????????`????????
fffff280`b2914600 ????????`????????
fffff280`b2914608 ????????`????????
fffff280`b2914610 ????????`????????
fffff280`b2914618 ????????`????????
fffff280`b2914620 ????????`????????
fffff280`b2914628 ????????`????????
fffff280`b2914630 ????????`????????
fffff280`b2914638 ????????`????????
fffff280`b2914640 ????????`????????
fffff280`b2914648 ????????`????????
fffff280`b2914650 ????????`????????
fffff280`b2914658 ????????`????????
fffff280`b2914660 ????????`????????
fffff280`b2914668 ????????`????????
fffff280`b2914670 ????????`????????
fffff280`b2914678 ????????`????????
fffff280`b2914680 ????????`????????
fffff280`b2914688 ????????`????????
fffff280`b2914690 ????????`????????
fffff280`b2914698 ????????`????????
fffff280`b29146a0 ????????`????????
fffff280`b29146a8 ????????`????????
fffff280`b29146b0 ????????`????????
fffff280`b29146b8 ????????`????????
fffff280`b29146c0 ????????`????????
fffff280`b29146c8 ????????`????????
fffff280`b29146d0 ????????`????????
fffff280`b29146d8 ????????`????????
fffff280`b29146e0 ????????`????????
fffff280`b29146e8 ????????`????????
fffff280`b29146f0 ????????`????????
fffff280`b29146f8 ????????`????????
fffff280`b2914700 ????????`????????
fffff280`b2914708 ????????`????????
fffff280`b2914710 ????????`????????
fffff280`b2914718 ????????`????????
fffff280`b2914720 ????????`????????
fffff280`b2914728 ????????`????????
fffff280`b2914730 ????????`????????
fffff280`b2914738 ????????`????????
fffff280`b2914740 ????????`????????
fffff280`b2914748 ????????`????????
fffff280`b2914750 ????????`????????
fffff280`b2914758 ????????`????????
fffff280`b2914760 ????????`????????
fffff280`b2914768 ????????`????????
fffff280`b2914770 ????????`????????
fffff280`b2914778 ????????`????????
fffff280`b2914780 ????????`????????
fffff280`b2914788 ????????`????????
fffff280`b2914790 ????????`????????
fffff280`b2914798 ????????`????????
fffff280`b29147a0 ????????`????????
fffff280`b29147a8 ????????`????????
fffff280`b29147b0 ????????`????????
fffff280`b29147b8 ????????`????????
fffff280`b29147c0 ????????`????????
fffff280`b29147c8 ????????`????????
fffff280`b29147d0 ????????`????????
fffff280`b29147d8 ????????`????????
fffff280`b29147e0 ????????`????????
fffff280`b29147e8 ????????`????????
fffff280`b29147f0 ????????`????????
fffff280`b29147f8 ????????`????????
fffff280`b2914800 ????????`????????
fffff280`b2914808 ????????`????????
fffff280`b2914810 ????????`????????
fffff280`b2914818 ????????`????????
fffff280`b2914820 ????????`????????
fffff280`b2914828 ????????`????????
fffff280`b2914830 ????????`????????
fffff280`b2914838 ????????`????????
fffff280`b2914840 ????????`????????
fffff280`b2914848 ????????`????????
fffff280`b2914850 ????????`????????
fffff280`b2914858 ????????`????????
fffff280`b2914860 ????????`????????
fffff280`b2914868 ????????`????????
fffff280`b2914870 ????????`????????
fffff280`b2914878 ????????`????????
fffff280`b2914880 ????????`????????
fffff280`b2914888 ????????`????????
fffff280`b2914890 ????????`????????
fffff280`b2914898 ????????`????????
fffff280`b29148a0 ????????`????????
fffff280`b29148a8 ????????`????????
fffff280`b29148b0 ????????`????????
fffff280`b29148b8 ????????`????????
fffff280`b29148c0 ????????`????????
fffff280`b29148c8 ????????`????????
fffff280`b29148d0 ????????`????????
fffff280`b29148d8 ????????`????????
fffff280`b29148e0 ????????`????????
fffff280`b29148e8 ????????`????????
fffff280`b29148f0 ????????`????????
fffff280`b29148f8 ????????`????????
fffff280`b2914900 ????????`????????
fffff280`b2914908 ????????`????????
fffff280`b2914910 ????????`????????
fffff280`b2914918 ????????`????????
fffff280`b2914920 ????????`????????
fffff280`b2914928 ????????`????????
fffff280`b2914930 ????????`????????
fffff280`b2914938 ????????`????????
fffff280`b2914940 ????????`????????
fffff280`b2914948 ????????`????????
fffff280`b2914950 ????????`????????
fffff280`b2914958 ????????`????????
fffff280`b2914960 ????????`????????
fffff280`b2914968 ????????`????????
fffff280`b2914970 ????????`????????
fffff280`b2914978 ????????`????????
fffff280`b2914980 ????????`????????
fffff280`b2914988 ????????`????????
fffff280`b2914990 ????????`????????
fffff280`b2914998 ????????`????????
fffff280`b29149a0 ????????`????????
fffff280`b29149a8 ????????`????????
fffff280`b29149b0 ????????`????????
fffff280`b29149b8 ????????`????????
fffff280`b29149c0 ????????`????????
fffff280`b29149c8 ????????`????????
fffff280`b29149d0 ????????`????????
fffff280`b29149d8 ????????`????????
fffff280`b29149e0 ????????`????????
fffff280`b29149e8 ????????`????????
fffff280`b29149f0 ????????`????????
fffff280`b29149f8 ????????`????????
fffff280`b2914a00 ????????`????????
fffff280`b2914a08 ????????`????????
fffff280`b2914a10 ????????`????????
fffff280`b2914a18 ????????`????????
fffff280`b2914a20 ????????`????????
fffff280`b2914a28 ????????`????????
fffff280`b2914a30 ????????`????????
fffff280`b2914a38 ????????`????????
fffff280`b2914a40 ????????`????????
fffff280`b2914a48 ????????`????????
fffff280`b2914a50 ????????`????????
fffff280`b2914a58 ????????`????????
fffff280`b2914a60 ????????`????????
fffff280`b2914a68 ????????`????????
fffff280`b2914a70 ????????`????????
fffff280`b2914a78 ????????`????????
fffff280`b2914a80 ????????`????????
fffff280`b2914a88 ????????`????????
fffff280`b2914a90 ????????`????????
fffff280`b2914a98 ????????`????????
fffff280`b2914aa0 ????????`????????
fffff280`b2914aa8 ????????`????????
fffff280`b2914ab0 ????????`????????
fffff280`b2914ab8 ????????`????????
fffff280`b2914ac0 ????????`????????
fffff280`b2914ac8 ????????`????????
fffff280`b2914ad0 ????????`????????
fffff280`b2914ad8 ????????`????????
fffff280`b2914ae0 ????????`????????
fffff280`b2914ae8 ????????`????????
fffff280`b2914af0 ????????`????????
fffff280`b2914af8 ????????`????????
fffff280`b2914b00 ????????`????????
fffff280`b2914b08 ????????`????????
fffff280`b2914b10 ????????`????????
fffff280`b2914b18 ????????`????????
fffff280`b2914b20 ????????`????????
fffff280`b2914b28 ????????`????????
fffff280`b2914b30 ????????`????????
fffff280`b2914b38 ????????`????????
fffff280`b2914b40 ????????`????????
fffff280`b2914b48 ????????`????????
fffff280`b2914b50 ????????`????????
fffff280`b2914b58 ????????`????????
fffff280`b2914b60 ????????`????????
fffff280`b2914b68 ????????`????????
fffff280`b2914b70 ????????`????????
fffff280`b2914b78 ????????`????????
fffff280`b2914b80 ????????`????????
fffff280`b2914b88 ????????`????????
fffff280`b2914b90 ????????`????????
fffff280`b2914b98 ????????`????????
fffff280`b2914ba0 ????????`????????
fffff280`b2914ba8 ????????`????????
fffff280`b2914bb0 ????????`????????
fffff280`b2914bb8 ????????`????????
fffff280`b2914bc0 ????????`????????
fffff280`b2914bc8 ????????`????????
fffff280`b2914bd0 ????????`????????
fffff280`b2914bd8 ????????`????????
fffff280`b2914be0 ????????`????????
fffff280`b2914be8 ????????`????????
fffff280`b2914bf0 ????????`????????
fffff280`b2914bf8 ????????`????????
fffff280`b2914c00 ????????`????????
fffff280`b2914c08 ????????`????????
fffff280`b2914c10 ????????`????????
fffff280`b2914c18 ????????`????????
fffff280`b2914c20 ????????`????????
fffff280`b2914c28 ????????`????????
fffff280`b2914c30 ????????`????????
fffff280`b2914c38 ????????`????????
fffff280`b2914c40 ????????`????????
fffff280`b2914c48 ????????`????????
fffff280`b2914c50 ????????`????????
fffff280`b2914c58 ????????`????????
fffff280`b2914c60 ????????`????????
fffff280`b2914c68 ????????`????????
fffff280`b2914c70 ????????`????????
fffff280`b2914c78 ????????`????????
fffff280`b2914c80 ????????`????????
fffff280`b2914c88 ????????`????????
fffff280`b2914c90 ????????`????????
fffff280`b2914c98 ????????`????????
fffff280`b2914ca0 ????????`????????
fffff280`b2914ca8 ????????`????????
fffff280`b2914cb0 ????????`????????
fffff280`b2914cb8 ????????`????????
fffff280`b2914cc0 ????????`????????
fffff280`b2914cc8 ????????`????????
fffff280`b2914cd0 ????????`????????
fffff280`b2914cd8 ????????`????????
fffff280`b2914ce0 ????????`????????
fffff280`b2914ce8 ????????`????????
fffff280`b2914cf0 ????????`????????
fffff280`b2914cf8 ????????`????????
fffff280`b2914d00 ????????`????????
fffff280`b2914d08 ????????`????????
fffff280`b2914d10 ????????`????????
fffff280`b2914d18 ????????`????????
fffff280`b2914d20 ????????`????????
fffff280`b2914d28 ????????`????????
fffff280`b2914d30 ????????`????????
fffff280`b2914d38 ????????`????????
fffff280`b2914d40 ????????`????????
fffff280`b2914d48 ????????`????????
fffff280`b2914d50 ????????`????????
fffff280`b2914d58 ????????`????????
fffff280`b2914d60 ????????`????????
fffff280`b2914d68 ????????`????????
fffff280`b2914d70 ????????`????????
fffff280`b2914d78 ????????`????????
fffff280`b2914d80 ????????`????????
fffff280`b2914d88 ????????`????????
fffff280`b2914d90 ????????`????????
fffff280`b2914d98 ????????`????????
fffff280`b2914da0 ????????`????????
fffff280`b2914da8 ????????`????????
fffff280`b2914db0 ????????`????????
fffff280`b2914db8 ????????`????????
fffff280`b2914dc0 ????????`????????
fffff280`b2914dc8 ????????`????????
fffff280`b2914dd0 ????????`????????
fffff280`b2914dd8 ????????`????????
fffff280`b2914de0 ????????`????????
fffff280`b2914de8 ????????`????????
fffff280`b2914df0 ????????`????????
fffff280`b2914df8 ????????`????????
fffff280`b2914e00 ????????`????????
fffff280`b2914e08 ????????`????????
fffff280`b2914e10 ????????`????????
fffff280`b2914e18 ????????`????????
fffff280`b2914e20 ????????`????????
fffff280`b2914e28 ????????`????????
fffff280`b2914e30 ????????`????????
fffff280`b2914e38 ????????`????????
fffff280`b2914e40 ????????`????????
fffff280`b2914e48 ????????`????????
fffff280`b2914e50 ????????`????????
fffff280`b2914e58 ????????`????????
fffff280`b2914e60 ????????`????????
fffff280`b2914e68 ????????`????????
fffff280`b2914e70 ????????`????????
fffff280`b2914e78 ????????`????????
fffff280`b2914e80 ????????`????????
fffff280`b2914e88 ????????`????????
fffff280`b2914e90 ????????`????????
fffff280`b2914e98 ????????`????????
fffff280`b2914ea0 ????????`????????
fffff280`b2914ea8 ????????`????????
fffff280`b2914eb0 ????????`????????
fffff280`b2914eb8 ????????`????????
fffff280`b2914ec0 ????????`????????
fffff280`b2914ec8 ????????`????????
fffff280`b2914ed0 ????????`????????
fffff280`b2914ed8 ????????`????????
fffff280`b2914ee0 ????????`????????
fffff280`b2914ee8 ????????`????????
fffff280`b2914ef0 ????????`????????
fffff280`b2914ef8 ????????`????????
fffff280`b2914f00 ????????`????????
fffff280`b2914f08 ????????`????????
fffff280`b2914f10 ????????`????????
fffff280`b2914f18 ????????`????????
fffff280`b2914f20 ????????`????????
fffff280`b2914f28 ????????`????????
fffff280`b2914f30 ????????`????????
fffff280`b2914f38 ????????`????????
fffff280`b2914f40 ????????`????????
fffff280`b2914f48 ????????`????????
fffff280`b2914f50 ????????`????????
fffff280`b2914f58 ????????`????????
fffff280`b2914f60 ????????`????????
fffff280`b2914f68 ????????`????????
fffff280`b2914f70 ????????`????????
fffff280`b2914f78 ????????`????????
fffff280`b2914f80 ????????`????????
fffff280`b2914f88 ????????`????????
fffff280`b2914f90 ????????`????????
fffff280`b2914f98 ????????`????????
fffff280`b2914fa0 ????????`????????
fffff280`b2914fa8 ????????`????????
fffff280`b2914fb0 ????????`????????
fffff280`b2914fb8 ????????`????????
fffff280`b2914fc0 ????????`????????
fffff280`b2914fc8 ????????`????????
fffff280`b2914fd0 ????????`????????
fffff280`b2914fd8 ????????`????????
fffff280`b2914fe0 ????????`????????
fffff280`b2914fe8 ????????`????????
fffff280`b2914ff0 ????????`????????
fffff280`b2914ff8 ????????`????????
fffff280`b2915000 ????????`????????
fffff280`b2915008 ????????`????????
fffff280`b2915010 ????????`????????
fffff280`b2915018 ????????`????????
fffff280`b2915020 ????????`????????
fffff280`b2915028 ????????`????????
fffff280`b2915030 ????????`????????
fffff280`b2915038 ????????`????????
fffff280`b2915040 ????????`????????
fffff280`b2915048 ????????`????????
fffff280`b2915050 ????????`????????
fffff280`b2915058 ????????`????????
fffff280`b2915060 ????????`????????
fffff280`b2915068 ????????`????????
fffff280`b2915070 ????????`????????
fffff280`b2915078 ????????`????????
fffff280`b2915080 ????????`????????
fffff280`b2915088 ????????`????????
fffff280`b2915090 ????????`????????
fffff280`b2915098 ????????`????????
fffff280`b29150a0 ????????`????????
fffff280`b29150a8 ????????`????????
fffff280`b29150b0 ????????`????????
fffff280`b29150b8 ????????`????????
fffff280`b29150c0 ????????`????????
fffff280`b29150c8 ????????`????????
fffff280`b29150d0 ????????`????????
fffff280`b29150d8 ????????`????????
fffff280`b29150e0 ????????`????????
fffff280`b29150e8 ????????`????????
fffff280`b29150f0 ????????`????????
fffff280`b29150f8 ????????`????????
fffff280`b2915100 ????????`????????
fffff280`b2915108 ????????`????????
fffff280`b2915110 ????????`????????
fffff280`b2915118 ????????`????????
fffff280`b2915120 ????????`????????
fffff280`b2915128 ????????`????????
fffff280`b2915130 ????????`????????
fffff280`b2915138 ????????`????????
fffff280`b2915140 ????????`????????
fffff280`b2915148 ????????`????????
fffff280`b2915150 ????????`????????
fffff280`b2915158 ????????`????????
fffff280`b2915160 ????????`????????
fffff280`b2915168 ????????`????????
fffff280`b2915170 ????????`????????
fffff280`b2915178 ????????`????????
fffff280`b2915180 ????????`????????
fffff280`b2915188 ????????`????????
fffff280`b2915190 ????????`????????
fffff280`b2915198 ????????`????????
fffff280`b29151a0 ????????`????????
fffff280`b29151a8 ????????`????????
