 - 1 Dec 2015
That's if the board allows that GPU ... Bios update might allow it
			well this is what i'm thinking, will see what boxing day will bringI'd wholeheartedly pick the 1050ti to go with your q9550 otherwise a faster gpu most certainly will be bottlenecked by the cpu/processor.
 thank you all for input and suggestions
Well i've updated it to the latest what i found online as the one on msi page wasn't the latest and was making my pc to do RR when starting it up. And on the compatability list it states that it supportsThat's if the board allows that GPU ... Bios update might allow it
But there it shows for 2.83 or oc of 3.4 don't make difference??According to this http://thebottlenecker.com/#project a GTX 970 and a GTX 1050Ti will be largely bottlenecked by your CPU, whereas a GTX 1050 will work well with only a 7% bottleneck.
This is at stock speed, but I would presume that the 7% bottleneck for the GTX 1050 would probably be negated somewhat by an OC of 3.4GHz.But there it shows for 2.83 or oc of 3.4 don't make difference??
well this is what i'm thinking, will see what boxing day will bringthank you all for input and suggestions
If a 6-core/12-thread Westmere with GeForce GTX 980 can't handle it, imagine what kind of a system it requires, a GTX 1080 Ti for sure![]()
Thank you for your input aswell. But now is there a point for 970 if in couple of years that pc will be just for htpc? And i will just need hdmi or dp port so to get sound and video out of itThat system should be able to run pubeg no problem, I'm running a Westmere too, the x5650 clocked to 4.4ghz with a 1070ti and on the test server (which appears to be much better optimised) I get over 100fps minimum. It's usually hovering around the 120-160fps range. I'm running everything in very low except for: AA- high, textures - high, effects - medium, draw distance - high.
As for the op's question, I'd get the 970, it's significantly faster. I have a 1050ti in my gen8 microserver (with quad core Xeon E3 1265l v2) and its around 40-70fps with EVERYTHING on very low.
I'll see whats the cheapest i could get 970, as for me new or used in the same price bracket thats why pocket goes for buying new thing but in my head the raw power of 970 takes the olace against the 1050tiI think in a couple of years when you look to upgrade again you'd be better off selling the 970 at that point and getting a lesser spec non gaming card which just draws power through the PCI-E bus. I have a Gen8 Microserver for my HTPC and the 1050ti is in that. I only got that for some light gaming though, then decided to build a proper gaming PC. Even then, the 1050ti is 75w TDP (actual draw on mine was 69w TDP iirc). 970 I'll guess is significantly higher, probably even on idle lol.
 thats why confused. But i'll see whats good around. And whats the best price for used one would be??for me that 970 looks as well better to get it but i'm not sure if my mobo will be compatible with it... and going with new 1050ti i will be able to return itDunno about price, but performance wise the 970 will kill it.
 because i checked and i'm running already the latest bios so might be tricky
i'm not worried about how hungry it is, i'm just confused what to do with it if it won't run on this pcGTX970 is a 150w card, it's not a power hungry card at all. You could undervolt/underclock it to reduce TDP and it'd probably still beat the 1050ti.
 to resell again
i'm not worried about how hungry it is, i'm just confused what to do with it if it won't run on this pcto resell again
Ill wait till boxing day or any closer sales to see whats on the desk untill then i might find a friend who has 970 so to try out in my pc if it runs will go with 970That is what i was thinking, about you reselling the gtx 970 or possibly upgrading your cpu ram and motherboard.
 will seeIm not worried about cpu im about mobo if it will be compatibleI used to run a q9550 and a 970. Worked a charm at 1080p for all games at medium/high settings.
The q9550 chip is such a beast of a cpu still to this day it has clout.
