Lot of misinformation & assumption here... 2017 LG RGBW HDTV's look incredible I just bought a 49" UHD text is razor sharp from 2 ft away & easily capable of web browsing as well as dual use as a gaming PC & HTPC! 49,55 & 60" models are godlike image wise & sheer scale of the beast!When I have some more time I will post a few pics of mine.............You need to buy an Active Display Port to HDMI adapter for best PC picture quality as most HDTV's do not have Display Port. Currently though you need HDMI 2.0a for HDR so no way to get HDR on PC with Display Port & a HDTV so that means you either compromise & run a pure HDMI 2.0a to HDMI 2.0a cable between GPU & Display (you can only get limited 16-235) or get full range 0-255 colour from your GPU via a Display Port to HDMI 2.0 adapter which is active & capable of 4K @ 60 Hz (cost around £20 for a proper model avoid the cheaper ones they can only do 4K @ 30 Hz).
Windows 10 HDR is a mess on PC you must have certain hardware or its not even possible for protected content! This is really dumb by MS as its actually slightly cheaper to buy a top of the line UHD player & recent HDTV than build a high end 4K gaming capable PCThey clearly do not want 4K HDR UHD playback for the masses on PC & 2017 high end HDTVs have the included playback now just plug into the net & on the LG for example they have Dolby Vision for Netflix UHD content (LG are one of the only HDTV manufacturer with Dolby Vision for Netflix UHD right now. It gives Stranger Things Season 2 a very filmic & lifelike appearance
https://support.microsoft.com/en-gb/help/4040547/windows-10-display-requirements-hdr-video
Finally MS also just removed free HEVC codec support on brand new Win 10 installs you now have to buy the codec to playback HEVC (x265) which is basically 4K content as most is in this format!
http://www.guru3d.com/news-story/4k...gpus-(update)-ms-pulls-free-hevc-support.html
Not seen it in person but here is an old link which shows the issue RGBW has with text vs a standard RGB layout: http://www.hdtvtest.co.uk/news/rgbw-201510084189.htm. Probably not an issue at normal TV viewing distances but would be an issue for close viewing when used as a desktop monitor. Maybe the newer models are better now?
I think the best picture is still HDMI 2.0 to HDMI 2.0 (RGB Full 0-255, 4k @ 60hz), this definitely works on a supported HDMI 2.0 graphics card (e.g. 1070 GTX). Although if your PC lacks HDMI 2.0 then a 4k 60hz capable display-port adaptor would be the next best option. HDR requires you to switch to YCbCr4:2:2 10 bit (due to hdmi 2.0 18gbps bandwidth limitation) which will mess up the text quality due to sub-sampling, not sure if this is possible with a display-port adaptor (some adaptors do claim to support HDMI 2.0a HDR).
Yes Windows HDR support is a mess, best to stick with the smart TV apps for Amazon Prime, Netflix etc which work well. HDR gaming on PC seems to work well for the few games that support it, but it is a bit of hassle switching output between RGB Full and YCbCr4:2:2, 10 bit, HDR. Lower end 4K TV's give a limited HDR experience as they can't reach the high brightness levels required for premium certification, however 1,000+ nits is probably a bit much if your only sat 1 ft from the screen.
Once you try this telly you would be hard pressed to find anything better. But I would definitely go curved for PC monitor in this size range - IT IS NOT A HYPE! - and something Like Vega 56 and upwards will be great match! Cheers