fffff280`b29151b0 ????????`????????
fffff280`b29151b8 ????????`????????
fffff280`b29151c0 ????????`????????
fffff280`b29151c8 ????????`????????
fffff280`b29151d0 ????????`????????
fffff280`b29151d8 ????????`????????
fffff280`b29151e0 ????????`????????
fffff280`b29151e8 ????????`????????
fffff280`b29151f0 ????????`????????
fffff280`b29151f8 ????????`????????
fffff280`b2915200 ????????`????????
fffff280`b2915208 ????????`????????
fffff280`b2915210 ????????`????????
fffff280`b2915218 ????????`????????
fffff280`b2915220 ????????`????????
fffff280`b2915228 ????????`????????
fffff280`b2915230 ????????`????????
fffff280`b2915238 ????????`????????
fffff280`b2915240 ????????`????????
fffff280`b2915248 ????????`????????
fffff280`b2915250 ????????`????????
fffff280`b2915258 ????????`????????
fffff280`b2915260 ????????`????????
fffff280`b2915268 ????????`????????
fffff280`b2915270 ????????`????????
fffff280`b2915278 ????????`????????
fffff280`b2915280 ????????`????????
fffff280`b2915288 ????????`????????
fffff280`b2915290 ????????`????????
fffff280`b2915298 ????????`????????
fffff280`b29152a0 ????????`????????
fffff280`b29152a8 ????????`????????
fffff280`b29152b0 ????????`????????
fffff280`b29152b8 ????????`????????
fffff280`b29152c0 ????????`????????
fffff280`b29152c8 ????????`????????
fffff280`b29152d0 ????????`????????
fffff280`b29152d8 ????????`????????
fffff280`b29152e0 ????????`????????
fffff280`b29152e8 ????????`????????
fffff280`b29152f0 ????????`????????
fffff280`b29152f8 ????????`????????
fffff280`b2915300 ????????`????????
fffff280`b2915308 ????????`????????
fffff280`b2915310 ????????`????????
fffff280`b2915318 ????????`????????
fffff280`b2915320 ????????`????????
fffff280`b2915328 ????????`????????
fffff280`b2915330 ????????`????????
fffff280`b2915338 ????????`????????
fffff280`b2915340 ????????`????????
fffff280`b2915348 ????????`????????
fffff280`b2915350 ????????`????????
fffff280`b2915358 ????????`????????
fffff280`b2915360 ????????`????????
fffff280`b2915368 ????????`????????
fffff280`b2915370 ????????`????????
fffff280`b2915378 ????????`????????
fffff280`b2915380 ????????`????????
fffff280`b2915388 ????????`????????
fffff280`b2915390 ????????`????????
fffff280`b2915398 ????????`????????
fffff280`b29153a0 ????????`????????
fffff280`b29153a8 ????????`????????
fffff280`b29153b0 ????????`????????
fffff280`b29153b8 ????????`????????
fffff280`b29153c0 ????????`????????
fffff280`b29153c8 ????????`????????
fffff280`b29153d0 ????????`????????
fffff280`b29153d8 ????????`????????
fffff280`b29153e0 ????????`????????
fffff280`b29153e8 ????????`????????
fffff280`b29153f0 ????????`????????
fffff280`b29153f8 ????????`????????
fffff280`b2915400 ????????`????????
fffff280`b2915408 ????????`????????
fffff280`b2915410 ????????`????????
fffff280`b2915418 ????????`????????
fffff280`b2915420 ????????`????????
fffff280`b2915428 ????????`????????
fffff280`b2915430 ????????`????????
fffff280`b2915438 ????????`????????
fffff280`b2915440 ????????`????????
fffff280`b2915448 ????????`????????
fffff280`b2915450 ????????`????????
fffff280`b2915458 ????????`????????
fffff280`b2915460 ????????`????????
fffff280`b2915468 ????????`????????
fffff280`b2915470 ????????`????????
fffff280`b2915478 ????????`????????
fffff280`b2915480 ????????`????????
fffff280`b2915488 ????????`????????
fffff280`b2915490 ????????`????????
fffff280`b2915498 ????????`????????
fffff280`b29154a0 ????????`????????
fffff280`b29154a8 ????????`????????
fffff280`b29154b0 ????????`????????
fffff280`b29154b8 ????????`????????
fffff280`b29154c0 ????????`????????
fffff280`b29154c8 ????????`????????
fffff280`b29154d0 ????????`????????
fffff280`b29154d8 ????????`????????
fffff280`b29154e0 ????????`????????
fffff280`b29154e8 ????????`????????
fffff280`b29154f0 ????????`????????
fffff280`b29154f8 ????????`????????
fffff280`b2915500 ????????`????????
fffff280`b2915508 ????????`????????
fffff280`b2915510 ????????`????????
fffff280`b2915518 ????????`????????
fffff280`b2915520 ????????`????????
fffff280`b2915528 ????????`????????
fffff280`b2915530 ????????`????????
fffff280`b2915538 ????????`????????
fffff280`b2915540 ????????`????????
fffff280`b2915548 ????????`????????
fffff280`b2915550 ????????`????????
fffff280`b2915558 ????????`????????
fffff280`b2915560 ????????`????????
fffff280`b2915568 ????????`????????
fffff280`b2915570 ????????`????????
fffff280`b2915578 ????????`????????
fffff280`b2915580 ????????`????????
fffff280`b2915588 ????????`????????
fffff280`b2915590 ????????`????????
fffff280`b2915598 ????????`????????
fffff280`b29155a0 ????????`????????
fffff280`b29155a8 ????????`????????
fffff280`b29155b0 ????????`????????
fffff280`b29155b8 ????????`????????
fffff280`b29155c0 ????????`????????
fffff280`b29155c8 ????????`????????
fffff280`b29155d0 ????????`????????
fffff280`b29155d8 ????????`????????
fffff280`b29155e0 ????????`????????
fffff280`b29155e8 ????????`????????
fffff280`b29155f0 ????????`????????
fffff280`b29155f8 ????????`????????
fffff280`b2915600 ????????`????????
fffff280`b2915608 ????????`????????
fffff280`b2915610 ????????`????????
fffff280`b2915618 ????????`????????
fffff280`b2915620 ????????`????????
fffff280`b2915628 ????????`????????
fffff280`b2915630 ????????`????????
fffff280`b2915638 ????????`????????
fffff280`b2915640 ????????`????????
fffff280`b2915648 ????????`????????
fffff280`b2915650 ????????`????????
fffff280`b2915658 ????????`????????
fffff280`b2915660 ????????`????????
fffff280`b2915668 ????????`????????
fffff280`b2915670 ????????`????????
fffff280`b2915678 ????????`????????
fffff280`b2915680 ????????`????????
fffff280`b2915688 ????????`????????
fffff280`b2915690 ????????`????????
fffff280`b2915698 ????????`????????
fffff280`b29156a0 ????????`????????
fffff280`b29156a8 ????????`????????
fffff280`b29156b0 ????????`????????
fffff280`b29156b8 ????????`????????
fffff280`b29156c0 ????????`????????
fffff280`b29156c8 ????????`????????
fffff280`b29156d0 ????????`????????
fffff280`b29156d8 ????????`????????
fffff280`b29156e0 ????????`????????
fffff280`b29156e8 ????????`????????
fffff280`b29156f0 ????????`????????
fffff280`b29156f8 ????????`????????
fffff280`b2915700 ????????`????????
fffff280`b2915708 ????????`????????
fffff280`b2915710 ????????`????????
fffff280`b2915718 ????????`????????
fffff280`b2915720 ????????`????????
fffff280`b2915728 ????????`????????
fffff280`b2915730 ????????`????????
fffff280`b2915738 ????????`????????
fffff280`b2915740 ????????`????????
fffff280`b2915748 ????????`????????
fffff280`b2915750 ????????`????????
fffff280`b2915758 ????????`????????
fffff280`b2915760 ????????`????????
fffff280`b2915768 ????????`????????
fffff280`b2915770 ????????`????????
fffff280`b2915778 ????????`????????
fffff280`b2915780 ????????`????????
fffff280`b2915788 ????????`????????
fffff280`b2915790 ????????`????????
fffff280`b2915798 ????????`????????
fffff280`b29157a0 ????????`????????
fffff280`b29157a8 ????????`????????
fffff280`b29157b0 ????????`????????
fffff280`b29157b8 ????????`????????
fffff280`b29157c0 ????????`????????
fffff280`b29157c8 ????????`????????
fffff280`b29157d0 ????????`????????
fffff280`b29157d8 ????????`????????
fffff280`b29157e0 ????????`????????
fffff280`b29157e8 ????????`????????
fffff280`b29157f0 ????????`????????
fffff280`b29157f8 ????????`????????
fffff280`b2915800 ????????`????????
fffff280`b2915808 ????????`????????
fffff280`b2915810 ????????`????????
fffff280`b2915818 ????????`????????
fffff280`b2915820 ????????`????????
fffff280`b2915828 ????????`????????
fffff280`b2915830 ????????`????????
fffff280`b2915838 ????????`????????
fffff280`b2915840 ????????`????????
fffff280`b2915848 ????????`????????
fffff280`b2915850 ????????`????????
fffff280`b2915858 ????????`????????
fffff280`b2915860 ????????`????????
fffff280`b2915868 ????????`????????
fffff280`b2915870 ????????`????????
fffff280`b2915878 ????????`????????
fffff280`b2915880 ????????`????????
fffff280`b2915888 ????????`????????
fffff280`b2915890 ????????`????????
fffff280`b2915898 ????????`????????
fffff280`b29158a0 ????????`????????
fffff280`b29158a8 ????????`????????
fffff280`b29158b0 ????????`????????
fffff280`b29158b8 ????????`????????
fffff280`b29158c0 ????????`????????
fffff280`b29158c8 ????????`????????
fffff280`b29158d0 ????????`????????
fffff280`b29158d8 ????????`????????
fffff280`b29158e0 ????????`????????
fffff280`b29158e8 ????????`????????
fffff280`b29158f0 ????????`????????
fffff280`b29158f8 ????????`????????
fffff280`b2915900 ????????`????????
fffff280`b2915908 ????????`????????
fffff280`b2915910 ????????`????????
fffff280`b2915918 ????????`????????
fffff280`b2915920 ????????`????????
fffff280`b2915928 ????????`????????
fffff280`b2915930 ????????`????????
fffff280`b2915938 ????????`????????
fffff280`b2915940 ????????`????????
fffff280`b2915948 ????????`????????
fffff280`b2915950 ????????`????????
fffff280`b2915958 ????????`????????
fffff280`b2915960 ????????`????????
fffff280`b2915968 ????????`????????
fffff280`b2915970 ????????`????????
fffff280`b2915978 ????????`????????
fffff280`b2915980 ????????`????????
fffff280`b2915988 ????????`????????
fffff280`b2915990 ????????`????????
fffff280`b2915998 ????????`????????
fffff280`b29159a0 ????????`????????
fffff280`b29159a8 ????????`????????
fffff280`b29159b0 ????????`????????
fffff280`b29159b8 ????????`????????
fffff280`b29159c0 ????????`????????
fffff280`b29159c8 ????????`????????
fffff280`b29159d0 ????????`????????
fffff280`b29159d8 ????????`????????
fffff280`b29159e0 ????????`????????
fffff280`b29159e8 ????????`????????
fffff280`b29159f0 ????????`????????
fffff280`b29159f8 ????????`????????
fffff280`b2915a00 ????????`????????
fffff280`b2915a08 ????????`????????
fffff280`b2915a10 ????????`????????
fffff280`b2915a18 ????????`????????
fffff280`b2915a20 ????????`????????
fffff280`b2915a28 ????????`????????
fffff280`b2915a30 ????????`????????
fffff280`b2915a38 ????????`????????
fffff280`b2915a40 ????????`????????
fffff280`b2915a48 ????????`????????
fffff280`b2915a50 ????????`????????
fffff280`b2915a58 ????????`????????
fffff280`b2915a60 ????????`????????
fffff280`b2915a68 ????????`????????
fffff280`b2915a70 ????????`????????
fffff280`b2915a78 ????????`????????
fffff280`b2915a80 ????????`????????
fffff280`b2915a88 ????????`????????
fffff280`b2915a90 ????????`????????
fffff280`b2915a98 ????????`????????
fffff280`b2915aa0 ????????`????????
fffff280`b2915aa8 ????????`????????
fffff280`b2915ab0 ????????`????????
fffff280`b2915ab8 ????????`????????
fffff280`b2915ac0 ????????`????????
fffff280`b2915ac8 ????????`????????
fffff280`b2915ad0 ????????`????????
fffff280`b2915ad8 ????????`????????
fffff280`b2915ae0 ????????`????????
fffff280`b2915ae8 ????????`????????
fffff280`b2915af0 ????????`????????
fffff280`b2915af8 ????????`????????
fffff280`b2915b00 ????????`????????
fffff280`b2915b08 ????????`????????
fffff280`b2915b10 ????????`????????
fffff280`b2915b18 ????????`????????
fffff280`b2915b20 ????????`????????
fffff280`b2915b28 ????????`????????
fffff280`b2915b30 ????????`????????
fffff280`b2915b38 ????????`????????
fffff280`b2915b40 ????????`????????
fffff280`b2915b48 ????????`????????
fffff280`b2915b50 ????????`????????
fffff280`b2915b58 ????????`????????
fffff280`b2915b60 ????????`????????
fffff280`b2915b68 ????????`????????
fffff280`b2915b70 ????????`????????
fffff280`b2915b78 ????????`????????
fffff280`b2915b80 ????????`????????
fffff280`b2915b88 ????????`????????
fffff280`b2915b90 ????????`????????
fffff280`b2915b98 ????????`????????
fffff280`b2915ba0 ????????`????????
fffff280`b2915ba8 ????????`????????
fffff280`b2915bb0 ????????`????????
fffff280`b2915bb8 ????????`????????
fffff280`b2915bc0 ????????`????????
fffff280`b2915bc8 ????????`????????
fffff280`b2915bd0 ????????`????????
fffff280`b2915bd8 ????????`????????
fffff280`b2915be0 ????????`????????
fffff280`b2915be8 ????????`????????
fffff280`b2915bf0 ????????`????????
fffff280`b2915bf8 ????????`????????
fffff280`b2915c00 ????????`????????
fffff280`b2915c08 ????????`????????
fffff280`b2915c10 ????????`????????
fffff280`b2915c18 ????????`????????
fffff280`b2915c20 ????????`????????
fffff280`b2915c28 ????????`????????
fffff280`b2915c30 ????????`????????
fffff280`b2915c38 ????????`????????
fffff280`b2915c40 ????????`????????
fffff280`b2915c48 ????????`????????
fffff280`b2915c50 ????????`????????
fffff280`b2915c58 ????????`????????
fffff280`b2915c60 ????????`????????
fffff280`b2915c68 ????????`????????
fffff280`b2915c70 ????????`????????
fffff280`b2915c78 ????????`????????
fffff280`b2915c80 ????????`????????
fffff280`b2915c88 ????????`????????
fffff280`b2915c90 ????????`????????
fffff280`b2915c98 ????????`????????
fffff280`b2915ca0 ????????`????????
fffff280`b2915ca8 ????????`????????
fffff280`b2915cb0 ????????`????????
fffff280`b2915cb8 ????????`????????
fffff280`b2915cc0 ????????`????????
fffff280`b2915cc8 ????????`????????
fffff280`b2915cd0 ????????`????????
fffff280`b2915cd8 ????????`????????
fffff280`b2915ce0 ????????`????????
fffff280`b2915ce8 ????????`????????
fffff280`b2915cf0 ????????`????????
fffff280`b2915cf8 ????????`????????
fffff280`b2915d00 ????????`????????
fffff280`b2915d08 ????????`????????
fffff280`b2915d10 ????????`????????
fffff280`b2915d18 ????????`????????
fffff280`b2915d20 ????????`????????
fffff280`b2915d28 ????????`????????
fffff280`b2915d30 ????????`????????
fffff280`b2915d38 ????????`????????
fffff280`b2915d40 ????????`????????
fffff280`b2915d48 ????????`????????
fffff280`b2915d50 ????????`????????
fffff280`b2915d58 ????????`????????
fffff280`b2915d60 ????????`????????
fffff280`b2915d68 ????????`????????
fffff280`b2915d70 ????????`????????
fffff280`b2915d78 ????????`????????
fffff280`b2915d80 ????????`????????
