HDR pass-through and integrated headphones.Whats the difference between V1 & V2?
ThanksHDR pass-through and integrated headphones.
Most important bit is the HDR support (passthrough). Also the cable is half the thickness and doesn't have the junction box on it so makes it lighter. Also the headphone socket is moved to the headset together with controls. The Processing unit is also redesigned.
Now all I need to do is find one!![]()
For me it's not enough of an upgrade to buy another one.
Out of interest does the new pass through box work with the older headset?
Might be enough for some users to order a new Box if it works.
After doing a bit of research you are quite right, the cable from the V1 extension cable won't actually fit in the V2 box.everything I've said says you cant mix v1 & v2
I would say yes as everything I've tried with the move uses 2 of themso I have just found an old move controller from the PS3 days, do I really need a second one to get most out of VR?
Ok, next question; are the newer move controllers any different to the ps3 ones?
http://www.very.co.uk/playstation-v...iate&utm_term=HotUKDeals_47868&utm_content=naIs this one any good or is it as good as the Skyrim edition one... https://www.currys.co.uk/gbuk/tv-an...playstation-vr-starter-pack-10173050-pdt.html
