- 9 May 2012
- South Wales
Well apperently my motherboard doesnt support overclocking OR downclocking because there is no option available to change cpu ratio only the vcore...
What is also weird in running stock at 3.5ghz and 3.7boost and i cant even get it below 1.32v or it will be unstable does that sound correct? Because i just cant lower it past that..
So right now it sits at usually 1.32-1.34v and sometimes reached 1.37-1.38 but quickly goes back down to the 1.34v spot but Its weird because in running stock anything lower makes my computer give black screen randomely and reboots...
Mobo is Asus prime a320m-k
Cpu is Ryzen 5 1500x stock
Hi marlon again
What make psu and power is it running ?
I will try have a look later see if can find some info out for you, had a little look last night but couldn’t see anything.
A lot off people will have the b350 or ax370 boards which you can tweak more
finally!
should i still mess with the vcore tho or Just leave it on auto? Because max i see is 1.3v on 3.5ghz usually Its in the 1.25-1.27v now