fffff280`b2915d88 ????????`????????
fffff280`b2915d90 ????????`????????
fffff280`b2915d98 ????????`????????
fffff280`b2915da0 ????????`????????
fffff280`b2915da8 ????????`????????
fffff280`b2915db0 ????????`????????
fffff280`b2915db8 ????????`????????
fffff280`b2915dc0 ????????`????????
fffff280`b2915dc8 ????????`????????
fffff280`b2915dd0 ????????`????????
fffff280`b2915dd8 ????????`????????
fffff280`b2915de0 ????????`????????
fffff280`b2915de8 ????????`????????
fffff280`b2915df0 ????????`????????
fffff280`b2915df8 ????????`????????
fffff280`b2915e00 ????????`????????
fffff280`b2915e08 ????????`????????
fffff280`b2915e10 ????????`????????
fffff280`b2915e18 ????????`????????
fffff280`b2915e20 ????????`????????
fffff280`b2915e28 ????????`????????
fffff280`b2915e30 ????????`????????
fffff280`b2915e38 ????????`????????
fffff280`b2915e40 ????????`????????
fffff280`b2915e48 ????????`????????
fffff280`b2915e50 ????????`????????
fffff280`b2915e58 ????????`????????
fffff280`b2915e60 ????????`????????
fffff280`b2915e68 ????????`????????
fffff280`b2915e70 ????????`????????
fffff280`b2915e78 ????????`????????
fffff280`b2915e80 ????????`????????
fffff280`b2915e88 ????????`????????
fffff280`b2915e90 ????????`????????
fffff280`b2915e98 ????????`????????
fffff280`b2915ea0 ????????`????????
fffff280`b2915ea8 ????????`????????
fffff280`b2915eb0 ????????`????????
fffff280`b2915eb8 ????????`????????
fffff280`b2915ec0 ????????`????????
fffff280`b2915ec8 ????????`????????
fffff280`b2915ed0 ????????`????????
fffff280`b2915ed8 ????????`????????
fffff280`b2915ee0 ????????`????????
fffff280`b2915ee8 ????????`????????
fffff280`b2915ef0 ????????`????????
fffff280`b2915ef8 ????????`????????
fffff280`b2915f00 ????????`????????
fffff280`b2915f08 ????????`????????
fffff280`b2915f10 ????????`????????
fffff280`b2915f18 ????????`????????
fffff280`b2915f20 ????????`????????
fffff280`b2915f28 ????????`????????
fffff280`b2915f30 ????????`????????
fffff280`b2915f38 ????????`????????
fffff280`b2915f40 ????????`????????
fffff280`b2915f48 ????????`????????
fffff280`b2915f50 ????????`????????
fffff280`b2915f58 ????????`????????
fffff280`b2915f60 ????????`????????
fffff280`b2915f68 ????????`????????
fffff280`b2915f70 ????????`????????
fffff280`b2915f78 ????????`????????
fffff280`b2915f80 ????????`????????
fffff280`b2915f88 ????????`????????
fffff280`b2915f90 ????????`????????
fffff280`b2915f98 ????????`????????
fffff280`b2915fa0 ????????`????????
fffff280`b2915fa8 ????????`????????
fffff280`b2915fb0 ????????`????????
fffff280`b2915fb8 ????????`????????
fffff280`b2915fc0 ????????`????????
fffff280`b2915fc8 ????????`????????
fffff280`b2915fd0 ????????`????????
fffff280`b2915fd8 ????????`????????
fffff280`b2915fe0 ????????`????????
fffff280`b2915fe8 ????????`????????
fffff280`b2915ff0 ????????`????????
fffff280`b2915ff8 ????????`????????
fffff280`b2916000 ????????`????????
fffff280`b2916008 ????????`????????
fffff280`b2916010 ????????`????????
fffff280`b2916018 ????????`????????
fffff280`b2916020 ????????`????????
fffff280`b2916028 ????????`????????
fffff280`b2916030 ????????`????????
fffff280`b2916038 ????????`????????
fffff280`b2916040 ????????`????????
fffff280`b2916048 ????????`????????
fffff280`b2916050 ????????`????????
fffff280`b2916058 ????????`????????
fffff280`b2916060 ????????`????????
fffff280`b2916068 ????????`????????
fffff280`b2916070 ????????`????????
fffff280`b2916078 ????????`????????
fffff280`b2916080 ????????`????????
fffff280`b2916088 ????????`????????
fffff280`b2916090 ????????`????????
fffff280`b2916098 ????????`????????
fffff280`b29160a0 ????????`????????
fffff280`b29160a8 ????????`????????
fffff280`b29160b0 ????????`????????
fffff280`b29160b8 ????????`????????
fffff280`b29160c0 ????????`????????
fffff280`b29160c8 ????????`????????
fffff280`b29160d0 ????????`????????
fffff280`b29160d8 ????????`????????
fffff280`b29160e0 ????????`????????
fffff280`b29160e8 ????????`????????
fffff280`b29160f0 ????????`????????
fffff280`b29160f8 ????????`????????
fffff280`b2916100 ????????`????????
fffff280`b2916108 ????????`????????
fffff280`b2916110 ????????`????????
fffff280`b2916118 ????????`????????
fffff280`b2916120 ????????`????????
fffff280`b2916128 ????????`????????
fffff280`b2916130 ????????`????????
fffff280`b2916138 ????????`????????
fffff280`b2916140 ????????`????????
fffff280`b2916148 ????????`????????
fffff280`b2916150 ????????`????????
fffff280`b2916158 ????????`????????
fffff280`b2916160 ????????`????????
fffff280`b2916168 ????????`????????
fffff280`b2916170 ????????`????????
fffff280`b2916178 ????????`????????
fffff280`b2916180 ????????`????????
fffff280`b2916188 ????????`????????
fffff280`b2916190 ????????`????????
fffff280`b2916198 ????????`????????
fffff280`b29161a0 ????????`????????
fffff280`b29161a8 ????????`????????
fffff280`b29161b0 ????????`????????
fffff280`b29161b8 ????????`????????
fffff280`b29161c0 ????????`????????
fffff280`b29161c8 ????????`????????
fffff280`b29161d0 ????????`????????
fffff280`b29161d8 ????????`????????
fffff280`b29161e0 ????????`????????
fffff280`b29161e8 ????????`????????
fffff280`b29161f0 ????????`????????
fffff280`b29161f8 ????????`????????
fffff280`b2916200 ????????`????????
fffff280`b2916208 ????????`????????
fffff280`b2916210 ????????`????????
fffff280`b2916218 ????????`????????
fffff280`b2916220 ????????`????????
fffff280`b2916228 ????????`????????
fffff280`b2916230 ????????`????????
fffff280`b2916238 ????????`????????
fffff280`b2916240 ????????`????????
fffff280`b2916248 ????????`????????
fffff280`b2916250 ????????`????????
fffff280`b2916258 ????????`????????
fffff280`b2916260 ????????`????????
fffff280`b2916268 ????????`????????
fffff280`b2916270 ????????`????????
fffff280`b2916278 ????????`????????
fffff280`b2916280 ????????`????????
fffff280`b2916288 ????????`????????
fffff280`b2916290 ????????`????????
fffff280`b2916298 ????????`????????
fffff280`b29162a0 ????????`????????
fffff280`b29162a8 ????????`????????
fffff280`b29162b0 ????????`????????
fffff280`b29162b8 ????????`????????
fffff280`b29162c0 ????????`????????
fffff280`b29162c8 ????????`????????
fffff280`b29162d0 ????????`????????
fffff280`b29162d8 ????????`????????
fffff280`b29162e0 ????????`????????
fffff280`b29162e8 ????????`????????
fffff280`b29162f0 ????????`????????
fffff280`b29162f8 ????????`????????
fffff280`b2916300 ????????`????????
fffff280`b2916308 ????????`????????
fffff280`b2916310 ????????`????????
fffff280`b2916318 ????????`????????
fffff280`b2916320 ????????`????????
fffff280`b2916328 ????????`????????
fffff280`b2916330 ????????`????????
fffff280`b2916338 ????????`????????
fffff280`b2916340 ????????`????????
fffff280`b2916348 ????????`????????
fffff280`b2916350 ????????`????????
fffff280`b2916358 ????????`????????
fffff280`b2916360 ????????`????????
fffff280`b2916368 ????????`????????
fffff280`b2916370 ????????`????????
fffff280`b2916378 ????????`????????
fffff280`b2916380 ????????`????????
fffff280`b2916388 ????????`????????
fffff280`b2916390 ????????`????????
fffff280`b2916398 ????????`????????
fffff280`b29163a0 ????????`????????
fffff280`b29163a8 ????????`????????
fffff280`b29163b0 ????????`????????
fffff280`b29163b8 ????????`????????
fffff280`b29163c0 ????????`????????
fffff280`b29163c8 ????????`????????
fffff280`b29163d0 ????????`????????
fffff280`b29163d8 ????????`????????
fffff280`b29163e0 ????????`????????
fffff280`b29163e8 ????????`????????
fffff280`b29163f0 ????????`????????
fffff280`b29163f8 ????????`????????
fffff280`b2916400 ????????`????????
fffff280`b2916408 ????????`????????
fffff280`b2916410 ????????`????????
fffff280`b2916418 ????????`????????
fffff280`b2916420 ????????`????????
fffff280`b2916428 ????????`????????
fffff280`b2916430 ????????`????????
fffff280`b2916438 ????????`????????
fffff280`b2916440 ????????`????????
fffff280`b2916448 ????????`????????
fffff280`b2916450 ????????`????????
fffff280`b2916458 ????????`????????
fffff280`b2916460 ????????`????????
fffff280`b2916468 ????????`????????
fffff280`b2916470 ????????`????????
fffff280`b2916478 ????????`????????
fffff280`b2916480 ????????`????????
fffff280`b2916488 ????????`????????
fffff280`b2916490 ????????`????????
fffff280`b2916498 ????????`????????
fffff280`b29164a0 ????????`????????
fffff280`b29164a8 ????????`????????
fffff280`b29164b0 ????????`????????
fffff280`b29164b8 ????????`????????
fffff280`b29164c0 ????????`????????
fffff280`b29164c8 ????????`????????
fffff280`b29164d0 ????????`????????
fffff280`b29164d8 ????????`????????
fffff280`b29164e0 ????????`????????
fffff280`b29164e8 ????????`????????
fffff280`b29164f0 ????????`????????
fffff280`b29164f8 ????????`????????
fffff280`b2916500 ????????`????????
fffff280`b2916508 ????????`????????
fffff280`b2916510 ????????`????????
fffff280`b2916518 ????????`????????
fffff280`b2916520 ????????`????????
fffff280`b2916528 ????????`????????
fffff280`b2916530 ????????`????????
fffff280`b2916538 ????????`????????
fffff280`b2916540 ????????`????????
fffff280`b2916548 ????????`????????
fffff280`b2916550 ????????`????????
fffff280`b2916558 ????????`????????
fffff280`b2916560 ????????`????????
fffff280`b2916568 ????????`????????
fffff280`b2916570 ????????`????????
fffff280`b2916578 ????????`????????
fffff280`b2916580 ????????`????????
fffff280`b2916588 ????????`????????
fffff280`b2916590 ????????`????????
fffff280`b2916598 ????????`????????
fffff280`b29165a0 ????????`????????
fffff280`b29165a8 ????????`????????
fffff280`b29165b0 ????????`????????
fffff280`b29165b8 ????????`????????
fffff280`b29165c0 ????????`????????
fffff280`b29165c8 ????????`????????
fffff280`b29165d0 ????????`????????
fffff280`b29165d8 ????????`????????
fffff280`b29165e0 ????????`????????
fffff280`b29165e8 ????????`????????
fffff280`b29165f0 ????????`????????
fffff280`b29165f8 ????????`????????
fffff280`b2916600 ????????`????????
fffff280`b2916608 ????????`????????
fffff280`b2916610 ????????`????????
fffff280`b2916618 ????????`????????
fffff280`b2916620 ????????`????????
fffff280`b2916628 ????????`????????
fffff280`b2916630 ????????`????????
fffff280`b2916638 ????????`????????
fffff280`b2916640 ????????`????????
fffff280`b2916648 ????????`????????
fffff280`b2916650 ????????`????????
fffff280`b2916658 ????????`????????
fffff280`b2916660 ????????`????????
fffff280`b2916668 ????????`????????
fffff280`b2916670 ????????`????????
fffff280`b2916678 ????????`????????
fffff280`b2916680 ????????`????????
fffff280`b2916688 ????????`????????
fffff280`b2916690 ????????`????????
fffff280`b2916698 ????????`????????
fffff280`b29166a0 ????????`????????
fffff280`b29166a8 ????????`????????
fffff280`b29166b0 ????????`????????
fffff280`b29166b8 ????????`????????
fffff280`b29166c0 ????????`????????
fffff280`b29166c8 ????????`????????
fffff280`b29166d0 ????????`????????
fffff280`b29166d8 ????????`????????
fffff280`b29166e0 ????????`????????
fffff280`b29166e8 ????????`????????
fffff280`b29166f0 ????????`????????
fffff280`b29166f8 ????????`????????
fffff280`b2916700 ????????`????????
fffff280`b2916708 ????????`????????
fffff280`b2916710 ????????`????????
fffff280`b2916718 ????????`????????
fffff280`b2916720 ????????`????????
fffff280`b2916728 ????????`????????
fffff280`b2916730 ????????`????????
fffff280`b2916738 ????????`????????
fffff280`b2916740 ????????`????????
fffff280`b2916748 ????????`????????
fffff280`b2916750 ????????`????????
fffff280`b2916758 ????????`????????
fffff280`b2916760 ????????`????????
fffff280`b2916768 ????????`????????
fffff280`b2916770 ????????`????????
fffff280`b2916778 ????????`????????
fffff280`b2916780 ????????`????????
fffff280`b2916788 ????????`????????
fffff280`b2916790 ????????`????????
fffff280`b2916798 ????????`????????
fffff280`b29167a0 ????????`????????
fffff280`b29167a8 ????????`????????
fffff280`b29167b0 ????????`????????
fffff280`b29167b8 ????????`????????
fffff280`b29167c0 ????????`????????
fffff280`b29167c8 ????????`????????
fffff280`b29167d0 ????????`????????
fffff280`b29167d8 ????????`????????
fffff280`b29167e0 ????????`????????
fffff280`b29167e8 ????????`????????
fffff280`b29167f0 ????????`????????
fffff280`b29167f8 ????????`????????
fffff280`b2916800 ????????`????????
fffff280`b2916808 ????????`????????
fffff280`b2916810 ????????`????????
fffff280`b2916818 ????????`????????
fffff280`b2916820 ????????`????????
fffff280`b2916828 ????????`????????
fffff280`b2916830 ????????`????????
fffff280`b2916838 ????????`????????
fffff280`b2916840 ????????`????????
fffff280`b2916848 ????????`????????
fffff280`b2916850 ????????`????????
fffff280`b2916858 ????????`????????
fffff280`b2916860 ????????`????????
fffff280`b2916868 ????????`????????
fffff280`b2916870 ????????`????????
fffff280`b2916878 ????????`????????
fffff280`b2916880 ????????`????????
fffff280`b2916888 ????????`????????
fffff280`b2916890 ????????`????????
fffff280`b2916898 ????????`????????
fffff280`b29168a0 ????????`????????
fffff280`b29168a8 ????????`????????
fffff280`b29168b0 ????????`????????
fffff280`b29168b8 ????????`????????
fffff280`b29168c0 ????????`????????
fffff280`b29168c8 ????????`????????
fffff280`b29168d0 ????????`????????
fffff280`b29168d8 ????????`????????
fffff280`b29168e0 ????????`????????
fffff280`b29168e8 ????????`????????
fffff280`b29168f0 ????????`????????
