60hz monitors and frame tearing advice
13 Oct 2004
Teesside
Hi all,
I recently helped a friend get into PC gaming on a budget, and as a result he has a cheaper 'gaming' monitor which although has 1ms response time, only is 60hz with no freesync / gsync.
I've always had high refresh rate monitors / G-sync and so have never had problems with tearing in the past.
The first game we tried was Doom, and with a constant 100+fps the tearing was horrible. With V-sync on the input lag was also horrible.
Perhaps I've been spoilt in the past with high refresh rate monitors and G-Sync etc, but I don't ever recall seeing frame tearing as bad as we experienced on doom with his setup.
Is this game particularly bad for tearing, or is there anything I can do to mitigate either the tearing with v-sync off, or the input lag with v-sync on?
One last query is does having borderless windowed mode / fullscreen have any bearing on tearing?
Thanks for your advice in advance,
Pes x
Overclock it to 75hz might make it a little better? what is the monitor?
Thanks - I think I'll look into this - I'm not sure what the monitor is exactly until I go back around my friends house.
To overclock it do I just create a custom resolution in nvidia control panel?
Thanks
Thanks
yes then apply it in the windows res settings