fffff280`b29168f8 00000000`00000000
fffff280`b2916900 00000000`00000109
fffff280`b2916908 a39fcfe8`0c40f5af
fffff280`b2916910 b3b6dc6e`5ec3a686
fffff280`b2916918 fffff802`67370000
fffff280`b2916920 00000000`00000019
fffff280`b2916928 00000000`00000000
fffff280`b2916930 00000000`00000000
fffff280`b2916938 00000000`00000000
fffff280`b2916940 00000000`00000000
fffff280`b2916948 00000000`00000000
fffff280`b2916950 00000000`00000000
fffff280`b2916958 00000000`00000000
fffff280`b2916960 00000000`00000000
fffff280`b2916968 00000000`00000000
fffff280`b2916970 00000000`00000000
fffff280`b2916978 00000000`00000000
fffff280`b2916980 00000000`00000000
fffff280`b2916988 00000000`00000000
fffff280`b2916990 00000000`00000000
fffff280`b2916998 00000000`00000000
fffff280`b29169a0 00000000`00000000
fffff280`b29169a8 00000000`00000000
fffff280`b29169b0 00000000`00000000
fffff280`b29169b8 00000000`00000000
fffff280`b29169c0 00000000`00000000
fffff280`b29169c8 00000000`00000000
fffff280`b29169d0 00000000`00000000
fffff280`b29169d8 00000000`00000000
fffff280`b29169e0 00000000`00000000
fffff280`b29169e8 00000000`00000000
fffff280`b29169f0 00000000`00000000
fffff280`b29169f8 00000000`00000000
fffff280`b2916a00 00000000`00000000
fffff280`b2916a08 00000000`00000000
fffff280`b2916a10 00000000`00000000
fffff280`b2916a18 00000000`00000000
fffff280`b2916a20 00000000`00000000
fffff280`b2916a28 00000000`00000000
fffff280`b2916a30 00000000`00000000
fffff280`b2916a38 00000000`00000000
fffff280`b2916a40 00000000`00000000
fffff280`b2916a48 00000000`00000000
fffff280`b2916a50 00000000`00000000
fffff280`b2916a58 00000000`00000000
fffff280`b2916a60 00000000`00000000
fffff280`b2916a68 00000000`00000000
fffff280`b2916a70 00000000`00000000
fffff280`b2916a78 00000000`00000000
fffff280`b2916a80 00000000`00000000
fffff280`b2916a88 00000000`00000000
fffff280`b2916a90 00000000`00000000
fffff280`b2916a98 00000000`00000000
fffff280`b2916aa0 00000000`00000000
fffff280`b2916aa8 00000000`00000000
fffff280`b2916ab0 00000000`00000000
fffff280`b2916ab8 00000000`00000000
fffff280`b2916ac0 00000000`00000000
fffff280`b2916ac8 00000000`00000000
fffff280`b2916ad0 00000000`00000000
fffff280`b2916ad8 00000000`00000000
fffff280`b2916ae0 00000000`00000000
fffff280`b2916ae8 00000000`00000000
fffff280`b2916af0 00000000`00000000
fffff280`b2916af8 00000000`00000000
fffff280`b2916b00 00000000`00000000
fffff280`b2916b08 00000000`00000000
fffff280`b2916b10 00000000`00000000
fffff280`b2916b18 00000000`00000000
fffff280`b2916b20 00000000`00000000
fffff280`b2916b28 00000000`00000000
fffff280`b2916b30 00000000`00000000
fffff280`b2916b38 00000000`00000000
fffff280`b2916b40 00000000`00000000
fffff280`b2916b48 00000000`00000000
fffff280`b2916b50 00000000`00000000
fffff280`b2916b58 00000000`00000000
fffff280`b2916b60 00000000`00000000
fffff280`b2916b68 00000000`00000000
fffff280`b2916b70 00000000`00000000
fffff280`b2916b78 00000000`00000000
fffff280`b2916b80 00000000`00000000
fffff280`b2916b88 00000000`00000000
fffff280`b2916b90 00000000`00000000
fffff280`b2916b98 00000000`00000000
fffff280`b2916ba0 00000000`00000000
fffff280`b2916ba8 00000000`00000000
fffff280`b2916bb0 00000000`00000000
fffff280`b2916bb8 00000000`00000000
fffff280`b2916bc0 00000000`00000000
fffff280`b2916bc8 00000000`00000000
fffff280`b2916bd0 00000000`00000000
fffff280`b2916bd8 00000000`00000000
fffff280`b2916be0 00000000`00000000
fffff280`b2916be8 00000000`00000000
fffff280`b2916bf0 00000000`00000000
fffff280`b2916bf8 00000000`00000000
fffff280`b2916c00 00000000`00000000
fffff280`b2916c08 00000000`00000000
fffff280`b2916c10 00000000`00000000
fffff280`b2916c18 00000000`00000000
fffff280`b2916c20 00000000`00000000
fffff280`b2916c28 00000000`00000000
fffff280`b2916c30 00000000`00000000
fffff280`b2916c38 00000000`00000000
fffff280`b2916c40 00000000`00000000
fffff280`b2916c48 00000000`00000000
fffff280`b2916c50 00000000`00000000
fffff280`b2916c58 00000000`00000000
fffff280`b2916c60 00000000`00000000
fffff280`b2916c68 00000000`00000000
fffff280`b2916c70 00000000`00000000
fffff280`b2916c78 00000000`00000000
fffff280`b2916c80 00000000`00000000
fffff280`b2916c88 00000000`00000000
fffff280`b2916c90 00000000`00000000
fffff280`b2916c98 00000000`00000000
fffff280`b2916ca0 00000000`00000000
fffff280`b2916ca8 00000000`00000000
fffff280`b2916cb0 00000000`00000000
fffff280`b2916cb8 00000000`00000000
fffff280`b2916cc0 00000000`00000000
fffff280`b2916cc8 00000000`00000000
fffff280`b2916cd0 00000000`00000000
fffff280`b2916cd8 00000000`00000000
fffff280`b2916ce0 00000000`00000000
fffff280`b2916ce8 00000000`00000000
fffff280`b2916cf0 00000000`00000000
fffff280`b2916cf8 00000000`00000000
fffff280`b2916d00 00000000`00000000
fffff280`b2916d08 00000000`00000000
fffff280`b2916d10 00000000`00000000
fffff280`b2916d18 00000000`00000000
fffff280`b2916d20 00000000`00000000
fffff280`b2916d28 00000000`00000000
fffff280`b2916d30 00000000`00000000
fffff280`b2916d38 00000000`00000000
fffff280`b2916d40 00000000`00000000
fffff280`b2916d48 00000000`00000000
fffff280`b2916d50 00000000`00000000
fffff280`b2916d58 00000000`00000000
fffff280`b2916d60 00000000`00000000
fffff280`b2916d68 00000000`00000000
fffff280`b2916d70 00000000`00000000
fffff280`b2916d78 00000000`00000000
fffff280`b2916d80 00000000`00000000
fffff280`b2916d88 00000000`00000000
fffff280`b2916d90 00000000`00000000
fffff280`b2916d98 00000000`00000000
fffff280`b2916da0 00000000`00000000
fffff280`b2916da8 00000000`00000000
fffff280`b2916db0 00000000`00000000
fffff280`b2916db8 00000000`00000000
fffff280`b2916dc0 00000000`00000000
fffff280`b2916dc8 00000000`00000000
fffff280`b2916dd0 00000000`00000000
fffff280`b2916dd8 00000000`00000000
fffff280`b2916de0 00000000`00000000
fffff280`b2916de8 00000000`00000000
fffff280`b2916df0 00000000`00000000
fffff280`b2916df8 00000000`00000000
fffff280`b2916e00 00000000`00000000
fffff280`b2916e08 00000000`00000000
fffff280`b2916e10 00000000`00000000
fffff280`b2916e18 00000000`00000000
fffff280`b2916e20 00000000`00000000
fffff280`b2916e28 00000000`00000000
fffff280`b2916e30 00000000`00000000
fffff280`b2916e38 00000000`00000000
fffff280`b2916e40 00000000`00000000
fffff280`b2916e48 00000000`00000000
fffff280`b2916e50 00000000`00000000
fffff280`b2916e58 00000000`00000000
fffff280`b2916e60 00000000`00000000
fffff280`b2916e68 00000000`00000000
fffff280`b2916e70 00000000`00000000
fffff280`b2916e78 00000000`00000000
fffff280`b2916e80 00000000`00000000
fffff280`b2916e88 00000000`00000000
fffff280`b2916e90 00000000`00000000
fffff280`b2916e98 00000000`00000000
fffff280`b2916ea0 00000000`00000000
fffff280`b2916ea8 00000000`00000000
fffff280`b2916eb0 00000000`00000000
fffff280`b2916eb8 00000000`00000000
fffff280`b2916ec0 00000000`00000000
fffff280`b2916ec8 00000000`00000000
fffff280`b2916ed0 00000000`00000000
fffff280`b2916ed8 00000000`00000000
fffff280`b2916ee0 00000000`00000000
fffff280`b2916ee8 00000000`00000000
fffff280`b2916ef0 00000000`00000000
fffff280`b2916ef8 00000000`00000000
fffff280`b2916f00 00000000`00000000
fffff280`b2916f08 00000000`00000000
fffff280`b2916f10 00000000`00000000
fffff280`b2916f18 00000000`00000000
fffff280`b2916f20 00000000`00000000
fffff280`b2916f28 00000000`00000000
fffff280`b2916f30 00000000`00000000
fffff280`b2916f38 00000000`00000000
fffff280`b2916f40 00000000`00000000
fffff280`b2916f48 00000000`00000000
fffff280`b2916f50 00000000`00000000
fffff280`b2916f58 00000000`00000000
fffff280`b2916f60 00000000`00000000
fffff280`b2916f68 00000000`00000000
fffff280`b2916f70 00000000`00000000
fffff280`b2916f78 00000000`00000000
fffff280`b2916f80 00000000`00000000
fffff280`b2916f88 00000000`00000000
fffff280`b2916f90 00000000`00000000
fffff280`b2916f98 00000000`00000000
fffff280`b2916fa0 00000000`00000000
fffff280`b2916fa8 00000000`00000000
fffff280`b2916fb0 00000000`00000000
fffff280`b2916fb8 00000000`00000000
fffff280`b2916fc0 00000000`00000000
fffff280`b2916fc8 00000000`00000000
fffff280`b2916fd0 00000000`00000000
fffff280`b2916fd8 00000000`00000000
fffff280`b2916fe0 00000000`00000000
fffff280`b2916fe8 00000000`00000000
fffff280`b2916ff0 00000000`00000000
fffff280`b2916ff8 00000000`00000000
fffff280`b2917000 00000000`00000000
fffff280`b2917008 00000000`00000000
fffff280`b2917010 00000000`00000000
fffff280`b2917018 00000000`00000000
fffff280`b2917020 00000000`00000000
fffff280`b2917028 00000000`00000000
fffff280`b2917030 00000000`00000000
fffff280`b2917038 00000000`00000000
fffff280`b2917040 00000000`00000000
fffff280`b2917048 00000000`00000000
fffff280`b2917050 00000000`00000000
fffff280`b2917058 00000000`00000000
fffff280`b2917060 00000000`00000000
fffff280`b2917068 00000000`00000000
fffff280`b2917070 00000000`00000000
fffff280`b2917078 00000000`00000000
fffff280`b2917080 00000000`00000000
fffff280`b2917088 00000000`00000000
fffff280`b2917090 00000000`00000000
fffff280`b2917098 00000000`00000000
fffff280`b29170a0 00000000`00000000
fffff280`b29170a8 00000000`00000000
fffff280`b29170b0 00000000`00000000
fffff280`b29170b8 00000000`00000000
fffff280`b29170c0 00000000`00000000
fffff280`b29170c8 00000000`00000000
fffff280`b29170d0 00000000`00000000
fffff280`b29170d8 00000000`00000000
fffff280`b29170e0 00000000`00000000
fffff280`b29170e8 00000000`00000000
fffff280`b29170f0 00000000`00000000
fffff280`b29170f8 00000000`00000000
fffff280`b2917100 00000000`00000000
fffff280`b2917108 00000000`00000000
fffff280`b2917110 00000000`00000000
fffff280`b2917118 00000000`00000000
fffff280`b2917120 00000000`00000000
fffff280`b2917128 00000000`00000000
fffff280`b2917130 00000000`00000000
fffff280`b2917138 00000000`00000000
fffff280`b2917140 00000000`00000000
fffff280`b2917148 00000000`00000000
fffff280`b2917150 00000000`00000000
fffff280`b2917158 00000000`00000000
fffff280`b2917160 00000000`00000000
fffff280`b2917168 00000000`00000000
fffff280`b2917170 00000000`00000000
fffff280`b2917178 00000000`00000000
fffff280`b2917180 00000000`00000000
fffff280`b2917188 00000000`00000000
fffff280`b2917190 00000000`00000000
fffff280`b2917198 00000000`00000000
fffff280`b29171a0 00000000`00000000
fffff280`b29171a8 00000000`00000000
fffff280`b29171b0 00000000`00000000
fffff280`b29171b8 00000000`00000000
fffff280`b29171c0 00000000`00000000
fffff280`b29171c8 00000000`00000000
fffff280`b29171d0 00000000`00000000
fffff280`b29171d8 00000000`00000000
fffff280`b29171e0 00000000`00000000
fffff280`b29171e8 00000000`00000000
fffff280`b29171f0 00000000`00000000
fffff280`b29171f8 00000000`00000000
fffff280`b2917200 00000000`00000000
fffff280`b2917208 00000000`00000000
fffff280`b2917210 00000000`00000000
fffff280`b2917218 00000000`00000000
fffff280`b2917220 00000000`00000000
fffff280`b2917228 00000000`00000000
fffff280`b2917230 00000000`00000000
fffff280`b2917238 00000000`00000000
fffff280`b2917240 00000000`00000000
fffff280`b2917248 00000000`00000000
fffff280`b2917250 00000000`00000000
fffff280`b2917258 00000000`00000000
fffff280`b2917260 00000000`00000000
fffff280`b2917268 00000000`00000000
fffff280`b2917270 00000000`00000000
fffff280`b2917278 00000000`00000000
fffff280`b2917280 00000000`00000000
fffff280`b2917288 00000000`00000000
fffff280`b2917290 00000000`00000000
fffff280`b2917298 00000000`00000000
fffff280`b29172a0 00000000`00000000
fffff280`b29172a8 00000000`00000000
fffff280`b29172b0 00000000`00000000
fffff280`b29172b8 00000000`00000000
fffff280`b29172c0 00000000`00000000
fffff280`b29172c8 00000000`00000000
fffff280`b29172d0 00000000`00000000
fffff280`b29172d8 00000000`00000000
fffff280`b29172e0 00000000`00000000
fffff280`b29172e8 00000000`00000000
fffff280`b29172f0 00000000`00000000
fffff280`b29172f8 00000000`00000000
fffff280`b2917300 00000000`00000000
fffff280`b2917308 00000000`00000000
fffff280`b2917310 00000000`00000000
fffff280`b2917318 00000000`00000000
fffff280`b2917320 00000000`00000000
fffff280`b2917328 00000000`00000000
fffff280`b2917330 00000000`00000000
fffff280`b2917338 00000000`00000000
fffff280`b2917340 00000000`00000000
fffff280`b2917348 00000000`00000000
fffff280`b2917350 00000000`00000000
fffff280`b2917358 00000000`00000000
fffff280`b2917360 00000000`00000000
fffff280`b2917368 00000000`00000000
fffff280`b2917370 00000000`00000000
fffff280`b2917378 00000000`00000000
fffff280`b2917380 00000000`00000000
fffff280`b2917388 00000000`00000000
fffff280`b2917390 00000000`00000000
fffff280`b2917398 00000000`00000000
fffff280`b29173a0 00000000`00000000
fffff280`b29173a8 00000000`00000000
fffff280`b29173b0 00000000`00000000
fffff280`b29173b8 00000000`00000000
fffff280`b29173c0 00000000`00000000
fffff280`b29173c8 00000000`00000000
fffff280`b29173d0 00000000`00000000
fffff280`b29173d8 00000000`00000000
fffff280`b29173e0 00000000`00000000
fffff280`b29173e8 00000000`00000000
fffff280`b29173f0 00000000`00000000
fffff280`b29173f8 00000000`00000000
fffff280`b2917400 00000000`00000000
fffff280`b2917408 00000000`00000000
fffff280`b2917410 00000000`00000000
fffff280`b2917418 00000000`00000000
fffff280`b2917420 00000000`00000000
fffff280`b2917428 00000000`00000000
fffff280`b2917430 00000000`00000000
fffff280`b2917438 00000000`00000000
fffff280`b2917440 00000000`00000000
fffff280`b2917448 00000000`00000000
fffff280`b2917450 00000000`00000000
fffff280`b2917458 00000000`00000000
fffff280`b2917460 00000000`00000000
fffff280`b2917468 00000000`00000000
fffff280`b2917470 00000000`00000000
fffff280`b2917478 00000000`00000000
fffff280`b2917480 00000000`00000000
fffff280`b2917488 00000000`00000000
fffff280`b2917490 00000000`00000000
fffff280`b2917498 00000000`00000000
fffff280`b29174a0 00000000`00000000
fffff280`b29174a8 00000000`00000000
fffff280`b29174b0 00000000`00000000
fffff280`b29174b8 00000000`00000000
fffff280`b29174c0 00000000`00000000
fffff280`b29174c8 00000000`00000000
fffff280`b29174d0 00000000`00000000
fffff280`b29174d8 00000000`00000000
fffff280`b29174e0 00000000`00000000
fffff280`b29174e8 00000000`00000000
fffff280`b29174f0 00000000`00000000
fffff280`b29174f8 00000000`00000000
fffff280`b2917500 00000000`00000000
fffff280`b2917508 00000000`00000000
fffff280`b2917510 00000000`00000000
fffff280`b2917518 00000000`00000000
fffff280`b2917520 00000000`00000000
fffff280`b2917528 00000000`00000000
fffff280`b2917530 00000000`00000000
fffff280`b2917538 00000000`00000000
fffff280`b2917540 00000000`00000000
fffff280`b2917548 00000000`00000000
fffff280`b2917550 00000000`00000000
fffff280`b2917558 00000000`00000000
fffff280`b2917560 00000000`00000000
fffff280`b2917568 00000000`00000000
fffff280`b2917570 00000000`00000000
fffff280`b2917578 00000000`00000000
fffff280`b2917580 00000000`00000000
fffff280`b2917588 00000000`00000000
fffff280`b2917590 00000000`00000000
fffff280`b2917598 00000000`00000000
fffff280`b29175a0 00000000`00000000
fffff280`b29175a8 00000000`00000000
fffff280`b29175b0 00000000`00000000
fffff280`b29175b8 00000000`00000000
fffff280`b29175c0 00000000`00000000
fffff280`b29175c8 00000000`00000000
fffff280`b29175d0 00000000`00000000
fffff280`b29175d8 00000000`00000000
fffff280`b29175e0 00000000`00000000
fffff280`b29175e8 00000000`00000000
fffff280`b29175f0 00000000`00000000
fffff280`b29175f8 00000000`00000000
fffff280`b2917600 00000000`00000000
fffff280`b2917608 00000000`00000000
fffff280`b2917610 00000000`00000000
fffff280`b2917618 00000000`00000000
fffff280`b2917620 00000000`00000000
fffff280`b2917628 00000000`00000000
fffff280`b2917630 00000000`00000000
fffff280`b2917638 00000000`00000000
fffff280`b2917640 00000000`00000000
fffff280`b2917648 00000000`00000000
fffff280`b2917650 00000000`00000000
fffff280`b2917658 00000000`00000000
fffff280`b2917660 00000000`00000000
fffff280`b2917668 00000000`00000000
fffff280`b2917670 00000000`00000000
fffff280`b2917678 00000000`00000000
fffff280`b2917680 00000000`00000000
fffff280`b2917688 00000000`00000000
fffff280`b2917690 00000000`00000000
fffff280`b2917698 00000000`00000000
fffff280`b29176a0 00000000`00000000
fffff280`b29176a8 00000000`00000000
fffff280`b29176b0 00000000`00000000
fffff280`b29176b8 00000000`00000000
fffff280`b29176c0 00000000`00000000
fffff280`b29176c8 00000000`00000000
fffff280`b29176d0 00000000`00000000
fffff280`b29176d8 00000000`00000000
fffff280`b29176e0 00000000`00000000
fffff280`b29176e8 00000000`00000000
fffff280`b29176f0 00000000`00000000
fffff280`b29176f8 00000000`00000000
fffff280`b2917700 00000000`00000000
fffff280`b2917708 00000000`00000000
fffff280`b2917710 00000000`00000000
fffff280`b2917718 00000000`00000000
fffff280`b2917720 00000000`00000000
fffff280`b2917728 00000000`00000000
fffff280`b2917730 00000000`00000000
fffff280`b2917738 00000000`00000000
fffff280`b2917740 00000000`00000000
fffff280`b2917748 00000000`00000000
fffff280`b2917750 00000000`00000000
fffff280`b2917758 00000000`00000000
fffff280`b2917760 00000000`00000000
fffff280`b2917768 00000000`00000000
fffff280`b2917770 00000000`00000000
fffff280`b2917778 00000000`00000000
fffff280`b2917780 00000000`00000000
fffff280`b2917788 00000000`00000000
fffff280`b2917790 00000000`00000000
fffff280`b2917798 00000000`00000000
fffff280`b29177a0 00000000`00000000
fffff280`b29177a8 00000000`00000000
fffff280`b29177b0 00000000`00000000
fffff280`b29177b8 00000000`00000000
fffff280`b29177c0 00000000`00000000
fffff280`b29177c8 00000000`00000000
fffff280`b29177d0 00000000`00000000
fffff280`b29177d8 00000000`00000000
fffff280`b29177e0 00000000`00000000
fffff280`b29177e8 00000000`00000000
fffff280`b29177f0 00000000`00000000
fffff280`b29177f8 00000000`00000000
fffff280`b2917800 00000000`00000000
fffff280`b2917808 00000000`00000000
fffff280`b2917810 00000000`00000000
fffff280`b2917818 00000000`00000000
fffff280`b2917820 00000000`00000000
fffff280`b2917828 00000000`00000000
fffff280`b2917830 00000000`00000000
fffff280`b2917838 00000000`00000000
fffff280`b2917840 00000000`00000000
fffff280`b2917848 00000000`00000000
fffff280`b2917850 00000000`00000000
fffff280`b2917858 00000000`00000000
fffff280`b2917860 00000000`00000000
fffff280`b2917868 00000000`00000000
fffff280`b2917870 00000000`00000000
fffff280`b2917878 00000000`00000000
fffff280`b2917880 00000000`00000000
fffff280`b2917888 00000000`00000000
fffff280`b2917890 00000000`00000000
fffff280`b2917898 00000000`00000000
fffff280`b29178a0 00000000`00000000
fffff280`b29178a8 00000000`00000000
fffff280`b29178b0 00000000`00000000
fffff280`b29178b8 00000000`00000000
fffff280`b29178c0 00000000`00000000
fffff280`b29178c8 00000000`00000000
fffff280`b29178d0 00000000`00000000
fffff280`b29178d8 00000000`00000000
fffff280`b29178e0 00000000`00000000
fffff280`b29178e8 00000000`00000000
fffff280`b29178f0 00000000`00000000
fffff280`b29178f8 00000000`00000000
fffff280`b2917900 00000000`00000000
fffff280`b2917908 00000000`00000000
fffff280`b2917910 00000000`00000000
fffff280`b2917918 00000000`00000000
fffff280`b2917920 00000000`00000000
fffff280`b2917928 00000000`00000000
fffff280`b2917930 00000000`00000000
fffff280`b2917938 00000000`00000000
fffff280`b2917940 00000000`00000000
fffff280`b2917948 00000000`00000000
fffff280`b2917950 00000000`00000000
fffff280`b2917958 00000000`00000000
fffff280`b2917960 00000000`00000000
fffff280`b2917968 00000000`00000000
fffff280`b2917970 00000000`00000000
fffff280`b2917978 00000000`00000000
fffff280`b2917980 00000000`00000000
fffff280`b2917988 00000000`00000000
fffff280`b2917990 00000000`00000000
fffff280`b2917998 00000000`00000000
fffff280`b29179a0 00000000`00000000
fffff280`b29179a8 00000000`00000000
fffff280`b29179b0 00000000`00000000
fffff280`b29179b8 00000000`00000000
fffff280`b29179c0 00000000`00000000
fffff280`b29179c8 00000000`00000000
fffff280`b29179d0 00000000`00000000
fffff280`b29179d8 00000000`00000000
fffff280`b29179e0 00000000`00000000
fffff280`b29179e8 00000000`00000000
fffff280`b29179f0 00000000`00000000
fffff280`b29179f8 00000000`00000000
fffff280`b2917a00 00000000`00000000
fffff280`b2917a08 00000000`00000000
fffff280`b2917a10 00000000`00000000
fffff280`b2917a18 00000000`00000000
fffff280`b2917a20 00000000`00000000
fffff280`b2917a28 00000000`00000000
fffff280`b2917a30 00000000`00000000
fffff280`b2917a38 00000000`00000000
fffff280`b2917a40 00000000`00000000
fffff280`b2917a48 00000000`00000000
fffff280`b2917a50 00000000`00000000
fffff280`b2917a58 00000000`00000000
fffff280`b2917a60 00000000`00000000
fffff280`b2917a68 00000000`00000000
fffff280`b2917a70 00000000`00000000
fffff280`b2917a78 00000000`00000000
fffff280`b2917a80 00000000`00000000
fffff280`b2917a88 00000000`00000000
fffff280`b2917a90 00000000`00000000
fffff280`b2917a98 00000000`00000000
fffff280`b2917aa0 00000000`00000000
fffff280`b2917aa8 00000000`00000000
fffff280`b2917ab0 00000000`00000000
fffff280`b2917ab8 00000000`00000000
fffff280`b2917ac0 00000000`00000000
fffff280`b2917ac8 00000000`00000000
fffff280`b2917ad0 00000000`00000000
fffff280`b2917ad8 00000000`00000000
fffff280`b2917ae0 00000000`00000000
fffff280`b2917ae8 00000000`00000000
fffff280`b2917af0 00000000`00000000
fffff280`b2917af8 00000000`00000000
fffff280`b2917b00 00000000`00000000
fffff280`b2917b08 00000000`00000000
fffff280`b2917b10 00000000`00000000
fffff280`b2917b18 00000000`00000000
fffff280`b2917b20 00000000`00000000
fffff280`b2917b28 00000000`00000000
fffff280`b2917b30 00000000`00000000
fffff280`b2917b38 00000000`00000000
fffff280`b2917b40 00000000`00000000
fffff280`b2917b48 00000000`00000000
fffff280`b2917b50 00000000`00000000
fffff280`b2917b58 00000000`00000000
fffff280`b2917b60 00000000`00000000
fffff280`b2917b68 00000000`00000000
fffff280`b2917b70 00000000`00000000
fffff280`b2917b78 00000000`00000000
fffff280`b2917b80 00000000`00000000
fffff280`b2917b88 00000000`00000000
fffff280`b2917b90 00000000`00000000
fffff280`b2917b98 fffff280`b2911000
fffff280`b2917ba0 00000000`00000000
fffff280`b2917ba8 00000000`00000000
fffff280`b2917bb0 00000000`00000000
fffff280`b2917bb8 00000000`00000000
fffff280`b2917bc0 00000000`00000000
fffff280`b2917bc8 00000000`00000000
fffff280`b2917bd0 00000000`00000000
fffff280`b2917bd8 00000000`00001f80
fffff280`b2917be0 00000000`00000000
fffff280`b2917be8 00000000`00000000
fffff280`b2917bf0 00000000`00000000
fffff280`b2917bf8 00000000`00000000
fffff280`b2917c00 00000000`00000000
fffff280`b2917c08 00000000`00000000
fffff280`b2917c10 00000000`00000000
fffff280`b2917c18 00000000`00000000
fffff280`b2917c20 00000000`00000000
fffff280`b2917c28 00000000`00000000
fffff280`b2917c30 00000000`00000000
fffff280`b2917c38 00000000`00000000
fffff280`b2917c40 00000000`00000000
fffff280`b2917c48 00000000`00000000
fffff280`b2917c50 00000000`00000000
fffff280`b2917c58 00000000`00000000
fffff280`b2917c60 00000000`00000000
fffff280`b2917c68 00000000`00000000
fffff280`b2917c70 00000000`00000000
fffff280`b2917c78 00000000`00000000
fffff280`b2917c80 00000000`00000000
fffff280`b2917c88 00000000`00000000
fffff280`b2917c90 00000000`00000000
fffff280`b2917c98 00000000`00000000
fffff280`b2917ca0 00000000`00000000
fffff280`b2917ca8 00000000`00000000
fffff280`b2917cb0 00000000`00000000
fffff280`b2917cb8 00000000`00000000
fffff280`b2917cc0 00000000`00000000
fffff280`b2917cc8 00000000`00000000
fffff280`b2917cd0 00000000`00000000
fffff280`b2917cd8 00000000`00000000
fffff280`b2917ce0 00000000`00000000
fffff280`b2917ce8 00000000`00000000
fffff280`b2917cf0 00000000`00000000
fffff280`b2917cf8 00000000`00000000
fffff280`b2917d00 00000000`00000000
fffff280`b2917d08 00000000`00000000
fffff280`b2917d10 00000000`00000000
fffff280`b2917d18 00000000`00000000
fffff280`b2917d20 00000000`00000000
fffff280`b2917d28 00000000`00000000
fffff280`b2917d30 00000000`00000000
fffff280`b2917d38 00000000`00000000
fffff280`b2917d40 00000000`00000000
fffff280`b2917d48 00000000`00000000
fffff280`b2917d50 00000000`00000000
fffff280`b2917d58 00000000`00000000
fffff280`b2917d60 00000000`00000000
fffff280`b2917d68 00000000`00000000
fffff280`b2917d70 00000000`00000000
fffff280`b2917d78 00000000`00000000
fffff280`b2917d80 00000000`00000000
fffff280`b2917d88 00000000`00000000
fffff280`b2917d90 00000000`00000000
fffff280`b2917d98 00000000`00000000
fffff280`b2917da0 00000000`00000000
fffff280`b2917da8 00000000`00000000
fffff280`b2917db0 00000000`00000000
fffff280`b2917db8 00000000`00000000
fffff280`b2917dc0 00000000`00000000
fffff280`b2917dc8 80000000`0000001c
fffff280`b2917dd0 00000000`00000000
fffff280`b2917dd8 00000000`00000000
fffff280`b2917de0 00000000`00000000
fffff280`b2917de8 00000000`00000000
fffff280`b2917df0 00000000`00000000
fffff280`b2917df8 00000000`00000000
fffff280`b2917e00 00000000`00000000
fffff280`b2917e08 00000000`00000000
fffff280`b2917e10 00000000`00000000
fffff280`b2917e18 00000000`00000000
fffff280`b2917e20 00000000`00000000
fffff280`b2917e28 00000000`00000000
fffff280`b2917e30 00000000`00000000
fffff280`b2917e38 00000000`00000000
fffff280`b2917e40 00000000`00000000
fffff280`b2917e48 00000000`00000000
fffff280`b2917e50 00000000`00000000
fffff280`b2917e58 00000000`00000000
fffff280`b2917e60 00000000`00000000
fffff280`b2917e68 00000000`00000000
fffff280`b2917e70 00000000`00000000
fffff280`b2917e78 00000000`00000000
fffff280`b2917e80 00000000`00000000
fffff280`b2917e88 00000000`00000000
fffff280`b2917e90 00000000`00000000
fffff280`b2917e98 00000000`00000000
fffff280`b2917ea0 00000000`00000000
fffff280`b2917ea8 00000000`00000000
fffff280`b2917eb0 00000000`00000000
fffff280`b2917eb8 00000000`00000000
fffff280`b2917ec0 00000000`00000000
fffff280`b2917ec8 00000000`00000000
fffff280`b2917ed0 00000000`00000000
fffff280`b2917ed8 00000000`00000000
fffff280`b2917ee0 00000000`00000000
fffff280`b2917ee8 00000000`00000000
fffff280`b2917ef0 00000000`00000000
fffff280`b2917ef8 00000000`00000000
fffff280`b2917f00 00000000`00000000
fffff280`b2917f08 00000000`00000000
fffff280`b2917f10 00000000`00000000
fffff280`b2917f18 00000000`00000000
fffff280`b2917f20 00000000`00000000
fffff280`b2917f28 00000000`00000000
fffff280`b2917f30 00000000`00000000
fffff280`b2917f38 00000000`00000000
fffff280`b2917f40 00000000`00000000
fffff280`b2917f48 00000000`00000000
fffff280`b2917f50 00000000`00000000
fffff280`b2917f58 00000000`00000000
fffff280`b2917f60 00000000`00000000
fffff280`b2917f68 00000000`00000000
fffff280`b2917f70 00000000`00000000
fffff280`b2917f78 00000000`00000000
fffff280`b2917f80 00000000`00000000
fffff280`b2917f88 00000000`00000000
fffff280`b2917f90 00000000`00000000
fffff280`b2917f98 00000000`00000000
fffff280`b2917fa0 00000000`00000000
fffff280`b2917fa8 00000000`00000000
fffff280`b2917fb0 00000000`00000000
fffff280`b2917fb8 00000000`00000000
fffff280`b2917fc0 00000000`00000000
fffff280`b2917fc8 00000000`00000000
fffff280`b2917fd0 00000000`00000000
fffff280`b2917fd8 00000000`00000000
fffff280`b2917fe0 00000000`00000000
fffff280`b2917fe8 00000000`00000000
fffff280`b2917ff0 00000000`00000000
fffff280`b2917ff8 00000000`00000000
fffff280`b2918000 ????????`????????
Dump Header Information
----- 64 bit Kernel Mini Dump Analysis
DUMP_HEADER64:
MajorVersion 0000000f
MinorVersion 00003fab
KdSecondaryVersion 00000000
DirectoryTableBase 00000000`001aa000
PfnDataBase fffff803`ff1f9188
PsLoadedModuleList fffff803`ff161fb0
PsActiveProcessHead fffff803`ff15a9a0
MachineImageType 00008664
NumberProcessors 00000008
BugCheckCode 00000109
BugCheckParameter1 a39fcfe8`0c40f5af
BugCheckParameter2 b3b6dc6e`5ec3a686
BugCheckParameter3 fffff802`67370000
BugCheckParameter4 00000000`00000019
KdDebuggerDataBlock fffff803`ff14b4d0
ProductType 00000001
SuiteMask 00000110
WriterStatus 00000000
MiniDumpFields 00000cff
TRIAGE_DUMP64:
ServicePackBuild 00000000
SizeOfDump 0006e53c
ValidOffset 0006e538
ContextOffset 00000348
ExceptionOffset 00000f00
MmOffset 00002080
UnloadedDriversOffset 000020d0
PrcbOffset 000023e8
ProcessOffset 00008d68
ThreadOffset 000095a0
CallStackOffset 00009db8
SizeOfCallStack 00001708
DriverListOffset 0000b828
DriverCount 000000c9
StringPoolOffset 00012938
StringPoolSize 000047c0
BrokenDriverOffset 00000000
TriageOptions ffffffff
TopOfStack fffff280`b29168f8
BStoreOffset 00000000
SizeOfBStore 00000000
LimitOfBStore 00000000`00000000
DebuggerDataOffset 0000b4c0
DebuggerDataSize 00000368
DataBlocksOffset 000170f8
DataBlocksCount 0000012d
fffff803`ff161fe0 - fffff803`ff16207b at offset 000183c8
fffff803`fdb7b180 - fffff803`fdb81aff at offset 00018464
ffffa181`025e0440 - ffffa181`025e080f at offset 0001ede4
000000c2`15ffeb10 - 000000c2`16000b0f at offset 0001f1b4
ffffa181`02820180 - ffffa181`02826aff at offset 000211b4
ffffa181`025e8440 - ffffa181`025e880f at offset 00027b34
00000062`8a77e970 - 00000062`8a78096f at offset 00027f04
ffffa181`028ab180 - ffffa181`028b1aff at offset 00029f04
ffffa181`025ec440 - ffffa181`025ec80f at offset 00030884
000000c2`280fd800 - 000000c2`280ff7ff at offset 00030c54
ffffa181`02940180 - ffffa181`02946aff at offset 00032c54
ffffa181`0293f440 - ffffa181`0293f80f at offset 000395d4
fffff280`b29168f8 - fffff280`b2917fff at offset 000399a4
ffffa181`029d5180 - ffffa181`029dbaff at offset 0003b0ac
ffffa181`029ee440 - ffffa181`029ee80f at offset 00041a2c
000000c2`27efde70 - 000000c2`27effe6f at offset 00041dfc
ffffa181`02c79180 - ffffa181`02c7faff at offset 00043dfc
ffffa181`029f9440 - ffffa181`029f980f at offset 0004a77c
000000c2`52cbc8d0 - 000000c2`52cbe8cf at offset 0004ab4c
ffffa181`02d04180 - ffffa181`02d0aaff at offset 0004cb4c
ffffa181`029fd440 - ffffa181`029fd80f at offset 000534cc
000000c2`2e3fdea0 - 000000c2`2e3ffe9f at offset 0005389c
ffffa181`02d97180 - ffffa181`02d9daff at offset 0005589c
ffffa181`02db0440 - ffffa181`02db080f at offset 0005c21c
000000c2`4927c670 - 000000c2`4927e66f at offset 0005c5ec
fffff803`ff1fa880 - fffff803`ff1fa8bf at offset 0005e5ec
fffff803`ff17f480 - fffff803`ff17f57f at offset 0005e62c
fffff802`67370000 - fffff802`67370fff at offset 0005e72c
fffff803`ff17d1d0 - fffff803`ff17d1d3 at offset 0005f72c
fffff803`ff17d1e0 - fffff803`ff17d31f at offset 0005f730
fffff803`ff15d670 - fffff803`ff15d67f at offset 0005f870
ffff908f`6ea6a000 - ffff908f`6ea6a747 at offset 0005f880
fffff803`ff168b28 - fffff803`ff168b2f at offset 0005ffc8
fffff803`ff168b20 - fffff803`ff168b27 at offset 0005ffd0
fffff803`ff17fdc0 - fffff803`ff17fe1f at offset 0005ffd8
fffff802`67371000 - fffff802`67371fff at offset 00060038
ffff8fc7`e3f1ff80 - ffff8fc7`e3f1ff87 at offset 00061038
ffff8fc7`e3ff0048 - ffff8fc7`e3ff004f at offset 00061040
ffff8fc7`fe0099c8 - ffff8fc7`fe0099cf at offset 00061048
ffff8ffc`01339b80 - ffff8ffc`01339b87 at offset 00061050
ffff8ffc`01339b88 - ffff8ffc`01339b8f at offset 00061058
ffff908f`699820c6 - ffff908f`69982995 at offset 00061060
ffff8fc7`e3f1fcf8 - ffff8fc7`e3f1fcff at offset 00061930
ffff8fc7`e3f1fdc0 - ffff8fc7`e3f1fdc7 at offset 00061938
ffff8fc7`e3f1f000 - ffff8fc7`e3f1f007 at offset 00061940
ffff8fc7`fe00ffb8 - ffff8fc7`fe00ffbf at offset 00061948
ffff8fc7`e3ff0078 - ffff8fc7`e3ff007f at offset 00061950
fffff803`ff161b00 - fffff803`ff161b37 at offset 00061958
fffff803`fef64000 - fffff803`fef64fff at offset 00061990
ffff908f`6e5e1048 - ffff908f`6e5e1147 at offset 00062990
fffff280`b2911000 - fffff280`b29110ff at offset 00062a90
ffff908f`6e5e1148 - ffff908f`6e5e11d7 at offset 00062b90
ffff908f`6e5e11d8 - ffff908f`6e5e11e7 at offset 00062c20
ffff908f`68c4b480 - ffff908f`68c4b57f at offset 00062c30
ffff908f`6e5e11e8 - ffff908f`6e5e127f at offset 00062d30
ffff908f`68ccdc40 - ffff908f`68ccdd3f at offset 00062dc8
ffff908f`6e5e1280 - ffff908f`6e5e130f at offset 00062ec8
ffff908f`717ad520 - ffff908f`717ad61f at offset 00062f58
ffff908f`762b6840 - ffff908f`762b693f at offset 00063058
ffff908f`68ccdd40 - ffff908f`68ccdd47 at offset 00063158
ffff908f`6e5e1040 - ffff908f`6e5e1047 at offset 00063160
fffff803`ff1801d0 - fffff803`ff1802cf at offset 00063168
ffff908f`68c4b580 - ffff908f`68c4b587 at offset 00063268
ffff908f`68c4b588 - ffff908f`68c4b597 at offset 00063270
ffff908f`68cd69f8 - ffff908f`68cd6af7 at offset 00063280
ffff908f`70dc36f8 - ffff908f`70dc37f7 at offset 00063380
ffff908f`68c4b598 - ffff908f`68c4b677 at offset 00063480
ffff908f`7aa47908 - ffff908f`7aa47a07 at offset 00063560
ffff908f`68ccdee0 - ffff908f`68ccdfdf at offset 00063660
ffff908f`70dc3540 - ffff908f`70dc363f at offset 00063760
ffff908f`68ccdd48 - ffff908f`68ccdd57 at offset 00063860
ffff908f`68ccdd58 - ffff908f`68ccdd67 at offset 00063870
ffff908f`68ccdd68 - ffff908f`68ccdd77 at offset 00063880
ffff908f`68ccdd78 - ffff908f`68ccdd87 at offset 00063890
ffff908f`68ccdd88 - ffff908f`68ccdd97 at offset 000638a0
ffff908f`68ccdd98 - ffff908f`68ccdda7 at offset 000638b0
ffff908f`68ccdda8 - ffff908f`68ccddb7 at offset 000638c0
ffff908f`68ccddb8 - ffff908f`68ccddc7 at offset 000638d0
ffff908f`68ccddc8 - ffff908f`68ccddd7 at offset 000638e0
ffff908f`68ccddd8 - ffff908f`68ccdde7 at offset 000638f0
ffff908f`68ccdde8 - ffff908f`68ccddf7 at offset 00063900
ffff908f`68ccddf8 - ffff908f`68ccde07 at offset 00063910
ffff908f`68ccde08 - ffff908f`68ccde17 at offset 00063920
ffff908f`68ccde18 - ffff908f`68ccde27 at offset 00063930
ffff908f`68ccde28 - ffff908f`68ccde37 at offset 00063940
ffff908f`6e5e1310 - ffff908f`6e5e1397 at offset 00063950
ffff908f`6e5e1398 - ffff908f`6e5e13a7 at offset 000639d8
fffff803`fef17440 - fffff803`fef1753f at offset 000639e8
fffff803`feedacd0 - fffff803`feedadcf at offset 00063ae8
ffff908f`718e1d70 - ffff908f`718e1e6f at offset 00063be8
ffff908f`6e19f820 - ffff908f`6e19f91f at offset 00063ce8
fffff803`ff14b430 - fffff803`ff14b52f at offset 00063de8
fffff802`651d6360 - fffff802`651d645f at offset 00063ee8
ffff908f`6d8c01a0 - ffff908f`6d8c029f at offset 00063fe8
ffff908f`70da9740 - ffff908f`70da983f at offset 000640e8
ffff908f`6ed70180 - ffff908f`6ed7027f at offset 000641e8
ffff908f`717ad400 - ffff908f`717ad4ff at offset 000642e8
ffff908f`717ad508 - ffff908f`717ad51f at offset 000643e8
ffff908f`6e150908 - ffff908f`6e150a07 at offset 00064400
ffff908f`762b6940 - ffff908f`762b6a07 at offset 00064500
ffff908f`7aa47840 - ffff908f`7aa47907 at offset 000645c8
ffff908f`762b6700 - ffff908f`762b67ff at offset 00064690
ffff908f`762b6808 - ffff908f`762b683f at offset 00064790
ffff908f`717ad620 - ffff908f`717ad707 at offset 000647c8
fffff803`ff1802d0 - fffff803`ff1802d7 at offset 000648b0
ffff908f`6e5e13a8 - ffff908f`6e5e1447 at offset 000648b8
fffff803`ff1802d8 - fffff803`ff180317 at offset 00064958
fffff803`ff180318 - fffff803`ff180327 at offset 00064998
ffffd58c`65f12740 - ffffd58c`65f1283f at offset 000649a8
ffffd58c`59652ab0 - ffffd58c`59652baf at offset 00064aa8
fffff803`ff180328 - fffff803`ff180377 at offset 00064ba8
ffff908f`6d34dad0 - ffff908f`6d34dbcf at offset 00064bf8
ffff908f`7aa47a08 - ffff908f`7aa47a57 at offset 00064cf8
ffff908f`7aa47a58 - ffff908f`7aa47a67 at offset 00064d48
ffff908f`7aa47700 - ffff908f`7aa477ff at offset 00064d58
ffff908f`7aa47a68 - ffff908f`7aa47ae7 at offset 00064e58
ffff908f`762b6a08 - ffff908f`762b6af7 at offset 00064ed8
ffff908f`708109f8 - ffff908f`70810af7 at offset 00064fc8
ffff908f`70dc3640 - ffff908f`70dc36f7 at offset 000650c8
ffff908f`68c448c0 - ffff908f`68c449bf at offset 00065180
fffff803`ff2129c0 - fffff803`ff212abf at offset 00065280
ffff908f`68ccdfe0 - ffff908f`68cce047 at offset 00065380
fffff803`ff184680 - fffff803`ff18477f at offset 000653e8
ffff908f`68cce048 - ffff908f`68cce097 at offset 000654e8
ffff908f`6e43c130 - ffff908f`6e43c22f at offset 00065538
ffff908f`6fdc1818 - ffff908f`6fdc1917 at offset 00065638
ffff908f`6e04d9f8 - ffff908f`6e04daf7 at offset 00065738
ffff908f`6db6f9f8 - ffff908f`6db6faf7 at offset 00065838
ffff908f`6a4b79f8 - ffff908f`6a4b7af7 at offset 00065938
ffff908f`6e04daf8 - ffff908f`6e04db07 at offset 00065a38
ffff908f`6c64b378 - ffff908f`6c64b477 at offset 00065a48
ffff908f`6db6faf8 - ffff908f`6db6fb07 at offset 00065b48
ffff908f`6e5e1638 - ffff908f`6e5e1737 at offset 00065b58
ffff908f`6e5e1738 - ffff908f`6e5e1767 at offset 00065c58
ffff908f`6e5e1768 - ffff908f`6e5e178f at offset 00065c88
ffff908f`6e5e1790 - ffff908f`6e5e17af at offset 00065cb0
ffff908f`6e8f3da8 - ffff908f`6e8f3ea7 at offset 00065cd0
ffff908f`6db6fda8 - ffff908f`6db6fea7 at offset 00065dd0
ffff908f`6e5e17b0 - ffff908f`6e5e1857 at offset 00065ed0
ffff908f`6e5e1858 - ffff908f`6e5e1867 at offset 00065f78
ffff908f`6e04dda8 - ffff908f`6e04dea7 at offset 00065f88
ffff908f`6e8f3ea8 - ffff908f`6e8f3f17 at offset 00066088
ffff908f`6e8f3f18 - ffff908f`6e8f3f27 at offset 000660f8
ffff908f`6e8f3f28 - ffff908f`6e8f3f87 at offset 00066108
ffff908f`6c64b728 - ffff908f`6c64b827 at offset 00066168
ffff908f`6db6fea8 - ffff908f`6db6ff17 at offset 00066268
ffff908f`6db6ff18 - ffff908f`6db6ff27 at offset 000662d8
ffff908f`6db6ff28 - ffff908f`6db6ff87 at offset 000662e8
ffff908f`6e5e1868 - ffff908f`6e5e18c7 at offset 00066348
ffff908f`6e5e18c8 - ffff908f`6e5e1957 at offset 000663a8
ffff908f`68d209f8 - ffff908f`68d20af7 at offset 00066438
ffff908f`68cd6af8 - ffff908f`68cd6b07 at offset 00066538
ffff908f`6ab91778 - ffff908f`6ab91877 at offset 00066548
ffff908f`70dc37f8 - ffff908f`70dc3807 at offset 00066648
ffff908f`6b3d4280 - ffff908f`6b3d437f at offset 00066658
ffff908f`6c3782c0 - ffff908f`6c3783bf at offset 00066758
ffff908f`68c4b6c0 - ffff908f`68c4b7bf at offset 00066858
ffff908f`6c3783c0 - ffff908f`6c378467 at offset 00066958
ffff908f`68c4b7c0 - ffff908f`68c4b867 at offset 00066a00
fffff803`ff1690f0 - fffff803`ff1691ef at offset 00066aa8
ffff908f`70f512c0 - ffff908f`70f513bf at offset 00066ba8
ffff908f`6ecdb0c8 - ffff908f`6ecdb1c7 at offset 00066ca8
ffff908f`7d4e4278 - ffff908f`7d4e4377 at offset 00066da8
ffff908f`6d741ac0 - ffff908f`6d741bbf at offset 00066ea8
fffff803`ff1692d8 - fffff803`ff1693d7 at offset 00066fa8
ffff908f`6c8d8b98 - ffff908f`6c8d8c97 at offset 000670a8
ffff908f`6feaff60 - ffff908f`6feb005f at offset 000671a8
ffff908f`6f2673a0 - ffff908f`6f26749f at offset 000672a8
ffff908f`6cfb0090 - ffff908f`6cfb018f at offset 000673a8
fffff803`ff156401 - fffff803`ff156500 at offset 000674a8
ffff908f`6b3d4380 - ffff908f`6b3d4427 at offset 000675a8
ffffd58c`541f0607 - ffffd58c`541f0706 at offset 00067650
ffffd58c`54557c10 - ffffd58c`54557d0f at offset 00067750
fffff803`ff15a9a0 - fffff803`ff15aa9f at offset 00067850
ffff908f`70f513c0 - ffff908f`70f51467 at offset 00067950
fffff803`feedf840 - fffff803`feedf93f at offset 000679f8
fffff803`ff50f9b0 - fffff803`ff50faaf at offset 00067af8
fffff803`ff50f900 - fffff803`ff50f9af at offset 00067bf8
ffff908f`6b36ed10 - ffff908f`6b36ee0f at offset 00067ca8
fffff803`ff15c3c0 - fffff803`ff15c4bf at offset 00067da8
ffffd58c`54017043 - ffffd58c`54017142 at offset 00067ea8
ffffd58c`54014040 - ffffd58c`5401413f at offset 00067fa8
ffffd58c`551ad001 - ffffd58c`551ad100 at offset 000680a8
ffffd58c`54449558 - ffffd58c`54449657 at offset 000681a8
fffff803`ff5eb018 - fffff803`ff5eb117 at offset 000682a8
ffffd58c`62d85b70 - ffffd58c`62d85c6f at offset 000683a8
ffffd58c`6924df30 - ffffd58c`6924e02f at offset 000684a8
ffffd58c`63b591e0 - ffffd58c`63b592df at offset 000685a8
ffffd58c`6c7dd790 - ffffd58c`6c7dd88f at offset 000686a8
ffffd58c`55b6b210 - ffffd58c`55b6b30f at offset 000687a8
ffffd58c`62d85f60 - ffffd58c`62d8605f at offset 000688a8
ffffd58c`54017d50 - ffffd58c`54017e4f at offset 000689a8
ffffd58c`54014850 - ffffd58c`5401494f at offset 00068aa8
ffffd58c`57a52d30 - ffffd58c`57a52e2f at offset 00068ba8
ffffd58c`54028a00 - ffffd58c`54028aff at offset 00068ca8
ffff908f`68cb9970 - ffff908f`68cb9a6f at offset 00068da8
ffffd58c`54018ae0 - ffffd58c`54018bdf at offset 00068ea8
ffffd58c`54018fd0 - ffffd58c`540190cf at offset 00068fa8
ffff908f`68c46610 - ffff908f`68c4670f at offset 000690a8
ffff908f`68cb9d70 - ffff908f`68cb9e6f at offset 000691a8
ffff908f`68c50000 - ffff908f`68c500ff at offset 000692a8
ffffd58c`54017f9f - ffffd58c`5401809e at offset 000693a8
ffff908f`68cb9a70 - ffff908f`68cb9aff at offset 000694a8
fffff803`ff15fd00 - fffff803`ff15fdff at offset 00069538
ffff908f`68cd6da8 - ffff908f`68cd6ea7 at offset 00069638
ffff908f`68d20da8 - ffff908f`68d20ea7 at offset 00069738
ffff908f`68c4b908 - ffff908f`68c4ba07 at offset 00069838
ffff908f`68cd6ea8 - ffff908f`68cd6f17 at offset 00069938
ffff908f`68cd6f18 - ffff908f`68cd6f27 at offset 000699a8
ffff908f`68cd6f28 - ffff908f`68cd6f87 at offset 000699b8
ffff908f`70dc3aa8 - ffff908f`70dc3ba7 at offset 00069a18
ffff908f`6ab91b28 - ffff908f`6ab91c27 at offset 00069b18
ffff908f`70dc3ba8 - ffff908f`70dc3c17 at offset 00069c18
ffff908f`70dc3c18 - ffff908f`70dc3c27 at offset 00069c88
ffff908f`70dc3c28 - ffff908f`70dc3c87 at offset 00069c98
ffff908f`68c43d30 - ffff908f`68c43e2f at offset 00069cf8
ffffb2a5`404a6000 - ffffb2a5`404a60ff at offset 00069df8
ffff908f`68c43e30 - ffff908f`68c43ed7 at offset 00069ef8
ffff908f`68c43ed8 - ffff908f`68c43ee7 at offset 00069fa0
ffff908f`68c43ee8 - ffff908f`68c43ef7 at offset 00069fb0
ffff908f`68c43ef8 - ffff908f`68c43f07 at offset 00069fc0
ffff908f`6e9ea598 - ffff908f`6e9ea697 at offset 00069fd0
ffff908f`6d6a8ad8 - ffff908f`6d6a8bd7 at offset 0006a0d0
ffff908f`68c4ba08 - ffff908f`68c4ba97 at offset 0006a1d0
ffff908f`69df1690 - ffff908f`69df178f at offset 0006a260
ffff908f`6e498598 - ffff908f`6e498697 at offset 0006a360
ffff908f`6c4b0598 - ffff908f`6c4b0697 at offset 0006a460
ffff908f`6e224690 - ffff908f`6e22478f at offset 0006a560
ffff908f`6b3d4650 - ffff908f`6b3d474f at offset 0006a660
ffff908f`6c378690 - ffff908f`6c37878f at offset 0006a760
ffff908f`68c4ba98 - ffff908f`68c4bb8f at offset 0006a860
ffff908f`6b3d5330 - ffff908f`6b3d542f at offset 0006a958
ffff908f`6b3d4b90 - ffff908f`6b3d4c8f at offset 0006aa58
ffff908f`6b3d4750 - ffff908f`6b3d4797 at offset 0006ab58
ffff908f`6b3d4798 - ffff908f`6b3d482f at offset 0006aba0
ffff908f`6b3d4878 - ffff908f`6b3d4977 at offset 0006ac38
fffff803`ff213150 - fffff803`ff21324f at offset 0006ad38
fffff803`ff180378 - fffff803`ff180417 at offset 0006ae38
ffff908f`68c62f10 - ffff908f`68c6300f at offset 0006aed8
ffff908f`68c63010 - ffff908f`68c630bf at offset 0006afd8
ffff908f`6af48830 - ffff908f`6af4892f at offset 0006b088
ffff908f`6ac8fda0 - ffff908f`6ac8fe9f at offset 0006b188
ffff908f`6c265bf0 - ffff908f`6c265cef at offset 0006b288
ffff908f`6b040660 - ffff908f`6b04075f at offset 0006b388
ffffd58c`54529cf0 - ffffd58c`54529def at offset 0006b488
ffffd58c`54529e68 - ffffd58c`54529f67 at offset 0006b588
ffff908f`6b0405e8 - ffff908f`6b04065f at offset 0006b688
ffff908f`71e5c7f0 - ffff908f`71e5c8ef at offset 0006b700
ffff908f`6b0487f0 - ffff908f`6b0488ef at offset 0006b800
ffffd58c`573448a0 - ffffd58c`5734499f at offset 0006b900
ffff908f`68c4bb90 - ffff908f`68c4bbd7 at offset 0006ba00
ffffd58c`9661d230 - ffffd58c`9661d32f at offset 0006ba48
ffffd58c`9d4b31f0 - ffffd58c`9d4b32ef at offset 0006bb48
ffffd58c`6fe961d0 - ffffd58c`6fe962cf at offset 0006bc48
ffffd58c`6ac48010 - ffffd58c`6ac4810f at offset 0006bd48
ffffd58c`540b3d50 - ffffd58c`540b3e4f at offset 0006be48
ffffd58c`59315790 - ffffd58c`5931588f at offset 0006bf48
fffff803`ff5ea5a8 - fffff803`ff5ea6a7 at offset 0006c048
ffffd58c`57080ac0 - ffffd58c`57080bbf at offset 0006c148
ffffd58c`541abdf8 - ffffd58c`541abef7 at offset 0006c248
ffffd58c`64f601e8 - ffffd58c`64f602e7 at offset 0006c348
ffffd58c`54027398 - ffffd58c`54027497 at offset 0006c448
ffffd58c`99cc0a48 - ffffd58c`99cc0b47 at offset 0006c548
ffffd58c`540b3e50 - ffffd58c`540b3ebf at offset 0006c648
ffff908f`68c4bbd8 - ffff908f`68c4bc6f at offset 0006c6b8
ffff908f`68c4bcb8 - ffff908f`68c4bdb7 at offset 0006c750
ffff908f`68c4bdb8 - ffff908f`68c4bddf at offset 0006c850
ffffd58c`544f32e8 - ffffd58c`544f33e7 at offset 0006c878
ffffd58c`6b9f3428 - ffffd58c`6b9f3527 at offset 0006c978
ffff908f`68c4bec0 - ffff908f`68c4bfbf at offset 0006ca78
ffff908f`68c4bfc0 - ffff908f`68c4c05f at offset 0006cb78
ffffd58c`5431e6d0 - ffffd58c`5431e7cf at offset 0006cc18
ffff908f`68c4bc70 - ffff908f`68c4bcb7 at offset 0006cd18
ffffd58c`544ef1f8 - ffffd58c`544ef2f7 at offset 0006cd60
ffff908f`6af53b00 - ffff908f`6af53bff at offset 0006ce60
ffffd58c`544f74c8 - ffffd58c`544f75c7 at offset 0006cf60
ffffd58c`57343b38 - ffffd58c`57343c37 at offset 0006d060
ffff908f`70aee990 - ffff908f`70aeea8f at offset 0006d160
ffffd58c`6c611440 - ffffd58c`6c61153f at offset 0006d260
ffffd58c`70cd1b10 - ffffd58c`70cd1c0f at offset 0006d360
ffffd58c`6b9f3528 - ffffd58c`6b9f3607 at offset 0006d460
ffffd58c`64cc25f8 - ffffd58c`64cc26f7 at offset 0006d540
ffff908f`68c4c060 - ffff908f`68c4c10f at offset 0006d640
ffff908f`68c4c110 - ffff908f`68c4c11f at offset 0006d6f0
ffff908f`68c4c120 - ffff908f`68c4c12f at offset 0006d700
ffff908f`68c4c130 - ffff908f`68c4c13f at offset 0006d710
ffff908f`68c4c140 - ffff908f`68c4c14f at offset 0006d720
ffff908f`6b29b8f0 - ffff908f`6b29b9ef at offset 0006d730
ffffd58c`541d81e0 - ffffd58c`541d82df at offset 0006d830
ffff908f`6b298780 - ffff908f`6b29887f at offset 0006d930
ffffd58c`540bd130 - ffffd58c`540bd22f at offset 0006da30
ffffd58c`540dae60 - ffffd58c`540daf5f at offset 0006db30
ffff908f`6afd2de0 - ffff908f`6afd2edf at offset 0006dc30
ffff908f`68c4f8e0 - ffff908f`68c4f9df at offset 0006dd30
fffff803`ff181e00 - fffff803`ff181eff at offset 0006de30
ffff908f`68d69b90 - ffff908f`68d69c8f at offset 0006df30
fffff803`ff14c9f0 - fffff803`ff14caef at offset 0006e030
ffff908f`6d147c00 - ffff908f`6d147cff at offset 0006e130
ffff908f`6d85d010 - ffff908f`6d85d10f at offset 0006e230
ffff908f`6c35ef10 - ffff908f`6c35f00f at offset 0006e330
ffffd58c`540d7ed0 - ffffd58c`540d7fcf at offset 0006e430
Max offset 6e530, 20044 from end of file
Strings
PAGEDU64
PAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGE
PAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGE
PAGExL
PAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGE4
GEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGEPAGE
aswHdsKe.sys
WdFilter.sys
WdNisDrv.sys
OpenHardware
WdFilter.sys
dump_storpor
dump_storahc
dump_dumpfve
EhStorClass.
EhStorClass.
amdkmafd.sys
dam.sys
WdBoot.sys
hwpolicy.sys
GenuineIntel
Pvu^8Z
System
\SystemRoot\system32\ntoskrnl.exe
\SystemRoot\system32\hal.dll
\SystemRoot\system32\kd.dll
\SystemRoot\system32\mcupdate_GenuineIntel.dll
\SystemRoot\System32\drivers\msrpc.sys
\SystemRoot\System32\drivers\ksecdd.sys
\SystemRoot\System32\drivers\werkernel.sys
\SystemRoot\System32\drivers\CLFS.SYS
\SystemRoot\System32\drivers\tm.sys
\SystemRoot\system32\PSHED.dll
\SystemRoot\system32\BOOTVID.dll
\SystemRoot\System32\drivers\FLTMGR.SYS
\SystemRoot\System32\drivers\clipsp.sys
\SystemRoot\System32\drivers\cmimcext.sys
\SystemRoot\System32\drivers\ntosext.sys
\SystemRoot\system32\CI.dll
\SystemRoot\System32\drivers\cng.sys
\SystemRoot\system32\drivers\Wdf01000.sys
\SystemRoot\system32\drivers\WDFLDR.SYS
\SystemRoot\system32\drivers\WppRecorder.sys
\SystemRoot\system32\drivers\SleepStudyHelper.sys
\SystemRoot\System32\Drivers\acpiex.sys
\SystemRoot\system32\drivers\mssecflt.sys
\SystemRoot\System32\drivers\ACPI.sys
\SystemRoot\System32\drivers\WMILIB.SYS
\SystemRoot\System32\drivers\intelpep.sys
\SystemRoot\system32\drivers\WindowsTrustedRT.sys
\SystemRoot\System32\drivers\WindowsTrustedRTProxy.sys
\SystemRoot\System32\drivers\pcw.sys
\SystemRoot\System32\drivers\msisadrv.sys
\SystemRoot\System32\drivers\pci.sys
\SystemRoot\System32\drivers\vdrvroot.sys
\SystemRoot\system32\drivers\pdc.sys
\SystemRoot\system32\drivers\CEA.sys
\SystemRoot\System32\drivers\partmgr.sys
\SystemRoot\System32\drivers\spaceport.sys
\SystemRoot\System32\drivers\volmgr.sys
\SystemRoot\System32\drivers\volmgrx.sys
\SystemRoot\System32\drivers\mountmgr.sys
\SystemRoot\System32\drivers\storahci.sys
\SystemRoot\System32\drivers\storport.sys
\SystemRoot\System32\drivers\fileinfo.sys
\SystemRoot\System32\Drivers\Wof.sys
\SystemRoot\System32\Drivers\NTFS.sys
\SystemRoot\System32\Drivers\Fs_Rec.sys
\SystemRoot\system32\drivers\ndis.sys
\SystemRoot\system32\drivers\NETIO.SYS
\SystemRoot\System32\Drivers\ksecpkg.sys
\SystemRoot\System32\drivers\tcpip.sys
\SystemRoot\System32\drivers\fwpkclnt.sys
\SystemRoot\System32\drivers\wfplwfs.sys
\SystemRoot\System32\DRIVERS\fvevol.sys
\SystemRoot\System32\drivers\volume.sys
\SystemRoot\System32\drivers\volsnap.sys
\SystemRoot\System32\Drivers\SmartDefragDriver.sys
\SystemRoot\System32\drivers\rdyboost.sys
\SystemRoot\System32\Drivers\mup.sys
\SystemRoot\system32\drivers\iorate.sys
\SystemRoot\System32\drivers\disk.sys
\SystemRoot\System32\drivers\CLASSPNP.SYS
\SystemRoot\System32\Drivers\crashdmp.sys
\SystemRoot\System32\drivers\cdrom.sys
\SystemRoot\system32\drivers\filecrypt.sys
\SystemRoot\system32\drivers\tbs.sys
\SystemRoot\System32\Drivers\Null.SYS
\SystemRoot\System32\Drivers\Beep.SYS
\SystemRoot\System32\drivers\BasicDisplay.sys
\SystemRoot\System32\drivers\watchdog.sys
\SystemRoot\System32\drivers\dxgkrnl.sys
\SystemRoot\System32\drivers\vmbkmclr.sys
\SystemRoot\System32\drivers\BasicRender.sys
\SystemRoot\System32\Drivers\Npfs.SYS
\SystemRoot\System32\Drivers\Msfs.SYS
\SystemRoot\system32\DRIVERS\tdx.sys
\SystemRoot\system32\DRIVERS\TDI.SYS
\SystemRoot\System32\DRIVERS\netbt.sys
\SystemRoot\system32\drivers\mrxsmb22.sys
\SystemRoot\system32\drivers\afd.sys
\SystemRoot\system32\DRIVERS\VBoxNetLwf.sys
\SystemRoot\System32\drivers\vwififlt.sys
\SystemRoot\System32\drivers\pacer.sys
\SystemRoot\system32\drivers\netbios.sys
\SystemRoot\system32\DRIVERS\rdbss.sys
\SystemRoot\system32\drivers\csc.sys
\SystemRoot\system32\DRIVERS\VBoxUSBMon.sys
\SystemRoot\system32\DRIVERS\VBoxDrv.sys
\SystemRoot\system32\drivers\nsiproxy.sys
\SystemRoot\System32\drivers\npsvctrig.sys
\SystemRoot\System32\drivers\mssmbios.sys
\??\C:\ProgramData\Microsoft\Windows Defender\Definition Updates\{5352D0E7-374E-4E77-B09D-DD0E84FBB94C}\MpKslc066f949.sys
\??\C:\ProgramData\Microsoft\Windows Defender\Definition Updates\{CDE1B3CE-9D0D-4DBD-B54F-34BF4B21B359}\MpKslb5db646b.sys
\SystemRoot\System32\drivers\gpuenergydrv.sys
\SystemRoot\System32\Drivers\dfsc.sys
\SystemRoot\system32\drivers\bam.sys
\SystemRoot\SysWow64\drivers\AsUpIO.sys
\SystemRoot\SysWow64\drivers\AsIO.sys
\SystemRoot\system32\DRIVERS\ahcache.sys
\SystemRoot\System32\DriverStore\FileRepository\compositebus.inf_amd64_9c1fb8f4db31c348\CompositeBus.sys
\SystemRoot\System32\drivers\kdnic.sys
\SystemRoot\System32\drivers\umbus.sys
\SystemRoot\System32\DriverStore\FileRepository\c0318486.inf_amd64_11ba0b4b7cc81d52\atikmpag.sys
\SystemRoot\System32\DriverStore\FileRepository\c0318486.inf_amd64_11ba0b4b7cc81d52\atikmdag.sys
\SystemRoot\System32\drivers\HDAudBus.sys
\SystemRoot\System32\drivers\portcls.sys
\SystemRoot\System32\drivers\drmk.sys
\SystemRoot\System32\drivers\ks.sys
\SystemRoot\SysWow64\drivers\AiChargerPlus.sys
\SystemRoot\System32\drivers\USBXHCI.SYS
\SystemRoot\system32\drivers\ucx01000.sys
\SystemRoot\System32\drivers\TeeDriverW8x64.sys
\SystemRoot\System32\drivers\asmtxhci.sys
\SystemRoot\System32\drivers\serial.sys
\SystemRoot\System32\drivers\serenum.sys
\SystemRoot\system32\DRIVERS\e1d65x64.sys
\SystemRoot\System32\drivers\wmiacpi.sys
\SystemRoot\System32\drivers\intelppm.sys
\SystemRoot\System32\drivers\acpipagr.sys
\SystemRoot\System32\drivers\NdisVirtualBus.sys
\SystemRoot\System32\drivers\swenum.sys
\SystemRoot\System32\drivers\ScpVBus.sys
\SystemRoot\System32\drivers\rdpbus.sys
\SystemRoot\system32\drivers\xspltspk.sys
\SystemRoot\system32\drivers\ksthunk.sys
\SystemRoot\system32\drivers\AtihdWT6.sys
\SystemRoot\System32\drivers\UsbHub3.sys
\SystemRoot\System32\drivers\USBD.SYS
\SystemRoot\system32\drivers\RTKVHD64.sys
\SystemRoot\System32\drivers\uaspstor.sys
\SystemRoot\System32\drivers\asmthub3.sys
\SystemRoot\System32\drivers\USBSTOR.SYS
\SystemRoot\System32\drivers\usbccgp.sys
\SystemRoot\SysWow64\drivers\AndroidAFDx64.sys
\SystemRoot\System32\drivers\hidusb.sys
\SystemRoot\System32\drivers\HIDCLASS.SYS
\SystemRoot\System32\drivers\HIDPARSE.SYS
\SystemRoot\System32\drivers\mouhid.sys
\SystemRoot\System32\drivers\mouclass.sys
\SystemRoot\System32\drivers\kbdhid.sys
\SystemRoot\System32\drivers\kbdclass.sys
\SystemRoot\system32\drivers\I1KBFLTR.sys
\SystemRoot\System32\win32k.sys
\SystemRoot\System32\win32kfull.sys
\SystemRoot\System32\win32kbase.sys
\SystemRoot\System32\drivers\dxgmms2.sys
\SystemRoot\system32\DRIVERS\udfs.sys
\SystemRoot\System32\drivers\TVMonitor.sys
\SystemRoot\System32\TSDDD.dll
\SystemRoot\System32\cdd.dll
\SystemRoot\System32\Drivers\dump_diskdump.sys
\SystemRoot\System32\Drivers\dump_storahci.sys
\SystemRoot\System32\Drivers\dump_dumpfve.sys
\SystemRoot\system32\drivers\luafv.sys
\SystemRoot\system32\drivers\wcifs.sys
\SystemRoot\system32\DRIVERS\WUDFRd.sys
\SystemRoot\System32\drivers\WpdUpFltr.sys
\SystemRoot\system32\drivers\cldflt.sys
\SystemRoot\system32\drivers\storqosflt.sys
\SystemRoot\System32\drivers\condrv.sys
\SystemRoot\system32\drivers\mslldp.sys
\SystemRoot\system32\drivers\lltdio.sys
\SystemRoot\system32\drivers\rspndr.sys
\SystemRoot\system32\drivers\HTTP.sys
\SystemRoot\system32\DRIVERS\bowser.sys
\SystemRoot\System32\drivers\mpsdrv.sys
\SystemRoot\system32\DRIVERS\mrxsmb.sys
\SystemRoot\system32\DRIVERS\mrxsmb20.sys
\SystemRoot\system32\DRIVERS\atksgt.sys
\SystemRoot\system32\DRIVERS\idmwfp.sys
\SystemRoot\System32\DRIVERS\srvnet.sys
\SystemRoot\System32\DRIVERS\srv2.sys
\??\C:\Windows\system32\drivers\mi2c.sys
\SystemRoot\system32\DRIVERS\lirsgt.sys
\SystemRoot\system32\drivers\mmcss.sys
\SystemRoot\system32\drivers\Ndu.sys
\SystemRoot\system32\DRIVERS\mrxsmb10.sys
\SystemRoot\system32\drivers\peauth.sys
\SystemRoot\system32\drivers\npf.sys
\SystemRoot\System32\DRIVERS\srv.sys
\SystemRoot\System32\drivers\tcpipreg.sys
\??\C:\Program Files (x86)\Common Files\Realtime Soft\UltraMonMirrorDrv\x64\UltraMonUtility.sys
\??\C:\WINDOWS\system32\drivers\IOMap64.sys
\SystemRoot\System32\drivers\rassstp.sys
\SystemRoot\System32\DRIVERS\NDProxy.sys
\SystemRoot\System32\drivers\AgileVpn.sys
\SystemRoot\System32\drivers\rasl2tp.sys
\SystemRoot\System32\drivers\raspptp.sys
\SystemRoot\System32\DRIVERS\raspppoe.sys
\SystemRoot\System32\DRIVERS\wanarp.sys
\SystemRoot\System32\DRIVERS\ndistapi.sys
\SystemRoot\System32\drivers\ndiswan.sys
\SystemRoot\system32\drivers\aswVmm.sys
\SystemRoot\system32\drivers\aswSP.sys
\SystemRoot\system32\drivers\aswbidsdrivera.sys
\SystemRoot\system32\drivers\aswbidsha.sys
\SystemRoot\system32\drivers\aswbloga.sys
\SystemRoot\system32\drivers\aswbuniva.sys
\SystemRoot\system32\drivers\aswSnx.sys
\SystemRoot\system32\drivers\aswRdr2.sys
\SystemRoot\system32\drivers\aswArPot.sys
\SystemRoot\system32\drivers\aswMonFlt.sys
\SystemRoot\system32\drivers\aswStm.sys
Fqw*8dz
GenuineIntel
GenuineIntel
2#I#+L
GenuineIntel
GenuineIntel
Pvu^8Z
^f3:H:
GenuineIntel
>93v_"
GenuineIntel
GenuineIntel
GenuineIntel
16299.15.amd64fre.rs3_release.170928-1534
!This program cannot be run in DOS mode.
1;Rich
h.rdata
H.data
.pdata
B.reloc
z<;b5"
c AUAVAWH
fD9 u.fD9p
u'fD9p
u fD9`
H9t$@t
A_A^A]
UVWATAUAVAWH
H1Q H1Q(H1Q0H1Q8H1Q@H1QHH1QPH1QXH1Q`H1QhH1QpH1QxH1
fffffff
H;D$8u
H;D$8t
ffffff
fffffff
x UATAUAVAWH
A_A^A]A\]
Freee8i
WfpH83
TpWcu!
\.)w:b
\.)w:b
\.)w:b
\LMq:b
\LMq:b
\LMq:b
\$Mft::$BITMAP
\$ UVWH
'dwcq/
\REGISTRY\MACHINE\SYSTEM\Control
ObjTBGBK
PsSiloContextPaged
USBXHCI.SYS
NtFsUV
FMfn5-
SuperfetchParametersChanged
ObNm%!
cdromll
ObNmE!
NTPNP_PCI0010
LL_OEMID
CM396350_TAB
\Device\HarddiskVolumeShadowCopy1
STORAGE#Volume#{c7d72784-e193-11e5-8565-806e6f6e6963}#000000
NtfoU+
\Programes\SteamLibrary\steamapps\common\Half-Life\valve\sound\holo
\$Extend\$RmMetadata\$TxfLog
50265E9}
\??\SCSI#Disk&Ven_Patriot&Prod_Torch_LE#4&39
MPSSVC
CMnb5A
sk\Device\
AvN @e
C:\Users
S-1-15-2-95739096-486727260-2033
59C:\Users\Ryan\AppDat
P::operator ()(153):NetworkFlyoutInitialized
NetworkUX
NetworkUX
NetworkUX::ViewContext::{ctor}::::operator ()(164):initThreadWork Exit
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_ResizeWindow(876):Enter
NetworkUX
NetworkUX
NetworkUX::ViewContext::_ResizeWindow(917):Wi-Fi category count: 0, shrinkForWiFiOff: 0, shrinkForMbbOff: 1
NetworkUX
NetworkUX
NetworkUX::ViewContext::_ResizeWindow(948):New flyout height: 146, othermediaCategoryCount: 1, airplaneModeOn: 0, isQuickSettingsVisible: 0, nSeparators: 0
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_ResizeWindow(992):Exit
NetworkUX
NetworkUX
Verbose
NetworkUX
NetworkUX
NetworkUX
NetworkUX
NetworkUX
NetworkUX
Verbose
Windows.Networking.UX.Internal.EthernetMediaManager
Ethernet
Ethernet
Ethernet
TALKTALK2985AE
Internet access
NetworkUX
NetworkUX
NetworkUX::ViewContext::{ctor}::::operator ()(131):initThreadWork Enter
NetworkUX
NetworkUX
NetworkUX::ViewContext::_Initialize(243):Enter
NetworkUX
NetworkUX
NetworkUX::ViewContext::_Initialize(246):Instantiated settings database
NetworkUX
NetworkUX
NetworkUX::ViewContext::_OnReactivatedEvent(1039):Network flyout is visible
NetworkUX
NetworkUX
NetworkUX::ViewContext::_OnReactivatedEvent(1045):Network flyout became visible after the initialization completed. We will go ahead and display the list now.
NetworkUX
NetworkUX
NetworkUX::ViewContext::~ViewContext(200):Exit
Ethernet
Ethernet
Ethernet
Ethernet
Ethernet
Ethernet
Ethernet
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::OnAirplaneModeEvent(573):Enter, airplaneModeOn: 0, changeAllowed: 0
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::OnAirplaneModeEvent(589):Exit
NetworkUX
NetworkUX
Verbose
NetworkUX
NetworkUX
Verbose
Ethernet
Ethernet
Ethernet
Ethernet
Windows.Networking.UX.Internal.DAMediaManager
Windows.Networking.UX.Internal.RasMediaManager
Ethernet
NetworkUX
NetworkUX
NetworkUX::ViewContext::_UpdateQuickSettingsVisibility(1158):IsQuickSettingsVisible: 0, wifiQuickActionApplicable: 0, airplandeModeQuickActionApplicable: 0, mbQuickActionApplicable: 0, tetheringQuickActionApplicable: 0
NetworkUX
NetworkUX
NetworkUX::ViewContext::_DisplayList(1105):IsWiFiContentVisible: 0
NetworkUX
NetworkUX
NetworkUX::ViewContext::_DisplayList(1108):IsMBBContentVisible: 0
NetworkUX
NetworkUX
NetworkUX::ViewContext::_DisplayList(1111):IsVPNContentVisible: 0
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_UpdateDividerRequired(1007):Enter
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_UpdateDividerRequired(1031):Exit
NetworkUX
NetworkUX
Verbose
NetworkUX
NetworkUX
NetworkUX
NetworkUX
NetworkUX
NetworkUX
Verbose
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_DisplayList(1134):Exit
=2sow\;
=2sow\;
=2sow\;
NetworkUX
NetworkUX
NetworkUX::ViewContext::~ViewContext(175):Enter
Ethernet
Internet access
Ethernet
NetworkUX
NetworkUX
Verbose
NetworkUX
NetworkUX
Verbose
=2sow\;
NetworkUX
NetworkUX
NetworkUX::ViewContext::_OnReactivatedEvent(1051):Network flyout is hidden
Ethernet
Ethernet
NetworkUX
NetworkUX
Verbose
NetworkUX
NetworkUX
NetworkUX
NetworkUX
NetworkUX
NetworkUX
Verbose
Ethernet
Ethernet
Ethernet
Ethernet
NetworkUX
NetworkUX
NetworkUX::ViewContext::_Initialize(260):NetworkUXManager has been initialized
EapHostPeerInitialize Entry
EapHostPeerInitialize Exit:
returning(0)
Ethernet
not set
ncasvc
Ethernet
Ethernet
NetworkUX
NetworkUX
NetworkUX::ViewContext::ViewContext(80):Enter
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_IsVPNConnectionFlowEnabled(42):Enter
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_IsVPNConnectionFlowEnabled(67):Vpn registration enabled
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_IsVPNConnectionFlowEnabled(74):Exit
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::ViewContext(169):Exit
Ethernet
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_AddCategoryToList(707):Enter
NetworkUX
NetworkUX
NetworkUX::ViewContext::_AddCategoryToList(728):Adding Ethernet category to the UI list
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_AddCategoryToList(777):Exit
NetworkUX
NetworkUX
Verbose
NetworkUX::ViewContext::_DisplayList(1063):Enter
NetworkUX
NetworkUX
NetworkUX::ViewContext::_DisplayList(1070):Instantiated SettingsEnvironmentDatabase
NetworkUX
NetworkUX
NetworkUX::ViewContext::_DisplayList(1080):Queried quick actions provider
Ethernet
I believe fffff80267370000 (arg 3 in the dump you posted) contains the module (.dll) that went wrong, however that tool hasn't listed what it is.
Could you upload/send me the raw .dmp file so I can try drilling into it?
Ah, I completely missed that.
SF4AE1, maybe try making sure you have the latest graphics drivers, or try another card (or the onboard one) if you can - it may be a failing card.
Thanks guys I will try updating the GPU driver and if no joy I can upload the raw data for your Pho - Honestly thanks taking the time to help
Little bit an update guys more crashes overnight but who crashed seems to have identified something
Conclusion
16 crash dumps have been found and analyzed. Only 5 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
mrxsmb22.sys (NetFilter SDK WFP Driver (WPP), Windows (R) Win 7 DDK provider)
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Looking into this file above after some googling it seems to be a bit dodgy - Also only created in my system a few days ago with no previous versions - This is all when the crahes started
